My first car build 1933 Chevy 2dr Sedan
Discussion in 'The Hokey Ass Message Board' started by rjlilhaus, Dec 9, 2010.
  1. rjlilhaus
    rjlilhaus
    from Albany, OR
    This is my first car I am building I was never much into hot rod stuff till the last few years. I build a 67 Chevy swb and I i enjoyed every minute of it. I originally was going to build a truck but i like the old school hot rods alot more. So here are some pics of the begining.
    I am planning on building an entire ch***is. I am going to twin turbo a packard straight 8. I have most of the parts together and i just started cutting the car.
    So far i have taken 3 inches out of the bottom and welded the factory lower bodyline back on. tonight i cut 4 inches out of the top and i am in the process of putting it back on. I bought a 54 packard Clipper and pulled the motor out for a donor.
    volvobrynk likes this.
  2. rjlilhaus
    rjlilhaus
    from Albany, OR
    Body is off getting ready to start cutting. The plan is to cut the bottom off and replace the bottom body line parallel to the window and side body line i think its suttle but a cleaner look
  3. rjlilhaus
    rjlilhaus
    from Albany, OR
    bottom cut off and sectioning the body line to make it longer now that the section of body is gone. had to make it line back up with the line on the fender. I am s***ch welding it with mild steel rod and finishing it with silicon bronze.
  4. rjlilhaus
    rjlilhaus
    from Albany, OR
    I have alot more pics of the top chop and the rest of the bottom but i am having trouble downloading them. I will try to get time to try again tomorrow
  5. Lamplighter
    Lamplighter
    That's a good looking car to begin with, it will be fun following along. Any other design thoughts or goals for the car?
  6. Kreepea_1
    Kreepea_1
    I like where you're going with this. Will you run fenders? Please post plenty on the Packard build.
  7. rjlilhaus
    rjlilhaus
    from Albany, OR
    I cut the lower bodyline off so i can take 4 inches out of the body and make the lower bodyline parralell with the windows and middle body line
  8. rjlilhaus
    rjlilhaus
    from Albany, OR
    This is before the first cut
  9. rjlilhaus
    rjlilhaus
    from Albany, OR
    Getting ready to cut the top
  10. rjlilhaus
    rjlilhaus
    from Albany, OR
  11. rjlilhaus
    rjlilhaus
    from Albany, OR
  12. rjlilhaus
    rjlilhaus
    from Albany, OR
    I have more pics i got the whole top back on all the windows sectioned and back together all is ready to weld except the doors still got to cut them this weekend.
  13. glasshole
    glasshole
    looks good!Can't wait to see more.
    Bill
  14. mohr hp
    mohr hp
    from Georgia
    love these cars. Going fenderless/channeled? Good luck with it
  15. thechopperguy
    thechopperguy
    Very cool, and very timely. I'm just getting started on the body of my '33 Chevy Master coupe. I'll be posting the build as I get into it.
  16. rottenrods
    rottenrods
  17. caseyscustoms
    caseyscustoms
    from st.joe, MO
    i would of deffently had the subfloor in, mounted on the frame, and the doors fitting well before i chopped it.
    i hope it all works out for you, but i would never be that lucky for it to actually line up.
  18. chevyfordman
    chevyfordman
    I hope that you saved the little metal plate on the wood rail by the p*** seat as that is your vin number of the car and it should match the ***le vin number.
  19. rjlilhaus
    rjlilhaus
    from Albany, OR
    Ya going fenderless and hoodless I am building the entire ch***is and interior so i dont know if that is considered channeling but i think its the same concept
  20. rjlilhaus
    rjlilhaus
    from Albany, OR
    The wood was gone when i got the car I have to get an ***embly ***le which kinda ****s because i really wanted to have it ***led as a 33 but it is what it is i guess. luckly there are minimal things you have to have to get an ***embly ***le in oregon. I can still register it in oregon as a 33 so i dont have to have blinkers and all that jaz that they didnt have originally.
  21. rjlilhaus
    rjlilhaus
    from Albany, OR
    I am fitting the doors last because i want them to fit perfect so i am gonna fit them to the new opening they were on the car when i took it apart.
  22. rjlilhaus
    rjlilhaus
    from Albany, OR
    Its all tacked together rockers welded back in just the doors left and alot of welding. I am using silicon bronze to weld it all abck together
  23. Outback
    Outback
    from NE Vic, Oz
    looks like an interesting build!
    Will follow this one,
  24. 37mj
    37mj
    is that silicon bronze strong enough for welding structural steel body back together ?
  25. ratfink56
    ratfink56
    nice proportions
  26. BOWTIE BROWN
    BOWTIE BROWN
  27. caseyscustoms
    caseyscustoms
    from st.joe, MO
    so your gonna cut the doors to fit the opening?
    i relize they were on the car before, but youve chopped the hell out of it, with out and thing to keep your door openings the same shape, what makes you think they will still fit?
  28. rjlilhaus
    rjlilhaus
    from Albany, OR
    Silcon bronze done right is very strong. I am also tacking every inch or so with mild steel rod. i could tig it back together all nice but i am leaving it all raw and i like the gold look of the bronze.
  29. rjlilhaus
    rjlilhaus
    from Albany, OR
    Everything was pretty calculated so the should only be minor modifacations to the doors besides the same chop as the car.
  30. caseyscustoms
    caseyscustoms
    from st.joe, MO
    yea the height will be the same, do you relize how much the body twists with no floor?
    i hope it works out for you, it just makes it very hard to get back square if you start cutting with no structure.
