need a "custom" tank for air ride
Discussion in 'The Hokey Ass Message Board' started by sawzall, Dec 7, 2010.
  1. sawzall
    sawzall
    looking for someplace where I can source a tank for my air ride setup.. I need the outside to be about 5 inches in dia.. I can go as large as 6 inches.. but thats it..
    length less than 30 inches is all good.
    any thoughts?
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Tubing capped on each end with ports drilled and welded.
  3. Brentadour
    Brentadour
    Hey sawzall, I'm in Phoenixville too. If you're looking to have something made I know a good welder in town.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    I don't know how much pressure the tank will see but it is over 15 PSI I would use a 4"
    dia. piece of pipe threaded on both ends and capped.
  5. Clark
    Clark
    I may have a tank about 6" by 20 something.
    Clark
  6. dreracecar
    dreracecar
    from so-cal
    An old fire extingusher
