Info Needed: S10 Tubular Control Arms Install
Discussion in 'The Hokey Ass Message Board' started by Jalopy Joker, Dec 7, 2010.
  1. Jalopy Joker
    Jalopy Joker
    Have a '89 Chevy S10 front clip in a '51 Ford project car. Installing tubular control arms for air bag set up. Bought through an online ad. Did not come with bushings or upper arms cross shafts. Can I use stock shafts? Aftermarket bushings or rubber best? Will only be a basic up'n'down cruisin' car, not a show off ride. Thanks (I know many here do not like S10 suspension, but many do. I know for sure that there is a lot of approval for air bags)
  2. 53sled
    53sled
    from KCMO
    Do you have a press? Micrometer? Are you close enough to a parts store you could go measure the new ones? Are they made to take the stock size or not?
  3. Jalopy Joker
    Jalopy Joker
    have a press and digital calibrator. finding the cross shaft in stock locally is the tough one. I know that some sites offer a larger than stock diam bushings for replacement on a worn stock set up. so, likely can up with correct bushing in rubber. but, still need to know if OK to run a stock shaft. Poly urethane bushing kit prices online are close to good rubber bushings. either have a better overall ride?
  4. 6berry
    6berry
    besides that very helpful bunny with a pancake on its head... i would check on maybe s10forum.com to find some really good info about that stuff
  5. Jalopy Joker
    Jalopy Joker
    Thanks, will try.
  6. 55 dude
    55 dude
    contact the guys you purchased the A-arms from,they probably sell them.
  7. Jalopy Joker
    Jalopy Joker
    bought the control arms from a private seller.
  8. Jalopy Joker
    Jalopy Joker
    still searching online, with no answers to my question. instead of trying stock upper shafts looking at ones for tubular control arms from Thorbecke Brothers and rollpans.com
  9. Jalopy Joker
    Jalopy Joker
    pics of what I bought that need bushings/shafts for
  10. Edelbroke
    Edelbroke
    I thought urethane bushings were prone to squeeking. But as long as its just an up and down car I would throw it together with whatever is cheapest, as long as its new. Not alot of rocket science here in bushings
  11. Muddi1
    Muddi1
    from Washington
    There is a forum dedicated to S10's, they can definatly help you out, the link is
    s10forum.com
    Good luck
  12. Jalopy Joker
    Jalopy Joker
    Thanks Muddi1, been to that site and mys10.com and s10v8.com without any luck on information. Edelbroke Thanks, figure rubber bushings will work Ok. But, concerned if stock shaft will work-take close look at pics posted.
  13. T-rev
    T-rev
  14. T-rev
    T-rev
    Let me know if it pulls up.
    Sometimes it will not allow you to view unless your signed in as a member.
    If it doesn't work ill copy it on to this thread for you. As Well as his Pics.
    ----Trevor:D
  15. Jalopy Joker
    Jalopy Joker
    T-rev - Thanks. was able to view it. I think I saw part of it when I was searching online for info. but, BYC is closed and I could not see their products. answers a lot of questions. will search for article again online to print out without all of the ads on S10FORUM. like here, sometimes you do not know the correct wording to do a proper search.
  16. T-rev
    T-rev
    Hey No problem thats what i think the HAMB is all about.:D to help your Fellow HAMBer out when he or she is havin issues. So I try to do my best to help everyone out.
  17. Muddi1
    Muddi1
    from Washington
    I didnt like all the ads either, I own a 01 s10 so I just went ahead a subscribed, got rid of the ads but the site can seem disorganized at times like they are doing maintenance or something. When it is runnign right it is a great place.
    I like just checking out the tech article mostly.
    What are the arms from, I am sure you have posted but I cant read it while typing ..I should open another window !!!! lol..
  18. Muddi1
    Muddi1
    from Washington
    AHAH!! another window does wonders lol, Energy suspension has a rebushing kit for a decent price. (please forgive me if I improperly post any part supplier names). I forget the part numbers but I put them on my 01 when I lowered it and used the supplied bushing grease. I have a press here at home so I just measured and remeasured and pressed my old out and new in.
    I have had them for 3 years now and no sqweaks or other problems. Make sure to connect the sway bar loose until yo uget the weight of the vehicle on it then tughten it up. At first I did it with out wight and my truck handled funny, it was seemed very "tippy" when cornering.
    Good Luck!!!
  19. Jalopy Joker
    Jalopy Joker
  20. Jalopy Joker
    Jalopy Joker
    still looking for ideas as to who made the bare metal arms and the silver arms.
  21. Jalopy Joker
    Jalopy Joker
    going to run the bare metal ones since have matching set. have done reinforcing and added shock/sway bar tabs to lowers. ordered Moog offset upper shaft kit from partsgeek.com-will see how those work. still have to figure out lower bushings. have rareparts.com in Stockton that i can go to if I can not figure this stuff out.
