Punch press holes
Discussion in 'The Hokey Ass Message Board' started by bsduece, Dec 21, 2010.
  1. bsduece
    bsduece
    Hey guys how would I punch a 3/4 inch hole in 1/8 steel on the cheap, i've been drilling them but it takes awhile just looking for a better, cleaner way; anyone have any homemade tools or something to use like with a shop press......or is there any one in so. cal., south bay area with the capablities to louver, punch holes, dimple die and so on?
  2. rottenleonard
    rottenleonard
  3. budd
    budd
  4. AJofHollywood
    AJofHollywood
    I'm thinking 1/8" is a little heavy for a punch you can use at home. Personally I use step-drill bits with great success, a 3/4" isn't too big. Irwin make the good ones --but Harbor Freight's are decent too for less $$ then an Irwin.
  5. thunderbirdesq
    thunderbirdesq
    Buy a 3/4" bimetal hole saw, use a little cutting fluid and a slow speed setting on the drill. Seriously. Quick and cheap.
  6. 62rebel
    62rebel
    a unitool and your arbor press would work, but be time consuming and somewhat restrictive. then again, so is a drill.... interesting situation.
  7. jcillch
    jcillch
    JANCEY SLUGGER, or any other magnetic drill press with an annular cutter.
  8. Francisco Plumbero
    Francisco Plumbero
    from il.
    Possibly a punch for an electrical box, look under Greenlee tools. Although the initial tool is not cheap they last a lot longer than a drill and cut clean. www.blackbookoftools.com
  9. AJofHollywood
    AJofHollywood
    I've never had great luck with hole saws and heavy metal. Plus they never last very long and holed don't look sharp (in metal).
    $9.99 Step Drill set from Harbor Freight, drills up to 3/4". Saved me a ton of time and money --a tool no rodder should be without:
  10. thunderbirdesq
    thunderbirdesq
    I've had the same 3/4" hole saw for over 15 years and have drilled probably hundreds of holes with it in at least 1/8" thick steel. If you run them slow in a drill press and use a cutting lube they will work great and last. I have a set of those irwin step bits too, they also work well. I like to use them when a hand drill is the only option.
  11. pdq67
    pdq67
    I'm going with a Greenlee set, punch, die and arbor.
    I figure maybe with a 1/2" impact wrench, you will pop them out fast.
    pdq67
  12. AJofHollywood
    AJofHollywood
    I'm buying the wrong hole saws then. What brand do you have?
  13. thisbugger
    thisbugger
    The best whole saws I've been using is made by champion (other companies make similar items), but just google champion whole saw 3/4". Drill press helps also.
  14. thunderbirdesq
    thunderbirdesq
    I've had good luck with Lennox as of late, I can't remember which brand my first kit I bought was, but they were painted red (very little of which is left on them now and they're still in regular use!) and are an electrician's set. Any that are considered a Bi-Metal should be fine. Any that aren't, well, they'll be dull in no time.
  15. AJofHollywood
    AJofHollywood
    Now I know what to ask for for my birthday.
  16. porsche930dude
    porsche930dude
  17. brenthughes
    brenthughes
    from Florida
    The problem I've had with a hole saw in thick metal is chip removal; there is no path for the chewed metal to get out of the way. I agree cutting fluid is crucial. I use a tooth brush to apply cutting oil to the groove being cut by the hole saw, and then use the brush to clear the metal out of the hole saw's teeth. Otherwise the teeth load up with metal and just get hot instead of cutting. I'm sure there are better ways but this is what I do for holes larger than my biggest (5/8") drill bit.
  18. DdoubleD
    DdoubleD
    from Michigan
    I used a 3/4" rotabroach for cutting holes in my frame .120" thickness. Does a slick job.
  19. TheMonkey
    TheMonkey
    from MN
    a buddy built a tube notcher and somebody gave him this tip on another forum, that supposedly works good:
    "a machinist flex tube with a nozzle to blow compressed air on the holesaw.
    This is the BEST trick for making holesaws last. I drilled 100 holes into 3/4" steel (grade 50) with the mag drill to prove a point to one of my employees with a 1.5" Milwaukee brand holesaw from home depot. Keep compressed air right on the teeth, and they will last a very very very long time."
  20. lawman
    lawman
    I've used punch presses for over 30 years and I have two very nice ones now..It would take a VERY LARGE ton wise press to do 1/8" steel. I also have the Greenlee system of punches and would never even try to use them on that size steel. The Greenlees are good on 18ga stainless which is about 16ga mild steel and thats about all. Stick with a Drill press and bits and you will he happy.IMHO.Tom (Tired Old Man)
  21. T Fritz
    T Fritz
    In our shop we use a step bit or a rota broach for that size of hole and in that thickness of material. The lenox hole saws a very good. I have a mag drill and the correct bits-not cheap but easy. If more than 50 holes invest in a anular cutter or a rota broach.
    Fritz
  22. enjenjo
    enjenjo
    from swanton oh
    I use one of these. Yes I have one in my shop
  23. bigheavy
    bigheavy
    like double d said, use a roto broach or go with hi quality bi metal holesaw. Try the JMR, it has a finer and harder tooth. If you are using a regular drill arbor, a good trick is to pull the drill out of the center of the arbor and use it to drill the pilot hole. Go online to MSC or Mc Master Carr and order a short piece of hardened drill rod the same diameter as the drill. replace the drill with the rod. This way the hole saw will be the only thing cutting, instead of the arbor trying to egg out the pilot hole as well. Low RPM too.
  24. budd
    budd
  25. I pull the hole saw down onto the metal to be cut until it scuffs its whatever-diamater" circle on the piece then i back it off. I then drill a hole just on the inside of the circle to act as a drain hole for the chips to ac***ulate in and fall through, then go back to your hole saw, again with cutting compound, drill press, super low speed, and good pressure.
  26. A Blair Rotabroach or Holcutter will outlast any drill bit or holesaw. A friend with an Ironworker like "enjenjo" has pictured above is also a good thing to have.
  27. That's how I do it.
  28. stealthcruiser
    stealthcruiser
    I would not recommend, that you use an impact tool , on these punches.......
  29. lawman
    lawman
    1/2" inpack !!!!! Sound like a good way to destroy a good Greenlee punch
    and they are not cheap. IMHO Tom (Tired Old Man)
  30. brenthughes
    brenthughes
    from Florida
    Great tip; I'll try it next time!
