Dual carb setup on Chevy 235 Pics?
Discussion in 'The Hokey Ass Message Board' started by J DE LUXE, Dec 23, 2010.
  1. The set up on my '51 Burb.
  2. Cosmo49
    Cosmo49
    Test fired this '54 261 bored out to 280 with twin 2 bbl Carter-Webers on a Edelbrock intake, Buffalo Steve made the 4 hole perches for the carbs. The only way we could test fire this set up was to make the PVC spacers to clear the PO's home-made headers. It ran! Will go in my '49 1/2 ton this spring, need to change the color, thinking grey or period 261 yellow.
  3. J DE LUXE
    J DE LUXE
    from Oklahoma
    Nice air cleaners cosmo!
  4. J DE LUXE
    J DE LUXE
    from Oklahoma
  5. J DE LUXE
    J DE LUXE
    from Oklahoma
    What year is that 235 mothertrucker?
  6. Cosmo49
    Cosmo49
    Those are retro re-pops from Tom Langdon @ Stovebolt Engine Co.
  7. '54
  8. ragtop35
    ragtop35
    Mine
  9. 37RAT
    37RAT
    from Wisconsin
    This one is made from 1 1/2" SS Dairy tubing I had standing in the corner, 0n a '62 235-
  10. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Not the prettiest one, but it actually runs pretty well.
  11. J DE LUXE
    J DE LUXE
    from Oklahoma
    Good God 37Rat! Hog leg of an engine! innovation right there! Good stuff man!
  12. LameExcuse
    LameExcuse
    from Renton, WA
    What intake it that? It look bad ***.
  13. sixinarowjoe
    sixinarowjoe
    from eastcoast
    it's an ellis
  14. PeteFromTexas
    PeteFromTexas
    Makes me wish I had never sold my Ellis.
  15. J DE LUXE
    J DE LUXE
    from Oklahoma
    I have an issue with my temporary set up. For right now I'm installing my Fenton exhaust mans. for my lake pipes. I'm leaving on the original single intake. I can not figure out how to get the gas pedal throttle rod thingamajig in place so that I can connect it back to the carburetor. Is there a secret squirrel way of getting around the new installment or what. Here are some pics of the puzzle.
  16. J DE LUXE
    J DE LUXE
    from Oklahoma
  17. J DE LUXE
    J DE LUXE
    from Oklahoma
    If someone has some pic's of their engine down there on the drivers side It might help. Thanks guys.
  18. robleticia
    robleticia
    ^^^^^x2!!!!:d
  19. J DE LUXE
    J DE LUXE
    from Oklahoma
    I think I'll just use some cable to get around it. Thanx guys.
  20. sixinarowjoe
    sixinarowjoe
    from eastcoast
    .i have a few the first one shows the llinkage bosses ( my motor is a 59) the po used the one under the freeze plug with a real hokey setup -i moved it to the foward one when i went to my current setup -i had to extend the pedal linkage ,it worked great ,you might have to bend the linkage going up to the carb -
  21. robleticia
    robleticia
    ^^^^what he said! Mine is done the same way, its a '58.
  22. J DE LUXE
    J DE LUXE
    from Oklahoma
    Yep! Thats a whole lot better than the thing I just tried. I'm gonna go and play with the pedal linkage to see if I can get it to work that way. I sent that picture you gave to my phone for reference. We'll see if jack this all up too. LOL! I'm on a bit of a time line so this little stuff is becoming the headache. Thanks much sixinarowjoe.
  23. J DE LUXE
    J DE LUXE
    from Oklahoma
    Damn! that paint looks good!!! by the way!
  24. sixinarowjoe
    sixinarowjoe
    from eastcoast
    here are a few more
    the center pic shows the linkage pivot moved to the forward boss on the block ,and the rod to the carbs goes up between the intake,fentons -also note i extended the gas pedal rod ,hope this helps - joe
  25. knucklepower
    knucklepower
    from .
    what kind of air cleaner?? very cool things.
  26. J DE LUXE
    J DE LUXE
    from Oklahoma
    Yes sirrrr! It does help. I did something close to the first pic you posted. I did some rigged stuff to make linkage at the to. I'm not worried about the looks right now. Once I figure out the dual carb deal I'll make it look hotter than a 2 dollar pistol and a hand-me down holster! Yeah! I'll post some pics when I'm done so you can see the madness.
  27. J DE LUXE
    J DE LUXE
    from Oklahoma
    Off to finish up and test it out.
  28. J DE LUXE
    J DE LUXE
    from Oklahoma
  29. J DE LUXE
    J DE LUXE
    from Oklahoma
    Rigged it up and it works but now it doesn't start! WTF! Turns over but won't fire up. All I smell is gas fumes. Can't figure it out.
  30. Curt B
    Curt B
    Sure see a lot more of those Fenton intakes lately. Here's mine:
