Flathead 6 goodies! Intakes, heads etc....
Discussion in 'The Hokey Ass Message Board' started by drillmastertommy, Aug 4, 2010.
  1. I am oh so near to getting my Plymouth PT81 pick up on the road over here in the UK and after spending countless hours surfing these and other pages for hop up parts to go on my 218 flathead 6 I thought I would put up a couple of pics of what I have got so far and hopefully get others to show off their tricked up flat 6's aswell.
    I am still working on the engine sorting my oil filtration etc but my most recent aquisition was the most stunningly gorgeous dual intake from Earl of Edgy Speed Shop aswell as some of his finned valve covers, oh yeah and he has just emailed to say my finned high compression head is ready!!!
    One gorgeous intake!
    IdahoBlueskies website has been a m***ive help and inspiration, I have lost count of how many times I listened to his car on youtube, gorgeous.
    So what you got????
    13 likes this.
  2. Car, engine thats in it at present & engine to go in it......eventually..........andyd
    13 likes this.
  3. Very nice ride and it's nice to see an Edgy head the same as one I have en route fitted up.
    Did you split the original exhaust manifold?
  4. Eddiecus
    Eddiecus
    from Norway
    I have one to:) I will take some pictures of the parts and post here later.
    I dident know that earl makes intakes, it sure looks real nice.
  5. Cool stuff, be sure to get those pics on here and c'mon people, surely there's more of you that have a tasty flat 6 you want the world to see.....
  6. plym_46
    plym_46
    from central NY
    A couple others
    Chrysler 251
    mine 230 dual stock carbs on fenton intake.
    13 likes this.
  7. Anymore or have all the flatg 6's gone into hibernation?
  8. moose
    moose
    We're not in hibernation just yet! Met/saw a few at the Ty Rods show today. Hopefully at the Alter Boys next week we can have an all Plymouth flathead display--there may be 4 or 5 at the show, and I'm only bringing 2! These are mine:
  9. choptop4
    choptop4
    Hows this?
    13 likes this.
  10. Sweet! The moose manifolds are pretty insane, would be interesting to hear a flatty running with them.
    What can you say about the F head (***uming I'm right in identifying it), amazing engineering, am I right in thinking that Earl has and will only make 3 of these? I read it somewhere on the reliable internet.
    Got mine fired up for the first time last week with all my Edgy bits inc new head and split manifold going into a pair of Smithys, sounded amazing!
  11. hkestes
    hkestes
    Here is my 218 with Offy intake, Carter/Webbers and Fenton Repop Cast Iron Headers. Just received my Edgy Head but am holding off until I have the .030 over 230 done to replace the current 218.
    13 likes this.
  12. D_Lazaris
    D_Lazaris
    from So. Cal
    Here is my Edmunds Head/Intake for my Nash straight 6
  13. Wow..all these motors make me want to pull the 340 and go back to a flat 6 in my Mopar!!!!!!!!!!!!
  14. RichFox
    RichFox
    Somebody on here mentioned they didn't know Earl (Edgy Speed Shop) made an intake. I also have seen the Hilborn type fuel injection he casts for Chrysler Spitfire six cylinder motors. Beautiful casting. Every bit as nice as one of Hilborn's castings. Works well also. If your building an all out MoPar.
  15. [​IMG]
    In my '46 Ply coupe- '59 Dodge 230, punched .030, custom cam, Sharp aluminum head, Edmunds intake w/2 Holley Webers, tube headers. Soon to be installed- Mallory dual point dizzy.
  16. Earl's cams are excellent. He re-ground the cam from the '55 dodge flatty I have in my '39 coupe, 'gives plenty of hp & torque. Motor details; 230 punched .060, Egge pistons, Fenton aluminum head, Langdon headers, Edmunds intake w/2 carter carbs.
  17. BrianInPa
    BrianInPa
    from Milton
    What transmissions are you guys running behind your flatheads?
    I have a 1940 Plymouth sedan with the original 201. I would like to swap it for a 230, or better yet, one of the larger Chrysler 6's.
    However, I'm just beginning to look into this swap, and I don't have any idea at this point which transmission and rear I should use.
    Any help would be greatly appreciated.
    BrianInPa
  18. plym_46
    plym_46
    from central NY
    Couple folks make adapters to us a S10 mustang 5speed. Rear ends out of Jeep Small Cherokees, Mopar B bodies, rangers, mazda pickups, exploders, all work with relocation of the spring mounts.
    I have a friend with a 5 speed od and a 3.55 B body rear end, 70 is right about 2K rpm.
    A 4speed A883 OD used in volares, vans and pickups, and some 6cyl GM truck applications is another possibility but you would need to do the adapter stuff o your own.
  19. rob-redm
    rob-redm
    My Ford Six ! The air cleaners have to go ! Head bolt dress up caps to come.
  20. john2kin
    john2kin
    from new york
    hmmm this is interesting my friend and i agree with you what you said .. :)
  21. Just like some of you, Blue skys blew my mind. After seeing and hearing it run. Who would want a v8. I have a 1951 Desoto Hilo sampan. It's taken two years to find Earl Edgy, as soon as I did I ordered a head. I found some headers, and had them jetcoated. New side plates, and a Langdon electronic ignion 12 volt. A few more parts like cam and carb or carbs and it will be ready to install into my sampan. I also have a 1952 plymouth over drive transmission in it now. It makes cruising so much easier. With a warn out engine I'm still able to drive it a 65mph at hwy speeds, and get 22mpg hwy. Can't wait to get the new engine in and run it down P.C.H. Highway.
