Stromberg 48 vs 97
Discussion in 'The Hokey Ass Message Board' started by BanjoBoy, Dec 3, 2010.
  1. BanjoBoy
    BanjoBoy
    Anyone know what the main difference is? Read the threads and seems the 48's get a little more cfm.
    Im running a Flatty with 4" Merc Crank (276cid) , Weiand Cheater Heads, Potvin 3/8 Cam,
    Any help is appreciated. All opinions welcome. Thanks guys
  2. hrm2k
    hrm2k
    48 = 180CFM
    97 = 155CFM
    We have several really knowledgeable guys on the board. You can direct your questions to UncleMax, ****ster27, Stromberg97.....I know there are others but just had a senior moment
    bikerlaw likes this.
  3. jetmek
    jetmek
    my 276 runs best with 97"s and stock jetting. thaTS A 2X2 SET UP. 3x2 you mite get away with a 48 on the ctr carb
  4. 1952henry
    1952henry
    Stock--.046 jets and #63 pv for a 48, .045 jets and #65 pv for a 97. 97s have two settings for the accelerator pump lever, unless they have been *******ized. Ford actually advertised the 97 as an "economy carburetor" when introduced in April of 1936.
  5. V8 Bob
    V8 Bob
    All my info states the Stromberg 48 had stock #48 main jets, with 1 1/32" venturis, while as stated, the 97 uses #45 jets and has 31/32" venturis. Most agree the "48" name is from it's jet size, while the "97" comes from it's venturi size of .096875, or .097.
    joel and 31ster like this.
  6. uncle max
    uncle max
    Actually, the 48, when first introduced, took it's name from the '34 Ford Parts numbering system, which all began with 48. 48-**** and so on. (jet size was coincidental).
    I sometimes build "hybrid" 48's... Using 97 style airhorns with the detent, and 97 style throttleshafts with two adjustment balls for easier tuning.
  7. V8 Bob
    V8 Bob
    Hi Max,
    I don't remember ever seeing the reference to 1934 numbering system concerning the 48 carb, but it makes perfect sense! Thanks for the info. Just one more "myth" corrected! :)
  8. V4F
    V4F
    from middle ca.
    if you have a 97 , i would try it first . 48s are the biggest . then 97 , then 81 . . steve
  9. strombergs97
    strombergs97
    What intake are you using how many carbs. With the build of your engine, 3x2 would work great with three 81s and running non-progressive linkage..With a basic formula of 1.5 CFMs per CI your engine could handle 400 + CFMs..Three 81s is about 420 CFMs, sounds like a good match to me..
    Duane..
  10. BanjoBoy
    BanjoBoy
    Running a Hexagon 2 x 2 Intake if it helps
  11. 1952henry
    1952henry
    My mistake.
  12. ct1932ford
    ct1932ford
  13. model.A.keith
    model.A.keith
    http://www.jalopyjournal.com/forum/group.php?groupid=269
  14. strombergs97
    strombergs97
    Hello..Run two 97s non-progressive. I believe two 48s would be better..
    Duane.
  15. BanjoBoy
    BanjoBoy
    I was told to run 2 48s for the added cfm
    Using a hexagon 2 x 2 intake
  16. BanjoBoy
    BanjoBoy
    thanks for all the input guys
    I was told the hexagon intake feeds cylinders in a different way than most flathead intakes. Just trying to turn stones and get some info.
    All info is appreciated
