Model A spring mounts on '40 rear...
Discussion in 'The Hokey Ass Message Board' started by PeteVS FP NJ, Nov 18, 2010.
  1. PeteVS FP NJ
    PeteVS FP NJ
    How many ways are there to mount a Model A spring on a '40 rear (directly over the axle centerline?) I've seen Tim Ayer's, but I'm not sure that the parts are still available and the welding looked kind of substantial. Anyone got pix and a description of what they've done? Thanks!!
    (Come to think of it, has anyone ever stretched an 'A' frame and moved the crossmember behind the axle and used the stock '40 mounts on the axle housings? That might eliminate Z'ing? Would that create m***ive body headaches?)
  2. dsiddons
    dsiddons
    from Indiana
    You can stretch the frame and run the spring behind the axle. Either way you need to z it.. Same amount of work with a different spin. Note: You can't really run a quick change with spring behind axle.. Something to think about.. Good luck..
  3. trmel3
    trmel3
    from new jersey
    check with chris here on the hamb. he did an excellent conversion with all ford parts
  4. dsiddons
    dsiddons
    from Indiana
    I agree! He is one of my favorite A bone builders..
  5. i've recently done mine, here's a few photo's
    don't worry, the welded leaf spring is only for mock up purposes while i wait for a proper reversed eye spring.
  6. flatford39
    flatford39
  7. PeteVS FP NJ
    PeteVS FP NJ
