Fastest you've ever been?
Discussion in 'The Hokey Ass Message Board' started by Drewid, Nov 26, 2004.
  1. NoFriends310
    NoFriends310
    now that has to be the ultimate rush! how was the turning radius on those birds? was it as bogged out as a lot of the claims say? Closest I got to breaking the sound barrier was in a F-18 simulator at EL Toro before they closed it down...hell even in that thing (pretty intense and realistic) tunnel vision was crazy!
  2. Wagonmaster2
    Wagonmaster2
    135 in a 428 powered '69 Pontiac Gran Prix w/ tall gears
    129 in my wife's current Hemi Magnum (governor limited) will do 150 easy
    160 in my 2000 Corvette-solid as a rock!
  3. OldCrow
    OldCrow
    160 sitting on the right side floor of Paul Pfohls D Jag. his son Paul Jr was a friend of mine and Paul Sr was out of town on business, so Jr and I took er for a spin. rural road near Cave Junction Oregon. that was around 1967. I still miss Jr. he was killed in a car accedent a couple years later (71 Boss Mustang).
    Russ
  4. Belchfire8
    Belchfire8
    Went an indicated 140 in a friends '70 440 Magnum Charger, probably more like 125 m.p.h. I remember it took nearly a quarter tank of gas to get the speedo buried and then back to the legal freeway speed with four of us in the car!
  5. 3Kidsnotime
    3Kidsnotime
    from Utah
    157 Radar on water 24 HTM 614ci 14lbs boost That will make your **** pucker.
  6. Jimbo302
    Jimbo302
    from Micronesia
    '97 viper gts. Speedo said 181, but who knows. Whatever speed it was, it tried to **** the p***enger window out when making a slight left lane change.
    Got pulled over after taking a little ford beater (with a solid cam engine that made power to 7k rpm) to over 5500 rpms in 4th (1:1), with a 26" tire and 2.73 rear. When the officer asked if I knew how fast I was going, I said "my speedometer only goes to 85". He didn't care for that, but still only gave me a ticket for 99mph in a 70 :thumbsup:
  7. woodienut
    woodienut
    from So.Cal.
    1968, 150 Indcated who knows how fast really? In a friend's GT500 Mustang (2 fours)on highway 55 west of Minneapolis, MN. running right down the dotted line in the middle of the road. He was hitting me in my right shoulder yelling "slow down A-hole"!!!
  8. EnglishBob
    EnglishBob
    and what crotch rocket was it?
    Honda B/s?
  9. 1951coe
    1951coe
    from Manvel TX
    I have been maybe 105 in my chevy silverado and i felt like the aerodynamics was on the verge of taking my life.
    The trucks i have driven in the 100 + range all were one stiff breeze or bump from flight, the aerodynamics are all wrong for that speed. I don't think you could keep it in a 4 lane span over 110:( but maybe my sh*t is different than the other chevys out there.
  10. Past 140 in my 02 Ford Lightning, MMR SM900 LB, ported, cammed all the goodies. My 54 I think reached a chilling 70 MPH once.
  11. Ned Ludd
    Ned Ludd
    124mph in a VW Golf Mk1. The speedometer needle was pointing straight down, but it overreads by 20%. Calculated from rpm, gear ratios, and tyre diameter it was an honest 200km/h.
    On Eibach coils and custom dampers it felt solid as a rock. It's amazing how a bit of speed takes out all the jitteriness. The ch***is is good for that extra 20% but the engine isn't ...
  12. fonti
    fonti
    165 with the 32 "Coupester" at 2010 Speedweek and in the 150's on the German Highway...
  13. Diavolo
    Diavolo
    So, those of you that want to say motorcycles can't go 190 mph... you have to realize some of us ride real motorcycles, not air cooled v-twin..... ah, never mind.
    I have previously stated that I personally have gone an indicated 181 on my Honda Blackbird. It is generally accepted that the speedo is indicating about 5-10% higher number so that makes my speed about 163 to 175. It's generally understood that using a power commander or other governor override with undo the governed speed limiter and 200+ mph is attainable with a mostly stock real motorcycle.
    From wikipedia:
    The Suzuki Hayabusa (or GSX1300R) is a sport bike motorcycle made by Suzuki since 1999. It immediately won acclaim as the world's fastest production motorcycle, with a top speed of 188–194 miles per hour (303–312 km/h).
