Hot Rod A - 4 Speed or 5 Speed?
Discussion in 'The Hokey Ass Message Board' started by Tommy R, Nov 30, 2010.
  1. Strange Agent
    Strange Agent
    4-speed is the obvious traditional choice, and you already have one. Do that.
  2. Mattilac
    Mattilac
    Seems to me most of the 4 speeds out there are stronger than the 5 speeds until you get EXPENSIVE.
    Plus I like 4 speeds.
  3. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    I had a S-10 5 speed in my 28 roadster on deuce rails, 327 sbc w/325 hp, 350 geared 9" ford. It ran high 13's, did crazy cool burnouts and got 25 mpg. The guys I travel with can't seem to drive under 80 so it was the only way I could keep up and still have fun stop lite to stop lite. Drove that car about 4 years beat the snot out of it and the trans never gave me a bit of trouble. As long as your not running a sticky tire and it doesn't hook-up there fine.
    I have a Richmond Super T-10 4 speed in my 40 coupe with a 300 hp 283 and 350 gear'd 9" and am seriously thinking of changing it to a 5 speed this winter. This car is considerably heavier so I will use a World Cl*** T-5 with an S-10 tailshaft. Just my 2 cents worth. Gary
    pecker head likes this.
  4. cooger
    cooger
    listen to Gary.. I have a 55 with 3:70 in it-had a wide ratio Muncie, fun alright but the thing was buzzed up 3g's at 70 and I was getting blown off the freeway by everything (live in Texas where 'dillers do 60) Put a t5 in it, still pretty fun (first does ****) but will haul at 80+ and not worry about Granny giving me the bird. Milage is good.
    cooger
  5. el Scotto
    el Scotto
    from Tracy, CA
    Hahahaha!!!! :)
  6. pitman
    pitman
    Lighter the car, the fewer the gears needed. I often skip gears when its too many intervals, to get up to speed.
  7. I run a T5 in our roadster - flathead powered. First gear is a little short but low RPM on the highway. It's a stock "non world cl*** box" from a S10 blazer six banger. Very happy with the set up - I'd do it again. By comparison, our flathead powered '36 sedan is a stock 3 speed and its gets winded on the highway.
    And another idea, we just put a T56 in my sons '90 Chevy truck and thats a sweet set up too. Maybe overkill but what the heck?
  8. OneBad56
    OneBad56
    the HRT originally was a three on the tree, but the engine I bought came with a C6 autobox.
    I have decided to go back to 3 pedals.
    I have a dual quad 429, so it was going to be a 4 speed toploader.
    However, a complete toploader conversion, new, was the same price as a tremec tko-600 with a hydraulic clutch.
    I ended up installing the 5 speed becuase of the friendlier first gear and the .64 fifth gear for the highway. Instead of doing 3200RPM at 70 on the highway, I will now do 1800RPM with lots of room to accelerate or drop it down into 4th. I do lots of highway driving.
    Around town, 4 gears only needed, when cruising, one gear only.
    BTW, not too many used toploaders come up for a 429, and when they do, price is the same for a new one. New comes with a warranty.
  9. TDWZ28
    TDWZ28
    from Michigan
    I just went through this. I put a lot of research and thought into the trans I wanted to run. The build is a 34, 2dr sedan. Light-wieght car. 392 hemi, hopped up. 3:90 rear. I checked into almost all the new transmissions that are for a street car. That would be Liberty, Autogear, M22 Muncie (which I run in my 500 HP Nomad with a 4:11), Richmond , and so on. I decided on the Richmond Super Street, 5 speed overdrive. It's all American made, has a 2:89 first gear (good for out of the hole), a 0.77 final ratio. Rated to a little over 500 HP, which is where I am pretty close to now. This trans should be the cats *** for what I want. I figure the overdrive will be pretty slick, if I ever need it. I doubt the car will be in 5th too much.
  10. jamesgr81
    jamesgr81
    56 Chevy. Got Richmond 5 speed with 3.08 12 bolt in the back. Engine is 454 BBC. Love the reduced RPM at speed. 4000 rpm at 70 mph ****s.
    Your cars is lighter so strength is not so critical unless you are serious at drag racing. In my 56 a Saginaw wouldn't last one p*** and a Muncie is too valuble to blow up. I left a cluster laying halfway down the strip at Pomona.
    Why would somebody give a **** how many speeds you have but you? Tradition is building cars the way you like. IMHO a 4 speed is old news - build something using better available technology and save gas and wear and tear to boot.
