help on welding cracks in fenders
Discussion in 'The Hokey Ass Message Board' started by frankieC, Nov 25, 2010.
  1. frankieC
    frankieC
    hey guys need help on welding cracks on 48 chevy fenders wher it roles under can post pics. tomorro
    F.O.G.
    38 sled
  2. fleet-master
    fleet-master
    hi there frankieC can you give more info as to what welding gear you have plz? Fatigue cracks should really be Oxy/acet welded to anneal the area concerned ,PB
  3. fordcragar
    fordcragar
    from Yakima WA.
    Pictures would help. Generally when you have cracks from fatigue, it's better to cut and replace metal. Otherwise you will develop cracks again next to the weld. But like everything else, it depends where the cracks are.
  4. strombergs97
    strombergs97
    It is also important to drill a hole at both ends of the crack.
    Duane.
  5. FatDaddy53
    FatDaddy53
    i agree u need to stop drill the holes first befor u start welding up a crack
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    If the fenders in question have a wire rolled into the edge you need to repair the wire first for a lasting repair.
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    I can't recall a post war vehicle that used a wired edge in the fender flange except a E-Type Jaguar bonnet.
    As fordcragar said- besure to cut out the metal surrounding the crack as there are several cracks in the metal you can't see, atleast until the vehicles' repainted and back on the road a few months!
    '' Humpty Dumpty was pushed "
  8. jcmarz
    jcmarz
    from Chino, Ca
    I repaired a couple of cracks on my Chevy ad pu. Not hard to do. First drill a small hole at the ends of the crack to keep the crack from spreading further. Then I used a cutoff wheel and opened the crack a little making sure that the edges were beveled. Then I welded them with a wire feeder a little at a time to reduced warped. Then grind the weld and check for any gaps. If gaps are found weld that area a little more. Grind again and if everything looks ok then clean the area and put a little bondo or lead. I always put metal prep before I put primer.
  9. frankieC
    frankieC
    thanks it's not a wire just rolled i have to cut it out and make a patch how do i make the roled part?????
    thanks
    frankie c
    38sled
  10. pimpin paint
    pimpin paint
    from so cal
    Hey frankie,
    dig around your shop or tool box for a piece of round stock or, perhaps a socket that matches the exact radius of the rounded flange. You may have to settle for something close, and fine-tune the shape with a hammer & dolly. Roll the flange on the end of your patch, and be sure to leave plenty of extra material to fully cover the area of the crack, plus a healthy margin, on each side of the crack.
    ''.........graffiti on the walls of history"
  11. nali
    nali
    I love this tip ..... I ll also try this.
    Thanks.
  12. frankieC
    frankieC
    thank you p p i'l try it and post pics!!!!
    PS i do most of my body work freddy flintstone styl any way (hehehe)
  13. chopolds
    chopolds
    from howell, nj
    Hey, Frankie...pimpin is right, but if the curve of the edge is pretty tight, and you can't just do a curve piece hammered over a piece of tubing, you can cut out a piece of 1/2 to 3/4" plywood to the correct curvature. Actually, cut 2 of them...one use a router, or just a disc sander to radius the sharp edges, clamp the metal between the 2, and hammer away. You can get the part just about perfect this way, if you cut the wood correctly!
  14. frankieC
    frankieC
    hey chop
    ike the plywood idea
    love the copper kart will you at the shows hext year!!!!
    check out my profile i'm doing a 38 pu.
  15. pimpin paint
    pimpin paint
    from so cal
    Hey Mark,
    A HammerForm is a great way to produce sheetmetal parts with complex shapes & forms, quickly & cheaply.
    Master metalshaper Ron Fournier has done some viedos & books on the subject.
    " Humpty Dumpty was pushed "
  16. rbradber
    rbradber
    from Choctaw
    I have a '35 Ford with dump rake spring tines welded in - perfect arc/fit.
  17. Mr48chev
    A few years ago one of the metal benders showed a photo of his set of dollys like this
    I made this one out of a piece of s**** flat bar and a piece of ****er rod that is about 3/4 in diameter but a guy could make up any size he needed pretty easy.
    I've got one rear fender for my truck that has a stress crack that I need to repair by cutting out a section and making a patch. I'd round the corners on the spot I cut out to lessen the chances of it causing another crack. Rear fenders usually crack because someone left off the brace from the fender to the frame.
  18. frankieC
    frankieC
    WTF is dump rake spring tines !!!!!!!!!
  19. 36 ROKIT
    36 ROKIT
    ^^^^^ Field dump rake is an ag. implement, pulled behind a tractor. Anybody have a pic for the city boys??
    Ingenious, rbradber!!
  20. frankieC
    frankieC
    hey 36 thanks for learning me!!
    got a farmer down the road think i'l mosesdown and see if he has any broken ones