    The Honda CBR1100**, also known as the Super Blackbird is a motorcycle manufactured by Honda from 1996 to 2007. In the mid 1990s, Honda Motorcycles were determined to produce the world's fastest production motorcycle and to take over the ***ociated bragging rights and marketing impact, at the time held by Kawasaki with its ZZ-R 1100.<SUP cl***=reference id=cite_ref-Brown2005_2-0>[3]</SUP> This led to the creation of the CBR1100** Super Blackbird, which achieved a verifiable 177 mph (285 km/h).<SUP cl***=reference id=cite_ref-3>[4]</SUP> The Blackbird name is a nod to the Lockheed SR-71 aircraft, once the world's fastest aircraft.<SUP cl***=reference id=cite_ref-siue.edu_4-0>[5]</SUP> Two years later the ***le had p***ed to the Suzuki Hayabusa which was able to exceed 188 mph (303 km/h).<SUP cl***=reference id=cite_ref-Brown2005_2-1>[3]</SUP><SUP cl***=reference id=cite_ref-Hoyer2007_5-0>[6]</SUP>
  14. Little Terry
    Little Terry
    150 in a BMW M3, but it didn't feel nearly as fast as doing around 75 in my '41!
    One of my old college buddies regularly attended the 200 club at the local airfield and topped the 200mph regularly on his modified hayabusa. I never accepted his invitation for a ride.
  15. brownsmetal
    brownsmetal
    My old Es*** on the way back from Louisville on 65 , Fast enough not sure though. 29 inch tire, 3.00 gear, 6000 rpm and using both lanes.
  16. TwoLaneBlacktop
    TwoLaneBlacktop
    from Burien
    125 in a Stockcar (Nascar) 115 on a Harley...............
  17. TwoLaneBlacktop
    TwoLaneBlacktop
    from Burien
    Oh.........and 110 in My '36 Ford Sedan.............
  18. Big Mac
    Big Mac
    Foggy memories + Keyboard cowboy power = Lot's of ******** stories.
  19. Big Mac
    Big Mac
    I had a '31 coupe, ALL ORIGINAL (even had the original front tires). The 80 yr old front end was toast. It was WAY squirrly, but I got it up to about 35 on a back road by my house. You had to turn the steering wheel at least half a turn before it would even engage. THAT was scary. lol.....
  20. 8flat
    8flat
    Very good point....haha. If they haven't swung a leg over a 175hp sport bike, they can't understand what they're capable of. My ZX9-R was extremely aerodynamic and very stable at 185, it was seriously stuck to the road.
    Hitting 190 isn't hard at all for a liter bike with some mods.
  21. 132 In my Mom's beamer when I was in High School ( I know Dumb)
    135 in a '75 Camaro, street/strip car, sitting on the p***enger floor (no seat)
    142 34' Magic Offshore Boat with two 1150hp wipple charged BBC
  22. travj31
    travj31
    from Western PA
    about 145 on CBR600, that is too fast for me... i was about 8200 rpms on a 15000 redline in 5th gear i believe. too wicked fast for me, wouldn't ever do that again...
  23. Racrdad
    Racrdad
    68 Camaro, small block on spray, all steel except the hood, 9 inch slicks. Oh yeah, street legal too :D 9.37 @ 137mph quarter mile. Dang I miss that car.....:( Next car I own built for speed will be a 55 Chevy!
  24. SLAMIT
    SLAMIT
    Prolly about 650-700mph while sitting in my dads camaro as a kid while he was restoring it. had no doors on yet and a crate inside but I would sit there and race hard everyday he was at work!!!!!!
  25. 6berry
    6berry
    115 in my audi but about 30 in my '48 when it had the flathead
  26. Jonneville
    Jonneville
    from NY and UK
    In the air, around 350mph in a P-51 Mustang...
    ...on the ground, 226mph at Bonneville in the SO-CAL Speedshop-built MG ZTT (I know it's bit late for here but it also sneaked into Hop-Up Vol 5)...
    ...but it's all relative as 125mph seemed damn fast in the Bones' '32...
    Regards
    Jon'.
  27. Zack Methvin
    Zack Methvin
    160 down the backstretch at Texas Motor Speedway in a Cup Car.
  28. Ruiner
    Ruiner
    My '63 Dodge Custom 880 with the 383 and tall gears put the fear into me at about 120 with about 1/2 to 1/4 pedal left to go to the floor...I backed off and it took me a few minutes to calm down...I'd really love to take her to Bonneville for the hell of it and really open her up...all stock, but good lord can that 2 barrel beast scream...
  29. Smokey2
    Smokey2
    Damn!!!! You've been FASTER On WATER!, Than I have in any Car.........(1960) !957 Chevy, .040 overbore, Racer Brown Roller, 3.70 Gear, Took tire Diameter.....Come up with 141 mph.
    (2002) 2001 Lincoln LS V-8..........148 mph, about 3 a.m. on 2 mile Striaght! ****
  30. Boeing Bomber
    Boeing Bomber
    110 MPH in my old Dodge van across the I-90 floating bridge around 1:00 in the morning, just because my buddy wanted to see what it was like to stand up going over 100 MPH. Came shooting out of the tunnel on the Seattle side like a Watermelon seed... only to see a cop waiting for me.... Beat the ticket in court.
