What would you do with a 32 axle and bones? This is what I did
Discussion in 'The Hokey Ass Message Board' started by donut29, Aug 12, 2009.
  1. Dirty2
    Dirty2
  2. donut29
    donut29
    from canton MI
    Thanks everyone for the kind words
    Im done with it NO more holes:cool:
  3. Young1
    Young1
    I remembered reading the article and couldn't remember which magazine it was in. Lots of digging and reading later I found it.
    The article people are talking about is "Drop, Fill, and Peak" from the March 09 issue (the one with the Orbitron on the cover) of Hot Rod Deluxe. It's a great tech article that follows Gene Winfield in how he fills and peaks an axle.
    Edit: I forgot to say they look great!
  4. greazhonkey
    greazhonkey
    Don't fill or drop, perfect as is. Nice work
  5. 3wLarry
    3wLarry
    from Owasso, Ok
    drill the ****er out to the ends...did mine and put 4700 miles on it in '07.
    Rolling Bones have 40,000 miles on theirs...no problems.
    Those axles are alot tuffer than you think, and it looks *****in'...
    junkyardgenius and kidcampbell71 like this.
  6. plym49
    plym49
    from Earth
    Maybe.
    The axle ends see different loads that the center.
    I guess it can last forever if it never hits the right pothole. Or maybe, you will hit that special pothole first time you drive it.
    The question is - - do you feel lucky?
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    Take a look at how thick a big beam axle is between the kingpin and the spring perch...it's almost a half inch thick...you ain't gonna break it.
    kidcampbell71 likes this.
  8. plym49
    plym49
    from Earth
    Probably not - but I'll bet that you can bend it pretty good if the front wheel catches a pothole or a curb just right.
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    don't mean to belabor the point, but if you hit a pothole hard enough to bend or break a big beam axle...seems like the tire would go first...especially if it's a bias ply.
  10. Royalshifter
    Royalshifter
    Moderator
    If anyone thinks an axle with drilled ends is going to break just remember that 1 3/4" spring everything is riding on.
  11. Cshabang
    Cshabang
    if you hit a pothle hard enough to bend an axle...you got bigger problems than a bent axle...
  12. plym49
    plym49
    from Earth
    But who cares whether the tire blows or even if the wheel bends. You still have steering. Both those things can happen (or not) and still the axle end can bend.
    I guess we can agree to disagree on this one. Your car does look nice, though.
  13. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I hear Eric was switching to selling billet items exclusively...hahaha.
  14. plym49
    plym49
    from Earth
    But the spring is designed to deflect - the axle isn't. Since the axle ends see different static and dynamic loads than the center portion of the axle (because of where the spring and radius rods attach), the question on the table is if removing that material from the axle ends makes them more likely to bend.
  15. plym49
    plym49
    from Earth
    Looks like the car in your ava is trying to dig a couple of new potholes..... :)
  16. crackerass54
    crackerass54
    from dallas
  17. donut29
    donut29
    from canton MI
    The great debate on weather to drill or not to drill continues:D
  18. VAPHEAD
    VAPHEAD
  19. donut29
    donut29
    from canton MI
  20. donut29
    donut29
    from canton MI
    Hey thanks it is the Hot Rod Deluxe with the orbition on the cover that has the article about how to peek an axle. I just found it
  21. fab32
    fab32
    Larry, There you go again.........injecting a bit of reality into a "Alice in Wonderland" discussion. A discussion I might ad that's being carried on by NOT ONE ENGINEER.
    Now if they were to bring up how many chords were worn away on that bias ply before it hit the pot hole we'd have a point.:eek::eek::rolleyes::rolleyes::rolleyes
    Frank
  22. Warpspeed
    Warpspeed
    Sure, but your "Big Beam Axle" is maybe eighty years old and full of very large drilled holes. Take out the original 4 banger, and fit a cast iron big block that weighs maybe four times as much, but of course none of that matters, eh ?
  23. el Scotto
    el Scotto
    from Tracy, CA
    Very nice!! Got to love drilled a drilled axle!
  24. neonloverrob
    neonloverrob
    from newton, ks
    I love the drilled look, I wondered about drilling the ends too. Never seen one done before this thread. It looks wicked completely drilled, but I'm thinking that might be a weak link too.
  25. donut29
    donut29
    from canton MI
    I'm not going to drill the ends I have decided to fill the ends. You don't see many undropped axles that have been filled so that's why I'm going to go that route.
  26. Old thread but you have lived in your Nanny state for far too long.
  27. Mudgy
    Mudgy
    Page 4 of 20 in this section says here in Oz we cant do that.
    Looks cool though!
  28. Warpspeed
    Warpspeed
    Yup, LIVED is definitely the right word.
  29. striper
    striper
    :rolleyes: Of course, there is a reason you don't see that.
  30. model t 26
    model t 26
    looks like you need to weld in the rust pits and grind it smooth,harvs bones seem to have a little more care to them,but nice job though
