Lowering '51 Chev Rear - U Bolts Source?
Discussion in 'The Hokey Ass Message Board' started by Jeff51, Feb 24, 2005.
  1. Jeff51
    Jeff51
    from Pullman WA
    I was going to block the rear to lower it some, but I'm not sure where to find longer versions of the flat-bottomed u-bolts that hold the stock axle to the leaf spring - any ideas? Doen't sound like something I ought to make out of all-thread....
  2. happy hoppy
    happy hoppy
  3. ric
    ric
    I bought some for 3-4" blocks at local parts house, I believe Dorman makes them.
  4. JamesG
    JamesG
    When I bought my 4" blocks from Chevs of the 40's, they came with the longer, correct u-bolts.
  5. slammed
    slammed
    Frame and axle shop's. Call a few.
  6. wiseguy
    wiseguy
    from Seattle
    Shucks has them i saw them here in seattle yesterday.
  7. Jeff51
    Jeff51
    from Pullman WA
    Cool, thanks guys. I live in BFE so nothing is readily available - appreciate the help.
  8. Rhino
    Rhino
    from ST. Louis
    The guys that do alot of off the road stuff have them on there 4/wheel drive trucks, they just go the other direction! I picked up a used set at a swap meet last weekend, 10 bucks, 3" block, extra long U bolts.
  9. OldSchoolObee
    OldSchoolObee
    I've used BRS kit, it can be had with or without blocks, plus it centers the axle,if you are using stock springs....:D
  10. OutLaw
    OutLaw
    I took an origonal one down to my local spring company and had them make me some 4 in longer for about 15 bucks.
  11. Aaron51chevy
    Aaron51chevy
    Do you run stock size tires? I want to 4" in the back of my 51 chevy but wasn't sure if i'd get tire rub or hit anything going that low.
    Thanks
  12. OutLaw
    OutLaw
    You should have plenty of room I was running 235/75/15 and diddn't rub on ant thing...but my rear axle ( 9in ) on deep pot holes would come up and smack the frame.
    Krupanut has 4inchers and dosent have a problem with his tires either.
  13. krupanut
    krupanut
    No problem with the tires but I do smack the frame on sometimes.
    Regularly with people in the back seat.
  14. JamesG
    JamesG
    Stock tires.
