?? on leaf spring brackets
Discussion in 'The Hokey Ass Message Board' started by sewanhaka62, Dec 7, 2010.
  1. sewanhaka62
    sewanhaka62
    hi was wondering if on a leaf spring if the rear [loose ] brackets have to face rearwards or can they be attached in front of spring eye -- is there a certain angle needed .. thanks bob
  2. 53sled
    53sled
    from KCMO
    Shackles. They are on the rear for a reason, many actually.
    Angle, important, yes but it is not as important as on a transverse leaf.
  3. 69fury
    69fury
    from Topeka
  4. sewanhaka62
    sewanhaka62
    on that spring ?? the front of spring has a solid bracket mounted to frame -- on the rear of spring , the bracket that swings for play , does it have to be mounted behind the spring eye ..... wouldn't there be enough
    play for it to work if mounted in front .. thanks fury for answer
  5. rusty1
    rusty1
    ...look at some stock vehicles with the same set-up for suggestions.
  6. buzz4041
    buzz4041
    from Texas
    All the one's I ever saw they were mounted behind. Maybe this helps
