Fabric dyeing?
Discussion in 'The Hokey Ass Message Board' started by Jimmy2car, Nov 28, 2010.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    I have a reasonably serviceable interior in my 32 Tudor, but the fabric has been damaged by water and other items. Has anyone any experience in dyeing fabrics? The present color is a kinda light brown, and I'd like to make it dark grey, if possible?
    Thanks for any help
    Jim
  2. I have used the SEM Spray dye with great success.
  3. mj40's
    mj40's
    Sem is a good product and used it several times when I was in the furniture upholstery business. Their vinyl products work even better.
  4. I used it on fabric and vynil. The trick on fabric is to brush it in with a stiff nylon brush.
  5. i have just used the sem. i first used it on some seats. and i didnt like it. but i did use it on a smoothed out plastic dash and with clearcoat it did come out pretty good.
    i used that duplicolor interior vinyl die on my seats with good results. last a good while.
  6. t man is right about the brush. i just dyed a set of fabric seats as well and the brush helps alot.
  7. stev8
    stev8
    Do you brush before or after spraying?
    When its completely dry or straight afterspraying?
    I have some fabric to dye so this info could prove very helpful!!
    Good timeing!
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    Thanks all
    Where do I find this SEM stuff?
  9. i got my sem paint at a paint shop. your near me jimmy. i got it at B & Z autocolor. here in stockton.
    stev. i do both actualy. it helps to do it after cause it softens the fabric. after you dye it its pretty rought to touch. after you brush it it softens it up. but i brush it all one way, dye it and then brush it another way, then dye it. i found if you dont some of the old color is noticable when you move the hairs in the fabric. so brushing it before and after helps. now its soft and cant even tell my fabric seats used to be khaki
  10. Jimmy2car
    Jimmy2car
    from No. Cal
    Hooligan, I'm up above Sacramento. Guess I'll try a few paint places, thanks. Do you spray this stuff, or brush it on?
    Thanks
