Hey Thanks for your help! I have found a Halibrand rear for my Dodge build it has wide five hubs on it! I wanted to see if anyone has some example of wide five wheels! Or ideas or something! It maybe to expensive to switch all that out to ford axles etc.. Or can you buy some wheels aftermarket! The race car wide fives are to wide and expensive! the original style are to skinny but maybe I can modify a good idea!! Thanks a Bunch! Jer
I use steel wide-five wheels from Diamond Racing Wheels. They will make them in any width...I had 5" wide ones made to fit my Bonneville tires. About $75 each, as I recall. You can choose your offset. They also make them in aluminum. HPace
