How to get weld splatter off glass ??
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Feb 26, 2005.
  1. Toqwik
    Toqwik
    Somehow I got welding splatter on my new windshield. Is there any way to fix it? can you polish it out, or just deal with it? Fido
  2. jalopy43
    jalopy43
    Sorry buddy, once it's there,it stays! You might polish out some of it,with very fine steel wool. Good luck. And remember guys, protect your gl***,BEFORE you weld or grind near it!!:( Sparky
    Dino 64 likes this.
  3. fab32
    fab32
    Easy fix. drive over to your favorite gl*** shop, give them a few hundred bucks, they put in new gl***, it's almost like it didn't happpen.;) :cool:
    Frank
  4. [size=+2]Basically your windshield is pitted for good.
    Now you can take a razor blade and go back and forth to remove the small metal beads. Be sure to use one side only of the razor blade. This is because if you use the other side it can scratch the gl*** even more.
    You could try some 0000 steel wool.
    Sorry to hear it, I hope this helps.
    Reverend Jake
    [/size]
  5. skipstitch
    skipstitch
  6. Hay Dude, your screwed. You can get the weld b-b off but the pit it leaves behind is there for good. Wish I had better news.
    The Wizzard
    Dino 64 and Hnstray like this.
  7. you are screwed......
    Dino 64 likes this.
  8. dadseh
    dadseh
    What he said.... basically your windscreen is F U K T .
    Guys, also remember if you use an angle grinder in the viscinity of gl*** it does the same thing. Molten sparks on gl*** = pitting. I hang a simple bed sheet in front of my car in the shed to stop stray sparks from grinder hitting the ride. Sparks will carry 15-20 feet to damage gl*** / paint.
  9. lowandgold59
    lowandgold59
  10. Noname38
    Noname38
    Don't listen to these guys... they're just tryin to get you down.... Wet sand it then spray some clear on it....
  11. kustombuilder
    kustombuilder
    from Novi, MI
    yeah that oughta work FABULOUSLY!! :rolleyes:
    i'm afraid i have'nt come up with any way to fix this problem. i've done it before but i learned my leason. i always hang a couple layers of masking paper over any gl*** or some times i use an old canvas drop cloth or welding coat. even if a spark burns through it'll likely be too cold to hurt the gl*** by then. sorry about your luck. you might call a gl*** shop though just to see if they have come out with some miracle cure.
  12. LeadSledMerc
    LeadSledMerc
    If you find the miracle cure, be sure to let us know.
    We've all done this at one time or another!
  13. krooser
    krooser
    ALWAYS remember to cover your RADIATOR, too, when you are welding/cutting. Those hot chunks of metal LOVE to burn holes in those fragile copper tubes....
  14. madgrinder
    madgrinder
    badge of honor... wear it proudly.
    nochop likes this.
  15. 3M makes a spark resistant paper that is sticky on one side. It works good against grinding sparks, don't know about welding though. I wouldn't use just any old blanket to shield weld spatter, I've done it before and the results could be worse than a ruined windshield. Welding blanket or something non flammable preffered.
  16. 1lowtrk
    1lowtrk
    I just did the same thing to my door gl***. rolled them down and figured they'd be ok but those damn little molten balls found ther way to the gl*** anyway.
    nochop likes this.
  17. Digger_Dave
    Digger_Dave
    I had the same problem, used liquid dish washing detergent along with Jake's idea; didn't get rid of the pits, but window was sure clean!
    And use NEW razor blades!!
    clem likes this.
  18. polisher
    polisher
    Alliance Vendor
    Shave off the splatter, if pits left are shallow, and I mean shallow wet sand with 2000 grit then buff with a muslin buff and a good calcined alumina at around 600 rpm using an 8 inch buff.
    You might be lucky.
    If you buff to fast you'll generate heat and crack it, or scratch it more with the buff.
    Chances are the pits will be too deep.
    If you find after buffing that it's a little hazy get either a liquid gl*** type polish and apply a little of that.
    Best of luck.
    It's job to get it right, but it can be done if pits are shallow.
  19. bbo
    bbo
    from Wylie, Tx
    remove and replace gl***. only way. I have done that before it ****ed because I know better. You are lucky the weld splatter can burst the gl***.
    If you are going to do a lot of welding and grinding then use welding blankets and welding paper. The paper is adhesive back(tacky) and is great for indirect protection. Use a thick welding blacket for immediate protection.
    Gl*** pits and interiors burn fast.
  20. Toqwik
    Toqwik
    what ****s is I was welding on the back quarter, never would have dreamed that splatter would make it that far.....I am so pissed....Fido
  21. flatheadpete
    flatheadpete
    from Burton, MI
    Dang...almost 14 years old.
    36-3window and Bandit Billy like this.
  22. Bandit Billy
    Bandit Billy
    Since the resurrection has occurred I will pay my respects. It is a bit OT (a bit???:eek:) but T-Top panels on T?A's are often removed and abused leaving deep scratches and basically look fugly. I had a guy at a gl*** shop sand and polish a couple of sets of fisher panels and they turned out wicked nice. Cant get too close the frame and you could actually see the ridge a bit were he had to let off as he got close to the frame but well worth the couple hundred I paid him.
    As for windshields, park the car near the driving range, call your insurance company.
    LBCD, clem and Truck64 like this.
  23. Dixon Bastie
    Dixon Bastie
  24. Rusty O'Toole
    Rusty O'Toole
    Sandblasting will mess up gl*** too. Masking tape or paper won't save it, you need blankets or something thick. Anyone know any good method of masking gl*** when sandblasting nearby?
  25. Dixon Bastie
    Dixon Bastie
    I had a wiper arc polished out of one of my windshields by a pro gl*** shop. The owner warned me it would make it smooth, but would leave a blemish that looked like looking through a film, and U wouldn't like it.
    He was right, came out horse ****, I installed a new one two days later.
    Weld splatter on gl*** is forever.
  26. Bandit Billy
    Bandit Billy
    Use self adhesive plastic shelf liner on the gl*** if you can't remove it. I get the white stuff but you can get flowers if your so inclined ;)
    Rusty O'Toole likes this.
  27. krylon32
    krylon32
    from Nebraska
    Sorry for your problems. I to have had this problem many years ago and while it can't be cured I did use a really razor sharp stainless s****er and removed some of the chunks which left what looks like a small stone hit. Finally got fed up and replaced the gl***.
  28. 1946caddy
    1946caddy
    from washington
    Learn to tig weld, problem solved. :)
    Surf City and nochop like this.
  29. DDDenny
    To quote our Brit friends "facking brilliant"!
