help to give a 305 some punch
Discussion in 'The Hokey Ass Message Board' started by stagmuffin, Dec 5, 2010.
  1. BulldawgMusclecars
    BulldawgMusclecars
    The 305 heads actually have a pretty good following a**** 3rd gen Camaro/Firebird guys...check out http://www.thirdgen.org
    Lots of good info on them there, and 305 stuff in general.
  2. no offence but i wouldnt piss on a 305 if it was on fire ive had a few all junk after 100K miles some way before that
    i understand being on a budget and haveing to use what you have but .......
  3. Blue One
    Blue One
    from Alberta
    A 305 will run much better on gasoline than on punch. Sorry I couldn't resist :D
  4. slammed
    slammed
    Do-a-search-do-search, yada,yada. At least he did not ask "Let's see your: tat's, dog, club jacket, shop, fridge, favorite beer, ect. It's a tech engine question to improve performance. Stagmuffin, bump the cam up in the .440 to .454 range on lift max. Keep the duration under 225 for daily use and still have a boost of power. Match the cam to the intake and exhaust. There is a ballpark figure for you. Without busting yer ball's. Later!
  5. Deuces
    Deuces
    I had no power adders at the time I was street racing them.. The stock T5 and the optional 3.08 gears out back. Standard gears were the 2.73's... I did order the '88 air and radio delete. The only cars I lost to were the Buick GN cars... Boy did they make me look bad.. :(
  6. Blue One
    Blue One
    from Alberta
    You were street racing, you looked bad every minute of it. :p
  7. Deuces
    Deuces
    Yeah I know... Once I got my first drag racing ticket, I kinda slowed down a bit.. That was over 20 years ago.. Now days (at 50) I take it easy.. :)
  8. Blue One
    Blue One
    from Alberta
    Funny how that works isn't it ;) :)
  9. 53sled
    53sled
    from KCMO
    I love it when people don't read. This dude is in the UK. 383 strokers aren't at every chain parts store over there.
  10. Deuces
    Deuces
    Yeah man!!.... And I'm still drivin' around in a 300 hp GT.. :D
  11. Gman0046
    Gman0046
    The 305 one of the biggest POS ever made by GM. Second only to a 307. Niether one would make a decent boat anchor.
  12. Blue One
    Blue One
    from Alberta
    Actually with all that m*** and weight, they would make a pretty good boat anchor. Of course you couldn't lower it or pull it up by hand :D
  13. i read his post , i just hate 305's i would rather run a 6 cylinder thank you
    i know hes in the uk
  14. slammed
    slammed
    There is a thread that make's the 307 come alive with a cam swap. Word.
  15. 32fivewindow
    32fivewindow
    from USA!
    Ditch the 305 and the 307 and buy a decent 327 or 350. It will cost you less in the end. The 305 has pretty much the worse combination of parts to work with. Intake and heads flow too little too make any real power.
  16. FANTASY FACTORY
    FANTASY FACTORY
    My 307 went 12.40 all day long with a set of 77 305 heads a 30 30 cam and a 650 dp.
    learn how to build an engine before you condemn one.
  17. shocker998md
    shocker998md
    the only GN a fox body could beat would be mine, but thats cuz the motors out of it:p
    He looked bad because he wasnt in the buick.:p
    sorry for the thread hi jack and the bragging on a very off topic car. But I still love myne.
  18. Herdez
    Herdez
    Boat Anchor.
    Add power packs heads, forged 305 pistons, pink rods and you get a roller cammed stroker 265. Another, destroked 305 with 283 crank/spacer bearings Clevite MS1110H/ small journal rods = roller cammed 265. :eek:
  19. David Chandler
    David Chandler
    To the 305 haters out there, perhaps you might expound to us on why they are all junk, and will never be otherwise?
    The bore and stroke ratio isn't all that bad, consider adding a 1/4" in both directions and you come up with the Holy Grail 383 by comparison. It's a good small cube engine that will perform well when used on the street, especially with mods. I know because I've built and driven a several of them in O/T cars and trucks.
    There is no magic formula either. Just do what is done on other engines of a similar displacement and it will take care if itself. ( cam, compression, headwork etc.) Just don't get carried away and get in the big is always better syndrome when picking your parts.
    Good Luck.
  20. David Chandler is right it responds to all the same mods as any other motor!
  21. SoCalChevy54
    SoCalChevy54
    It's easy just add 22ci.....
  22. slammed
    slammed
    Read the man's location. UK + strapped for cash = run-what-you-have-on-hand. HELPFUL tech tip's to wake up his SBC.
  23. hellcat666
    hellcat666
    remind me wich part of his post he asked for your opinion. whats the difference if hes putting it in a 49 merc, a triumph car, or using it to drive his pool pump? he asked for advice on gettin power outa the motor, not what the thing belongs in. the more you tear new people apart the more discouraged there guna get and the faster this hobby dies.
  24. hellcat666
    hellcat666
    prolly the most logicaly/best way to go about this. i would do everything oldsrtocket said and def run a holly 4bbl on there nothing crazy, but itl make it feel way better having the va*** secondaries on your side. good luck with it
  25. a friend of mine had a 307 in his 69 camaro it was a very high rpming potent little engine
  26. 22rdstrguy
    22rdstrguy
    Hot Rod Magazine had an article back in '84 called, Deadly Lessons, Prepping the 400-hp 305 cid Z28 engine with RHS built 041 heads, 292 Comp cam,stock cast pistons & rods etc..Flywheel: 402 HP @ 7200 / Road HP 300 @ 7000 I have the article if anyone wants a photo copy just pm me your emali addy.
    I personally like a slightly built 305 for it's bottom end torque & good 0-60 times.
    EDIT, here is a link to a copy the build http://www.hioutput.com/tech/400hp/400hp.html
  27. Blown Mopar
    Blown Mopar
    from abc
    Here's what I did to mine. 350 heads w/2.02 intake valves, over the counter 350/350 hp cam from Chevrolet dealer, Edelbrock dp manifold, Holly carb (don't remember size), set of cheap headers. Beat the living **** out of my ("305s are a piece of ****") friend's 350 many many times.
  28. hotrodstude
    hotrodstude
    i modified a friends 77 camero with a 305.set up the dist and replaced the stock manifold with a offy 360 dual-port intake with a q-jet carb,which modified myself.a trans-go shift kit in the t350,duel exhaust using ford converters and 77 trans/am exhaust system.installed new timing chain straight up.result was a car that could hold its own with a 350 vette and deliver 26 mpg on the highway.
