Need help, front axle identification?
Discussion in 'The Hokey Ass Message Board' started by 117harv, Oct 24, 2010.
  1. 117harv
    117harv
    HPIM2993 (Small).JPG HPIM2994 (Small).JPG HPIM2995 (Small).JPG HPIM2996 (Small).JPG HPIM2997 (Small).JPG I scored this axle yesterday and have never seen one. It had wishbones and the juice brakes make it 39 or later ford. Maybe it's a lincoln or mercury? There is a raised area on top, maybe for a bump stop?
  2. looks like Lincoln brakes to me
  3. DD COOPMAN
    DD COOPMAN
    Looks like a Lincoln spindle, to me. Funny non-FORD-like curve in that axle, too. DD
  4. 117harv
    117harv
    I had a complete lincoln front end a year ago and the axle looked like a standard ford. I have also heard that the spindle/axle have to be used together as the inclination is different than ford.
  5. thunderbirdesq
    thunderbirdesq
    Late Linc, I believe...
  6. Andy
    Andy
    The Lincoln spindles a friend had used bigger dia. king pins. You would have to bush them down to use on a Ford. I did not have a chance to check inclination.
  7. 117harv
    117harv
    How late?
  8. johnny bondo
    johnny bondo
    from illinois
    46-48? Lincoln
    heres a 47 [​IMG]
  9. 117harv
    117harv
  10. 117harv
    117harv
    I checked his sight and another, and neither of them had a pic of it. It looks to have been identified by jonny bondo.
  11. 55 Mercury
    55 Mercury
    It's a 46-47 Lincoln axle. King pin dia. and inclination on the Lincoln is different then Ford. Wish bones are longer then Ford but if I remember right the wish bone boss is wider. Brakes are good to use on Ford spindles. They bolt right on and are self energizing.
    www.droppedaxles.com
  12. 296 V8
    296 V8
    from Nor~Cal
    Yes 46 - 48 Lincoln
    I narrow them to fit fords w spring on top (28 - 34 style)
  13. Muddi1
    Muddi1
    from Washington
    Howdy Gent's,
    I thought I had posted this question and perhaps it posted but it does not look like it.
    I have acquired a front axle that I am attempting to identify, It will be going under my first build and I need information to replace the king pins.
    The numbers cast into it on the drivers side "upright" are 3656872 GM312 It appears to be a drop axle of sorts and from the ONE online source that returns information I come up with a 1947-55 Chevrolet 1/2 ton truck axle.
    If this is the case great, other wise is it possible to have the king pins bosses drilled to a larger size? I have added a couple photos, The king pin measures 5.31 inches long and .866 - .877 this as I have found is the common 47-55 Chevy king pin but I have seen the same size for 1941-57 axles also, are they the same king pins?
    Thank you all for any assistance.
  14. TagMan
    TagMan
    Muddi1: It's a 1941-1955 Chevy (1st series) 1/2T axle, according to my '29-'57 Chevy manual.
    -Bob
  15. 55 Mercury
    55 Mercury
    It's a first series chevy AD axle. All the specs are on my web site www.droppedaxles.com there is also a article on my tech page about spindles.
  16. Muddi1
    Muddi1
    from Washington
    Thanks Guys!!! I have been very busy so it took a bit to get back to you.