  11. buzzard
    buzzard
    Alliance Member
  12. Greasy64
    Greasy64
    Real simple to me! 3.50 gear (that you have), a Saganaw 4 speed (that you have), in a light car with a SB Chevy turning a tall tire on the street?? That sounds like a fun ride to me. Bolt that all together and gimmie a ride in it next year at the Roundup!!
  13. Tommy R
    Tommy R
    5.0 gear?!? Damn, dude! And you're only running, what, 26-28" tires? Can you break the speed limit in a school zone? ;) Yes, I have two chunks, but I'd want to rebuild them first, a 3.50 and a 4.11. The 3.50 is in better shape and could likely be run as is. I appreciate the input. Maybe you could show up to one of the Monday night get togethers and I could bribe you to give me a ride? :)
    I wish I could have it done by the Round Up! Tell ya what, I'll give you a ride at the '12 Round Up. It should make that one. :)
    Regarding comments about the T-5.... Initially, I'd run a stock S10 trans, but would eventually upgrade to World Cl*** T-5 guts. I've got plenty of experience with T-5's and would be fine with it's strength since a good friend would build it for me and he's got a proven track record.
    Is there much commonality between the Saginaw or Muncie and the T-5 with regards to length, inputs/outputs, bolt pattern, mount location, etc.? I'm curious how much work would be involved in a retrofit from a Saggy to a T-5.
  14. Retro Jim
    Retro Jim
    A Hot Rod is only good with a 3 or 4 speed . The rest are for wimps !
    I like both 3 & 4 speeds but prefer a 4 speed . I have a 3 speed that I am putting into my 50 Ford and looking for a 4 speed for a g***er build .
    Anymore gears is just a wait of time !
    Retro Jim
  15. Tommy R
    Tommy R
    I appreciate everyone's input on this. I've been giving it a lot of thought and have been crunching a ****load of numbers. I think I'm going to stick with my original plan to run the T-5. With 4.11's, it'll let me cruise the highway at 75-80 turning just 2500 rpm. And it'll also have a deep enough first gear that it'll launch hard at the strip when I run it on slicks.
    Fortunately, a friend of mine is a very experienced T-5 builder and drag racer so I'll have him go through it before I put any real power to it. So it looks like I may have a Saginaw setup for sale soon and I'm on the lookout for a Camaro WC T-5 and an S10 tailshaft.
    Does anyone know if the Saginaw and T-5 would use the same GM bellhousing? I've got the one that came with the Saggy and will keep it if it's usable for the T-5. Thanks!
  16. SinisterCustom
    SinisterCustom
    Ever hear of a Muncie M-20???;)
    That's what' going in my T with a 3.27 rear gear....
    Find someone with a similar combo that you wanna run and go for a ride....that'll be a better indicator than "crunching" a bunch of #'s....haha
    Don't Camaro T-5's mount "canted"???
  17. 1971BB427
    1971BB427
    from Oregon
    You could always go with the 5 spd., but use a custom shifter that has a more traditional look. Your car is light enough that it wont care what ****** you put in it to perform well, so it's more a matter of what type of driving you'll be doing most.
  18. Tommy R
    Tommy R
    Yeah, yeah... ;) In all honesty, I still have time to change my mind. And I'm hoping before I *have* to make a decision I can ride in a car with a 4 speed and get a better feel for it.
  19. bscottstudio
    bscottstudio
    from Kansas
    There is an old trick that I don't believe has been mentioned yet. There was an article 20or so years ago in Hot Rod Mag. about combining a Saginaw 3-speed OD trans from the mid to late 60's with a Saginaw 4-speed. It involved swapping tail shaft housings and few other things. I would have to really search for the info.
    It gave you a 4-speed with OD. Now with that being said I am not sure how well it would live when drag racing. But it would be just as strong as any Saginaw.
    I happen to have a 3-speed OD Saginaw we took out of a 1967 El Camino with cables, switch and wiring. We took this out 20 years ago with this swap in mind but have never done it.
  20. Window Licker
    Window Licker
    im running a sbc with a t5 3.55 gears and 7.50-16 tires. i pretty much never use first, but i am very happy with the ******, i do great on the highway. i cruise 80-90 mph everyday on the way to work and back and do great on gas.
    the only regret i have is not changing to the 2.95 first.
  21. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    For a traditional hot rod I would go 3 or 4 speed. For a street rod/custom a World Cl*** T-5 would be a nice setup and they are pretty cheap still since there are so many around.
