Easy way to cope tubing
Discussion in 'The Hokey Ass Message Board' started by wizardfab, Dec 20, 2010.
  1. wizardfab
    wizardfab
    This is a trick that I have been using for more than 30 years and thought it would be a nice X M*** gift to all my fellow Gear Heads. You don't need any special tools to make a perfect fit to weld 2 pieces of round tubing. All it takes is 2 straight cuts at about a 45 degree angle leaving a little less than 1/3 of the center square on the end. I know it sounds strange but it does work. here is a picture to show what I an trying to explain. I made the cuts with my band saw.
  2. wizardfab
    wizardfab
    Same tube side view.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    How bout some pics of them fitted together and then welded?
  4. bobbyd08
    bobbyd08
    from md
    Nice east tech article. Thanks for posting.
    Bobbyd
  5. wizardfab
    wizardfab
    this is the fit, don't have time to weld now but will soon
  6. Good stuff! I teach my students that method, and it's pretty hard for some of them to wrap their heads around how a straight cut gives you a curved shape...
    I've gotten to the point that I just make those cuts on the long tube instead of cutting to length and notching separately. Saves on s****, too. Especially on 4130.
  7. 1971BB427
    1971BB427
    from Oregon
    That is fantastic! Thanks!
  8. Bucksnort
    Bucksnort
    Nice tip,thanks.
  9. wizardfab
    wizardfab
    It also works for tubes that are not 90 degrees to each other. Once you understand it you can experiment with the angels to make it fit. I used a disc sander for this one, took less than 1 min
  10. flatheadpete
    flatheadpete
    from Burton, MI
  11. wizardfab
    wizardfab
    Wow... so I just got a personal message from some guy that told me that this can not work and that I used special tools to do it! I told him that it is not a joke and to try it for himself. It is all true! It just makes me wonder how many people think this is a big joke? If you do you might want to try it!!!
  12. willysgasser40
    willysgasser40
    from Illinois
    Common sense is not so common !
  13. Don't worry, those that know it works, know. Thanks for showing a basic and cool tech tip!
  14. Just proves sometimes the right answer is the simple one or the simple answer is the right one. Either way. Brilliant!!!
  15. 34ratpickup
    34ratpickup
    from Orange, CA
    Yes it does in fact work awsome. I have a tube notcher and about half the time I use it. Sometimes its just easier to cut it and clean it out.
  16. jick
    jick
    from london
    cool...i need to do some tube work in the new year....thank-you!
  17. JOECOOL
    JOECOOL
    Yep .I have one of the tools that use the hole saw, most of the time it is quicker and less mess to do just like you have. Thanks
  18. fab32
    fab32
    Been using that method for over 40 years. I've got a mill set up to do notching as I built roll cages for Howe Racing enterprises for over 16 years but the oddball angle notch can be made with an air tight fit using this method after some practice.
    Almost everyone with no experience will tell you it won't work by just describing it and the look on their faces is one of wonder when you show them. Anywhere two round surfaces intersect they do so in a straight line, all you have to do is orientate your line of sight along the intersecting line and like magic a straight line appears.
    Frank
  19. sodas38
    sodas38
    Great tech, how simple. Thanks for the gift!!
  20. BillyM
    BillyM
    Thanks Santa! I love it.......it's just wnat I always wanted too!
  21. Flingdingo
    Flingdingo
    I had to stare at the pics for a few minutes, and suddenly it was all very clear. I couldn't figure out from the text if you were cutting across the pipe, or down into the end of it.
    As I'm staring at the pics, scratching my head, my eight-year-old comes in,looks for about 1/2 a second and says, "I get it!" Damn kids.
  22. wizardfab
    wizardfab
    I am glad to see that some "old pro's" jumped in to say that they have been doing this for years. Thanks guys.
  23. Big_John
    Big_John
    from Upstate NY
  24. SLAMIT
    SLAMIT
    Rad tip!!!! thanks.
    Now just teach us how to bend tubing without a bender and I will be all set
  25. Patdoody
    Patdoody
    almost the same principal for when I cut custom 4-1 collectors
  26. Dean Lowe
    Dean Lowe
    I saw Don Long do that 40 years ago. Amazingly simple way to fit tubing. The 90 degree joint is easy. The angle joints take some experience to visualize how to angle the saw cuts.
  27. Prewar
    Prewar
    from Orlando
    Gonna have to try this. I'm going to build a 'lakester' header for my banger.
    Any suggestions or hints for the small pipes going into the cone?
  28. wizardfab
    wizardfab
    Wow are you talking about the Don Long that built top fuel cars? The reason I ask is that we have a 1969 Don Long car that we saved and take to a lot of shows so people can hear it roar.
  29. wizardfab
    wizardfab
  30. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    That's pretty cool- thanks for sharing! Merry Christmas!
