Need ur chop opinions!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by 55CadillacTed, Dec 2, 2010.
  1. 55CadillacTed
    55CadillacTed
    i want a mild chop on my 55 Cad.
    Most chops on a 55 Cad are lowered equally in the front and rear then the rear gl*** is leaned forward.
    I do not want to chop the front, and chop the rear only 1.5" so there's a very slight slope (see picture where i taped the stainless in its new potential position).
    Then lean the rear gl*** to get rid of that big crown at the rear of the roof, giving the roof line a better slope.
    What do you think?
    NOTE: the picture with the most chop looks pretty goofy until i lower the car.
    I'm also thinking of chopping the fins off and giving the rear fins the same slope as the roof. If done well, i think the whole car will have a great flow.
  2. psyco50
    psyco50
    from Pomona,ca
    Damn dude, why would you go thru all that trouble just for a 1 1/2" chop, Hack the **** out of it, make it worth the work. I would get that front gl*** shaved down, pull the roof forward after you modify the lip and all that sheet metal around the front gl***. and chop the 'C' Pillar lower per your desired slope, lean the rear window in, and re-panel around the rear gl***. Having to re-panel the rear, you shouldn't have to do a cross section, Just my humble opinion. It looks easy to do..
  3. 52RustRocket
    52RustRocket
    Cutting the fins off of a Caddy?.....OUCH!!
  4. 55CadillacTed
    55CadillacTed
    i guess i'll post it this way:
    which chop do you like:
    no chop, mild chop, or full chop
    (i know, she desperately needs to be lowered also)
  5. KaddyKimber
    KaddyKimber
    from Denver, CO
  6. go with your original idea.... all the way. mild chop in back of the roof, and cut the fins off(i'v wanted to do this for a while on a caddy). I've always wanted to do the same chop on my 56 buick too. It's not meant to make the car look chopped, it's to make it look "right" ...The factory got it right in their drawings, but messed up the production models for sake of extra headroom.
    Mild chop
    Rocco
  7. psyco50
    psyco50
    from Pomona,ca
    Here you go, I found this chopped 55 Caddy pix online, Scalp that ***** :cool:
  8. sling shot
    sling shot
    go no chop or all the way
  9. Mild better than mega for me.
  10. kingpins
    kingpins
    exactly! why go thru that much work for a 1 1/2!!!
  11. chaos10meter
    chaos10meter
    from PA.
    If your going to chop it don't be shy.
    You need just enough side window left to throw a beer can out or a cop to hand you a ticket. **** when I was done I didn't have enough space left to mount one of them trafffic signal viewers on the dash.
    (kidding, kidding , kidding, don't get your ******* in a wad)
  12. Hdonlybob
    Hdonlybob
    I like your original idea...mild chop...ditch the fins = cool ride, and YOUR idea and $$$
    Go for it...
  13. mlagusis
    mlagusis
    I think the third pic looks the best. The back window is too steep stock. If you chop the back only it will smooth out the lines with out having to mess with the front window. Most people probaly would not even know it was chopped. Go for it!
    also, if you cut off the tail light bulges, i think 54 Packard tail lights will look good.
  14. metalshapes
    metalshapes
    Because a mild chop can look so much better.
    And it takes a lot more guts to do one.
    On a mild chop you do the same amount of work for a subtle change.
    To clean up the lines and make it look better.
    That is a lot harder to do than chopping the **** out of a car, and make it look like a skateboard ramp....
  15. Gator
    Gator
    from Statham Ga
    That looks like ***.
    One of the best looking custom Caddys out there is Nadine, and IIRC it's got a 2 inch chop.
  16. ironandsteele
    ironandsteele
    i vote no chop on that car, but that's just me.
  17. ClimisCD
    ClimisCD
    Mild chop front and rear but be careful with the fins. Chopped and sloped, they may expose too much of the thrunk.
  18. 55CadillacTed
    55CadillacTed
    chopping the fins:
    my thought was to cut the fins off with a single cut.
    then get a block of wood and shave it into the shape i want for the new smoother fin.
    Paint it and hold it in place and see how it looks.
    If i don't like it i can weld the original fin back on.
    If i do like it i can shape the new metal around my wooden mold.
  19. 49ratfink
    49ratfink
    Caddys from that era are cl***y... IMHO nothing needs to be done to them to be cool.
    as seen here, it is very easy to seriously mess one up. [​IMG]
    I like the idea of a mild chop... just enough to smooth out the profile a bit. way too many cool cars have been destroyed by people with no vision for what the end result will be, they just want to be radical like thier rockasilly buddys.
    not really feeling the lose the fins idea. wouldn't look too bad but not something I would do.
  20. Billa212
    Billa212
    from Milwaukee
    I like the 1.5"... I agree with metalshapes - the slight chop cleans it up a lot. I also vote to ditch the fins or smooth the lines somehow, I dunno they always seemed like an afterthought to me
  21. Looks like someone dropped a shipping container on that Caddy
  22. Woob
    Woob
    from Falcon, CO
    A subtle, tasteful chop can clean-up the look of certain vehicles. As a matter of fact, you're probably better to go mild than wild if it smooths the lines... I like a radical chop in the right application, but everything doesn't have to be so "in your face".
    As far as the fins are concerned, I think you should cut them off and send them to me.
  23. Mr48chev
    There are probably more cars with that style of wraparound windshield sitting in junkyards or back yards with a half finished chop that the owner either couldn't get gl*** to fit or stay in without cracking or couldn't find a gl*** man who would cut the gl***. And if you haven't checked, they gl*** guys charge you full price for every windshield they attempt to cut and have problems with along with the price of the one that finally gets in the car. I love chopped Caddy coupes and one of my good friends has one of the nicest pre wraparound windshield ones in the country but you had better find a guy who is willing to do the gl*** before ever starting on a chop on that car.
  24. SixFive
    SixFive
    Here's one that doesn't look like it has been stepped on...
  25. J scow
    J scow
    from Seattle
    Go all the way but you have to bring that front windshield down with it or you might as well leave it stock. IMHO
  26. old_skool_1953
    old_skool_1953
    No Chop!!!! Caddy's are sweet as is.
  27. zman
    zman
    from Garner, NC
    Yep....
    mild or none...
  28. I am biased. Mild chop all around with about 3/4 " more taken out of the back. Here is some eye candy and my blue parts car. PLEEEEEASE don't cut the fins off.
  29. ffr1222k
    ffr1222k
    I vote no chop..
