I just checked out the 4 barrel carb to 2x2 conversion adaptors at www.vintagespeed.com. Has anyone here tried those before? Are there any problems running them and how would a 4x2 setup on a dual quad intake look? Thanks, -Dean
I just got mine from suedesled (NWspeed) but have not intalled it yet. Tudor has one from Vintage speed I think but he hasnt installed it yet either..
Deal w/ NW Speed on this product for sure. I have heard almost nothing but bad reviews from Vintage Speeds adapter. Bolt hole not lining up, bad casting flashing, etc. And suedesled is a HAMB'r!
Well actually I was thinking of putting it on my '59 since they never made a multi-2bbl intake for a Ford 429ci. I'd like to do something a little more vintage than just one 4bbl. -Dean
get one from seudsled at north west speed as stated, and I think they are about 10 bucks cheaper in price than them vintage speed ones I debated this same thing for a good month mainly with myself and concluded ( with some HAMB knowledge) that i'd have to make up or buy some adaptors to run rochester carbs rather than them old 2 barrel holleys otherwise I'd be sacrificeing some power even though all I was going to use it on was a stock sbc 350 for now I just want to get things driveable and finish up the nessecities but perhaps next winter I'll take up the quest again
I haven't got the carbs yet but I do have the adaptors on the intake. Make sure you have enough room between carbs. Marty says you need 9 inches from center to center. I am going to have to make a spreader plate to get the 2 center carbs to clear each other.
I've got one of vintage speeds plates - there are some holes inboard I can't figure out. I am not sure how I am going to seal them off - I might seal them off by getting a different adapter
I had mocked up two 2x2 adapters on a tunnel ram too. I got 4 94s to fit if you run the adapters the opposite way(2 carbs one way 2 carbs the other) on a Edelbrock TRX1. My problem was that the top of the carbs were even with the top of my head . Went with a 2x4 set-up instead. Nobux
I'm glad I didn't buy the vintage speed piece.. How about their other products such as their rebuilt carbs?
How did you get the linkage to work? I barrowed a 94 from Himmelberg to mock everything together and would you believe even with the breathers it all fits under my hood!?
Oh......ok......(can you hear the rusty gears in my head starting to turn?) I don't supose you took a picture did you? Thanks for the great idea!
Hey Terry, Cool pic. get me one with the carbs. As far as the carbs go I can do those for ya too. Getting pretty backed up but I can get them out in 30 days
