home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. scootermcrad
    scootermcrad
    Yes! AWESOME! THANKS! Great work!
  2. Dyce
    Dyce
    I made the upper using a milling machine. You could leave the top flat, and make upper dies that you can remove. That way you can make a point, and a few radiused uppers. It works good the way it is though for sharp bends. It'sbar stock I salvaged from an old belt conveyer.
  3. Patdoody
    Patdoody
    Good stuff.. I actually just got done making a replica. I don't have a mill so I used a piece of 1/4 angle for the top die...
  4. KrisKustomPaint
    KrisKustomPaint
    Its not all homemade but the pedals are.
  5. cowboy1
    cowboy1
    from Austin TX
    is that motor from a hospital bed?
  6. KrisKustomPaint
    KrisKustomPaint
    I think it came of a "lift chair" but i'm sure a hospital bed probably has a similar motor.
  7. Dyce
    Dyce
    They really come in handy making brackets!!
  8. cowboy1
    cowboy1
    from Austin TX
    YEAH ! I just pulled one off a hospital bed for this same set up! How's it working for ya?
  9. Kustom Leatherworks
    Kustom Leatherworks
    from Milwaukee
    Some helpful tools here
  10. KrisKustomPaint
    KrisKustomPaint
    Well you can see I did reduce it down about 3:1. but at that speed it works great. Not too fast, but slow enough to make smooth turns. Some times I have to tap the pedal to turn a tight turn but other than that its wonderful. You can make a full depth p*** on 18 ga. steel no problem. Motor has plenty of power. Speed control would be nice but having a power bead roller for next to nothing is nicer.
  11. Patdoody
    Patdoody
    Yeah I bent up a piece of 1/8" steel diamond plate with it very easily. I have a 4' box and pan brake but hate putting heavier stuff in it, since its only designed for 22g
    I took photos of making it I might throw together a "how to" build for it.
  12. iagsxr
    iagsxr
    Bench at my house. Had to reload my computer lost all the actual fab pics.
    I'm still working out the backsplash.
  13. KrisKustomPaint
    KrisKustomPaint
    You must have some DEEP pockets to be using heim joints on a work bench. Looks cool though.
  14. MP&C
    MP&C
  15. vendetta
    vendetta
    my latest-a 600 wide press brake.i can use the arm for bending light gauge and narrower parts.as i don't have a press,i might just put a bottle jack on top instead of buying a press for heavier/wider parts.
    second picture is of some dies for putting swage around 1 1/2 and 2" holes in sheet metal.
  16. rouye56wingnut
    rouye56wingnut
    from mn.
    That tool was built by Joe Hartson and can be seen on allmetalshapers.com.I got a chance to use it at Kerry Pinkertons fall gathering in Huntsville Al.Joe is quite the machinist and craftsman .Dan
  17. hugh m
    hugh m
    from ct.
    Just gave away a Ryobi electric log splitter, and the thought came up it would be a neat "power cavity" to use for a small press or even a tube bender...just an idea.
  18. Blue One
    Blue One
    from Alberta
    I got hold of a Dayton gear motor, the same one Murfman used to power his bead roller. He posted pictures of it on one of the bead roller threads.
    It has a pair of wires which need to be swapped to change the direction of the motor.
    I'd like to be able to wire it with a switch to change motor direction and a single foot pedal to control it all.
    Anyone have any ideas or know how to do this ? It has me stumped right now.
    By the way I have been in touch with Murfman and he did reply back initially, we corresponded back and forth by e-mail.
    I asked him for details on how he wired his, as he has done what I want to do.
    No response lately to my messages and he seems unable (or unwilling) to help me out.
    Any help will be appreciated. Below are 2 pictures of Murfmans BR.
    Larry.
  19. Blue One
    Blue One
    from Alberta
    A bump for my question above.
  20. brucer
    brucer
    from western ky
    did you get a reversible motor?
  21. Blue One
    Blue One
    from Alberta
    Yes, the motor is reversible by switching a wire to the power supply it runs the other way.
    What I want to know is how to hook it up so both wires are hooked up and when switched it will run one way and then move the switch and have it run the other way.
  22. bct
    bct
    better hire an electrician if you can't figure that out
  23. HemiRambler
    HemiRambler
    Do a search on "wiring a reversing switch". Several ways to accomplish your task.
  24. Blue One
    Blue One
    from Alberta
    Ok thanks for the help :rolleyes: Now run along skippy your mother is calling. ;)
    Thanks I'll do that. Just thought maybe someone here had done it or knew how to do it.
  25. BISHOP
    BISHOP
    Its all in the switch. You just need a switch that caries a ground, and two positives oposite of each other, its very simple. Its called a 3 way switch. Top is forward, center is off, bottom is reverse.
  26. Why not two pedals side by side, a switch in one wired for forward, the other with a swich wired for reverse. Very user friendly:):):)
  27. Country Gent
    Country Gent
    Holy **** Andy! Super nice work. That truck should be a show piece if it's anything like your build work. country Gent
  28. Blue One
    Blue One
    from Alberta
    I have seen that done, and didn't want to go that route because it is too easy to switch motor rotation when the motor is under load by accidentally (or on pupose) stepping on the other foot switch.
    The instructions for my motor state that the motor must be stopped and not under load before reversing direction.
    I have found what I need is called a reversing drum switch. They have a neutral and you can stop the motor, switch direction with the drum switch and carry on with the single foot switch.
    The wiring is relatively simple with it too.
    So, a drum switch and a foot switch along with a little fab work and I'll have a powered bead roller.
    I bought a basic Magnum bead roller with an 18" throat. The fab work will involve beefing it up and mounting the motor.
  29. bobj49f2
    bobj49f2
    A rigid pipe threader is wired in this matter. You need a heavy duty two way switch and a foot pedal. You should be able to buy a replacement kit from a Rigid distributor in your area.
