Has anyone installed fenton cast iron headers on a flathead v8 in a Model A ch***is. Will they fit? Thanks.
Thanks for the reply 8-track. Which side is tight drivers or p***enger? I am going to be using Model A rails. I wonder if they are narrower? thanks again. Vic
I recently loaned a set of fentons to a guy that has a 29 roadster AV8 to try on for size. This car was built fairly close to the spec's in the Tardel book and used a F1 steering box. P***enger side fit, drivers side didnt. Not enough room to clear the steering box.... Your results may differ... T
The starter side is a 1/4 inch from the boxing plate, the firewall is not cut out, fits nice and snug.
Thanks Tim and 8 track I had sent Vern a note earlier tonight asking about these questions. Thanks again for your input. Vic
