55' Chevy "GASSER" Build UP... Yeah, another one
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Apr 10, 2010.
  1. Chopperman
    Chopperman
    seats are pro car from summit. I removed the headrests after a very nasty bucket seat bashing i took on the board.
    Not ideal or period correct seats, but i like them. Soooo :cool:
  2. Chopperman
    Chopperman
    I need one of these
  3. Mr. Jean
    Mr. Jean
    Yeah, don't we all.;)
    Sorry to see the damage. Best of luck getting it up and running soon.:cool:
  4. leroys85coupe
    leroys85coupe
    from usa
    ok they look great man.
  5. Paul Y
    Paul Y
    Not sure of your budget but this looked like good value if you wanted to put it together yourself.
    http://ohiocrank.com/chev_bb_shortb.html
    Think you might need to upgrade the rear end though....
    Feel for you, nothing worse than breaking your car when you have a family demanding feeding...
    P.
  6. Chopperman
    Chopperman
    pulling it down tomorrow.:D
  7. Chopperman
    Chopperman
    Cast iron chunkies in the intake. Not looking good for the heads
  8. swade41
    swade41
    from Buffalo,NY
    Man what a crusher, you just were starting to have fun with it too.
  9. Chopperman
    Chopperman
  10. ***Area-51***
    ***Area-51***
    from Ohio
    Thats not a good! :(
  11. 55chevr
    55chevr
    Guess you shut it off when it started smoking?
  12. Chopperman
    Chopperman
    anyone know anything about 454 motorhome engines?
    I have a line on a 78' 454 with under 10K miles for CHEAP. Looks like they come with a 4B main and steel crank. This might be my cheap ticket back on the road.
    Getting numbers to validate before I go ou tot look at it.
  13. jakedmoe
    jakedmoe
    they have beafier rods too, i think they might have cast pistons though not good for blowers. and it sounds like you drive it like its stollen lol (as would I) something with good pistons and rings sounds ideal for you.
  14. Chopperman
    Chopperman
    Guy sold the engine while I was heading out there to look at it.
    I either need to go the used CL route or throw big money at it.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Have to ask, what exact stupid stuff did you do for that to happen?. Float the valves, drop a valve, to much blower. Hell I almost sent my rearend to the s**** yard in Hollywood last night missing around with my buddy Brian with his 30 coupe. Seemed we got cought up acting out American Graffiti.
  16. Chopperman
    Chopperman
    stop light racing by myself. :D Honeslty I don't know why the engine blew other than a combination of things including the the wrong long block in the wrong application.:cool:
  17. benchseat4speed
    benchseat4speed
    from Golden, CO
    Thats a sweet 55, looks great man. The rearend destruction was awesome, made some cool trohpys. The engine not so much, I'm very sorry to see that. Both were bound to happen tho...stock cast piston 454 and a stock chevy dropout would never live with that blower. Dana 60 out back and forged everything up front.:cool:
  18. Baron
    Baron
    Unfortunately,there are no cutting corners when building a blower motor. Good crank, rods and blower pistons are a must. Not cheap, but either is doing this a couple times. If you think about it, it is a minor job compared to all the work you have done building this car. Good luck with building the new motor.
  19. 51 Hemi J
    51 Hemi J
    How did the Heads look?
  20. Chopperman
    Chopperman
    bent valve in one cyl
  21. Chopperman
    Chopperman
    Looks like I'm pulling the trigger on this.
    http://http://www.speedomotive.com/ps-196-56-chevy-496cid-800hp-street-rod-blower-stroker-engine.aspx
    ***EMBLED LONG BLOCK 800HP
    GM 454 4 BOLT, CNC MACHINED & CLEARANCED BLOCK
    NEW FORGED STEEL 4.250" STROKER CRANKSHAFT
    FORGED 4340 6.385" H-BEAM CONNECTING RODS
    JE FORGED PISTONS 8.5-1 WITH 119cc OPEN CHAMBER HEADS
    JE PLASMA MOLY RING SET
    CLEVITE H SERIES ROD AND MAIN BEARINGS
    BALANCED INTERNALLY TO 1/2 GRAM
    ALUM 320cc INT RUNNER, 119cc HEADS, 2.25/1.88 VALVES
    ARP HEAD BOLTS, FEL PRO GASKETS,
    COMP CAMS MAGNUM PUSHRODS
    STAINLESS STEEL ROLLER ROCKER ARMS
    S.A. GEAR DOUBLE ROLLER TIMING SET
    COMP. CAMS SOLID FLAT TAPPET CAM, 612/605" LIFT, 255/266 DUR @ 50, 110 LC
    Best deal I have found on a FA LB
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Got that money tree instead of a Christmas tree, :cool:.
  23. jakedmoe
    jakedmoe
  24. Chopperman
    Chopperman
  25. ***Area-51***
    ***Area-51***
    from Ohio
    NICE! when do you expect it to arrive at your place?
  26. Chopperman
    Chopperman
    They said 4 week lead time, plus I still need to come up with a few thou more, so i don't just "charge it "
    I'm gussing i should be installing it mid to late jan
  27. BulldawgMusclecars
    BulldawgMusclecars
    Glad to hear you found another motor...already looking forward to the next video!
  28. brewster55
    brewster55
    love this car.
    gives me inspiration i need.
  29. Rob Kozak
    Rob Kozak
