Technical HEMI Tech- INDEX
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 5, 2006.
  1. scootermcrad
    scootermcrad
    EDIT (by Flat Ernie) - Here is a live link to the active thread on the board:
    http://www.jalopyjournal.com/forum/showthread.php?t=118764
    Just to make things even MORE simple... here's an index of the articles and subjects we've been talking about so far. I will update the "Index" as new ones come in.
    NEW! These topics as well as more discussions can be found here:
    http://www.jalopyjournal.com/forum/group.php?groupid=273
    HEMI Tech- General parts and info resources
    HEMI Tech- Identification
    HEMI Tech- What are these engines worth?
    HEMI Tech- Gaskets
    HEMI Tech- Block, head, porting/polishing, gaskets, mounting
    HEMI Tech- Transmission adapters, flywheels, starters
    HEMI Tech- Hemi Engine Mounts
    HEMI Tech- Intakes and exhaust manifolds
    HEMI Tech- Ignition
    HEMI Tech- Blowers, Superchargers, fuel injection
    HEMI Tech- Rockers, valves, pushrods, springs
    HEMI Tech- PISTONS! rods and related
    HEMI Tech: Water pump. Change? Rebuild? Run it?
    HEMI Tech: Oil systems- filters, pumps, pans
    HEMI Tech: Camshafts.. new? Regrind? solid or Hydraulic?
    HEMI Tech- Crankshafts. Stock? Billet? Stroker?
    HEMI Tech- Harmonic Balancers
    HEMI Tech: Alternator? Generator? Acc. Brackets?
    HEMI tech- Chevy H2O pump and pulleys?
    HEMI Tech- fuel pumps and covers- timing, valley and valve/rocker
    HEMI Tech- Examples and specs!
    HEMI Tech: Vacuum, Breathing and crank case pressure
    HEMI Tech: Machining
    HEMI Tech- Daimler Hemis
    HEMI Tech- POLY Tech - early poly motor info
    HEMI Tech- Rebuilds
    HEMI Tech: Machine Shop Reference by State
    Please PM me if any of these links don't work or if you have some ideas for new topics. Still have some in mind and will post them and update this list as they happen. In the mean time, let's all help keep the subjects full of up to date useful information.
    Hope these topics help everyone!
    Scooter
    artificer64 and RODIST like this.
  2. BloodyKnuckles
    BloodyKnuckles
    I'm not sure how many people have been benefitting from you threads but I must say that you rock!
    I'm working on a Desoto 291 for my "A" and you have unearthed a treasure chest of knowledge and information for all to share.
    Thank You!
    ******Knuckles
  3. axeman39
    axeman39
    from Saco Maine
    With my unofficial count of 73 Hemi owners and 150ish Hemis here on the HAMB, I would say that the Hemi tech threads are more than worth the effort put fourth and very much appreciated. Thanks! Axeman39.:)
  4. scootermcrad
    scootermcrad
    Thanks guys!! I appreciate the nice words! I'm glad they're helping someone. I know they're certainly helping me!! I've been spending so much time just trying to get the subjects up that I've hardly had time to even read them! I'm excited to sit down and start taking notes myself. The HAMB rules and with the amount of Hemi knowledge on here the HEMI Tech threads should rule too!
    Thanks for the help gathering info everyone! We still have a long way to go!
    BTW... This isn't just for Chrysler FirePowers! We need info on Dodge, DeSoto, the poly motors, the small cube Hemis... EVERYTHING!
  5. scootermcrad
    scootermcrad
    Just wanted to bump this up for you guys. I added a couple catagories for your viewing pleasure. It will take some time to get all these catagories filled out, but the topics are started. If anyone thinks of a topic that's NOT coverd here, let me know or start it with "HEMI Tech- ********" and I'll add it to the "Index". Just check to make sure it's not covered. Had some thoughts of some other ideas like Video rentals and things of that nature for resources. Have to figure out how to handle those yet. Not sure if that will be addressed in these or not.
    We'll get there!
    In the mean time, check out Harmonic Balancers and Identification and see if there is any factual information you can add!
    Cheers!
    Scooter
  6. scootermcrad
    scootermcrad
    Just wanted to bump this up in case it hasn't been seen yet. Let me know if there is any way I can add or improve what's already been started.
    Also... there are some subjects still virtually blank. If there is any info anyone can add to those sections, please do so. This seems to have been a great thing for anyone needing Hemi info thus far...
  7. right on man. this almost makes me want a hemi...almost!
  8. scootermcrad
    scootermcrad
    Bumping the Index back up to the top since there has been a lot of Hemi talk lately. Still trying to keep these updated. If anyone sees information that can be linked to under these topics, please add it.
    THANKS! :)
    Scooter
  9. ward3162
    ward3162
    Hemi Tech is definitely needed. Just getting back into Hot Rodding after a forty year break . Building a 49 Stud P/U w341 Desoto Hemi. Can't get enough info about Desoto Hemis. Thanks for the work.
  10. scootermcrad
    scootermcrad
    We need more Desoto Hemi tech stuff! Anything you could add would be great sir!! [thumbs up]
  11. scootermcrad
    scootermcrad
    Going to bump this up so you guys can take a look at the topics and see if there's anything we can add. We have very little in several catagories. Amazingly the HEMI Tech- Examples and specs!
    has very little in it. Hopefully those of you with Hemis completed or in the works can kick us down some pictures with specs. Maybe even links to your build or something.
    Thanks guys!
    Scooter
  12. scootermcrad
    scootermcrad
    Going to bump the Index back up to the top. I updated the intake/exhaust thread with a link to some Offy 6x2 stuff. Maybe some of you will have some fresh new thoughts and info to add somewhere to some of the other topics involving Hemis.
