hello everybody just wondering what best set up for motor mounts is for 57 international truck. I have been looking at a lot of different styles but not sure on which one to use. Thanks so much in advance! Hopefully that is
You probably wont get much help on here unless you introduce yourself and tell everybody what your about....
depends on what your shoving in her. but i'd use the same type of front mount bracket that it uses for it's 6cyl, it's a sturdy mount
want to put in a 327 i already have. Cheapest option for now the front mount will work? How do i go about this the best way. I keep seeing these weld on the frame styles with the polyurathane bushing.
