Looking for detailed I6's
Discussion in 'The Hokey Ass Message Board' started by low-n-slo54, Nov 29, 2010.
  1. low-n-slo54
    low-n-slo54
    I am looking for pictures of detailed sixes. don't care what make or model just nothing stock. I need to see chrome, custom paint, the works. I've done a search but not finding anything that i don't have to look at V8's . Might not be using the right terms. Or if you know links please post. Thanks!
  2. plym_46
    plym_46
    from central NY
    search inline 6 and flat head 6, there are two long threads
  3. Flipper
    Flipper
    from Kentucky
    Elagantly simple.
    It was in this car
  4. low-n-slo54
    low-n-slo54
    that is simple and well thought out.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    Check out my Peter Beater in my picture albums. The ol AMC made more torque than a dumptruck and looked cool doing it.
  6. low-n-slo54
    low-n-slo54
    That is cool Flathead!
  7. gmc_52
    gmc_52
    Here is my 235.
    Thomas
  8. sololobo
    sololobo
    Hot Damn, two shown two out-f'n-standing engines. Man is that lil red Chevy some tasty puddin. Love it, super less is more example. That bumblebee on the stand is super cool. Great tu-toning bro. Thanx for your posts ~Sololobo~
  9. low-n-slo54
    low-n-slo54
    Yeah really. Thanks for the great posts!
  10. dmw56
    dmw56
  11. t.canter
    t.canter
    call this a mini tribute to a really sharp old guy who sadly p***ed away before he could complete this 52 (used to be mine). this motor blew me away when i saw it. check out the intake.
  12. low-n-slo54
    low-n-slo54
    Ahhhh T. Canter! That flaked intake is killin me!! And DMW, damn that thing is cool. These are all giving some great ideas. Keep 'em coming.
  13. OL-54
    OL-54
    First shot is a Dad's 235 Chevy in a 41 Nash, next two is my 235 in my 54 Chevy
  14. low-n-slo54
    low-n-slo54
    I'm diggin that! I am about ready to start detailing my '54 235 and these hit the spot!
  15. sixinarowjoe
    sixinarowjoe
    from eastcoast
    the 59 235 in my 51 coupe project
  16. 1952henry
    1952henry
    Very nice! Those are early Chevy air cleaners, correct?
  17. cruzingratiot
    cruzingratiot
    from Detroit MI
  18. LowFat48
    LowFat48
  19. low-n-slo54
    low-n-slo54
    I'm glad I posted this thread. Thanks for the link Lowfat48!
  20. BOWTIE BROWN
    BOWTIE BROWN
    interesting, very interesting.
    thanx
    "AND THE BOWTIE ROLLS ON"
  21. sixinarowjoe
    sixinarowjoe
    from eastcoast
    yes they are.-thanks
  22. fat141
    fat141
    Can we see some (lots) more of this little gem please?:cool::cool:
    Rod
  23. fat141
    fat141
    O K, what happened to the pics, not even in the original post by Flipper?
    Now I got no pics at all to drool on.
    Rod
  24. Flipper
    Flipper
    from Kentucky
    These are the only other ones I have of it.
  25. Powerband
    Powerband
    That 51 Stovebolt is just right. Plenty of cool-hot sixes at FSP'
    http://fordsix.com/forum/
    250 performance six:
    '61 T'Bolt Six:
    Blueprinted D6DE Ford 250 Six; Jahns Racing cast pistons at @ 10:1CR, Clifford Shot Peened and Balanced Rods, Clifford 272H Cam, Line Bored & Balanced Bottom End, Torque Plate Machined .070 Cylinder Overbore, Sealed Power moly rings, Clevite &#8220;77&#8221; tri-metal main/rod bearings, FE Chrome-moly pushrods, Stainless steel 1.88 intake valves/1.50 exh with- silicon springs and HD retainers, Ported and Polished chambers and relieved valve shrouds . Cloyes timing set, Melling blueprinted HP oil pump, Clevite Anti pump-up lifters, Fisher custom Harmonic Balancer, Offenhauser Tri-Power 3X1 aluminum intake manifold w/ Offy progressive linkage, Modified Holley 1904 series gl*** bowl carbs w/ K&N air filters, Exhaust ¾ siamese port divider, Re-Curved Duraspark electronic distributor, GM HEI ignition trigger, Indexed Champion racing spark plugs, Br*** expansion plugs, Glyptal sealed engine block, Detroit hipo gasket set, Clifford blueprinted racing engine oil additive, Polished aluminum alternator, timing chain cover, thermostat housing, water pump and PCV., Matte black/alum. 6=8 Clifford valve cover. SFI 157 neutral balance-lightened racing flywheel spinning Centerforce Stage II Clutch, T5-Z Cobra 5speed ******, Short throw Hurst Indy shifter, 8&#8221; 3.80:1 TracLoc Posi rear, Shelby Traction Masters and sway bars, Mustang front strut bars, Scarebird Disc front brakes, Fabricated subframe connectors and crossmembers, 8 Point Roll bar, 5 point Safety Belts, Mustang 5.0 alum. racing radiator, Perma-Cool electric pusher fan, Holley fuel pump/pressure regulator, ****** 6602 dual out longtube headers, Smithy silencers, Original tube radio and vacuum wipers and front fender Gunsights&#8230;<O:p></O:p>
    The Sixth Sense Garage
    "I never want to see another 350/350 setup with an Idididiot..."
    HAve Fub
  26. Jimbo302
    Jimbo302
    from Micronesia
    Same here. Great looking 6'ers.
  27. Tell me about your road draft/PCV setup Looks interesting.
  28. Little Terry
    Little Terry
  29. low-n-slo54
    low-n-slo54
    All this inspiration! Can't wait till spring.
  30. gmc_52
    gmc_52
    It came off of a GMC military 302. It has a oil bath filter in the housing that filters the air before it goes into the crankcase. It also makes filling the engine with oil a little easier.
    Thomas
