I have a 46 V8 that I put the new mallory electronic distributor on, (2 bolt with crab like cap). Problem: The cap winds up directly under the fan belt...no way to put the wires on it. Anyone had this trouble? only thing I can see at this time is to eliminate the fan and use electric, not my first choicce,,as I wanted to heep the "old" look. Lance Alfieri captainlance@optonline.net
Throw the thing away...you are at the beginning of finding its problems! Get a '46-48 distributor, electronically converted ones are out ther...try GMC Bubba on here...and solve all the problems at once. The early Ford distributor, by the way, is based on Mallory patents...not so much the current Chinese Mallorys.
x2, mallory isnt the quality of product it used to be. If you do decide to run it make sure you carry a spare everything.
recently got a 46 with that mallory thing on it, no way to put a fan, running 2 electric ones right now, i agree with what they say its junk, especialy on a stock flathead no need for it stcok dist will work fine
Thanks to everyone who replied, Since I bought it alreadsy, I'll live with it till it ****s out...I will bne using a 16" SPAL puller fan as a replacement. lance