    Keep the info coming! Some of these topics are looking pretty bare and need more discussion.
    Cheers!
    Scooter
  13. AHotRod
    AHotRod
    Great info and reading Scooter.
  14. strombergs97
    strombergs97
    Hello..OK..I have a 241 Red Ram and and have HH Flex plate.. The flage on the crank does not have any threads..Wondering if the bolts are special..ie..shoulder diameter..Can I use any 8 point bolt..I believe 7/16"..right or wrong..
    I couldn't believe it when I first got ready to put the flex plate on..OH..****..
    Duane..
  15. Kerry
    Kerry
    Thread the flange for 1/2-20 and use bolts instead of the oem bolt/nut setup.
  16. 4tford
    4tford
    Check with HH they have the fex plate bolts which are 7/16 with nuts or the 1/2-20 for tapped cranks. You can tap your crank to use the 1/2-20 the holes are the right size to run the 1/2-20 tap through. Just make sure they are tapped straight.
  17. scootermcrad
    scootermcrad
  18. scootermcrad
    scootermcrad
    Well... we haven't talked about Hemis enough lately... so let's see bump this Index back up so you guys can add to some of these threads where possible.
    Been thinking about adding a reference for machine shops in everyone's area going state by state. Please let me know what you guys think about it. Last time I brought it up it got a good response, but it was brought up very unofficially. So shoot me a PM if you think it's something worthwhile or bump this back up.
    Also, I still haven't done much with feature builds for this section and I've been seeing some very nice progress on a few builds. I may need a kick in the rear or a reminder of who's building what so I can get some featured Hemi builds up for everyone's reference and reading pleasure! :D
    Thanks everyone!
    Scooter
  19. 4tford
    4tford
    I was doing a search back in 2004 on hotheads swap meet forum for shops in my area SE Michigan and got a few hits which are Thomson Automotive in Redford, Mi (313-538-0044) and also Dowker engines in Charlotte, Mi (517-543-0249) and one finale one is Angelucci Performance Macomb, Mi (586-412-8442) I personally have not done business with any of them just wanted a source if I did need one down the road.
  20. scootermcrad
    scootermcrad
    Thanks man! It looks like I better start a thread on this so there is a set place to post this info. I'll do it state by state in a few. The thread will probably get VERY big. Let me think about the best way to handle all the info that will be posted. Maybe I'll do it by alphabetic sections or something. It will take a lot of effort to get it filled out and will take everyone's support here. I will get started on it though.
    Thanks!
  21. Texas Bob
    Texas Bob
    from Las Vegas
    Right on man! Thank's for all the info! Just picked up a 53 Chrysler 331 here in town. See ya at the RRR?
  22. scootermcrad
    scootermcrad
    HEY BOB!!! Welcome to Hemis!! :D
    Yeah, hopefully I'll make it out to the RRR. Would be good to catch up!
    Oh... there are quite a few good places for Hemi machining in you area. Just can't remember the names. When you find out, PM me the details so I can post them in the Nevada section of the resource list.
    Cheers!
  23. edgeabilly
    edgeabilly
    Great info
    I just got a 53 331 Hemi. This is just what I needed...:D
  24. scootermcrad
    scootermcrad
    Okay, it's 2008 and 2007 was a good year getting all this together. WE NEED MORE INFO! Desoto Hemis and Dodge Hemis are hardly discussed and I know there are plenty of people out there that have them that can add info to the catagories. Let's keep it going. We're all here as students so anyone that can teach, please stand up so we can learn more about Hemis!
    Please, if you have experience and knowledge with any breed of early Hemi, take a little bit and read through the various catagories and add what you know.
    Hoping to see more examples and build ups this year. There's a 331 in the works right now that I'm hoping to do a build-up thread on, or at least a build-up series on. Bored&Stroked dropped all our jaws with a build up and hopefully we'll get to see that wrapped up and maybe we can even see some video action from him on the build! (hint, hint!)
    BTTT for 2008! Thank everyone for your participation and help keeping the catagories going!
  25. scootermcrad
    scootermcrad
    Okay boys and girls... bumpin' this up again.
    Anyone building a hemi this year? Post it up in the examples or post up a build sequence and shoot me the link and I'll make sure it gets added in the right places.
    Word has it that I just might be able to get a build progress on two 331's at the same time. Hopefully that will work out. I'll keep you guys posted.
    BTTT
  26. Ichoptop
    Ichoptop
    Mine is in the machine shop as we speak, getting the block and heads prepped. I dropped the new valves off friday so it should be done late this week or early next. Everything is built and/or bought for the rebuild and sitting in my office. Then my build up will start. It will be a moderate street motor, not to outlandish since it goes in a 2000lb bucket.
  27. scootermcrad
    scootermcrad
    If you have the time, PLEASE do a pic progress on the build! I'm more than positive that others (as well as myself) will benefit from it!
    Can't wait to see!
  28. Ichoptop
    Ichoptop
    this is my first hemi rebuild so I will be figuring out some stuff as I go. I have my best friend helping me do it who has played with a few hemis so I am sure we can get it figured out. I'll take some pix and write down as much as I can. By the way...it is a 1955 331 using a 354 cam.
  29. scootermcrad
    scootermcrad
    Sounds great! Do it! :D
  30. imperial
    imperial
    This I found on thehemi.com
    Did anyone here did this swap?
    Kenneth has discovered that by honing the lifter bores (***uming one needs or wants to) approximately 0.017 inches you can now use 1986 Oldsmobile roller lifters. Although this will require the alignment bars to be fabricated, or finding something that will fit. Kenneth is a machinist by trade, so was able to fabricate his own, and is also fabricating his own spring-style retaining device(s). These rollder lifters are considerably cheaper (approx $9 each) as compared to name brand aftermarket parts.
