Going to UN-r*t the Rod,27 chrysler rebuild
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Feb 13, 2010.
  1. farmer12
    farmer12
    Great transformation, you did well!
  2. Great transformation! Welcome back from the "other" side...
  3. landseaandair
    landseaandair
    from phoenix
    I don't know if you've changed the steering arms out yet but I'd suspect the center link of flexing before the Ford arms.
  4. linkstar69
    linkstar69
  5. 4Door54
    4Door54
    from Nor*Cal
    What a transformation! Is that steering column staying?
  6. storm king
    storm king
    I didn't see anywhere that you found latches for the top yet, so let me suggest going to www.southco.com and looking around. I might look at "compression' latches first. Once you nose around there a bit, you'll learn what certain type latches are called and be able to do a more thorough search on the net to find other sources. I used Southco latches when I was building tonneau covers for Dodge Vipers, and they have a great selection of quality stuff.
    If you know how to ask them right, they might even send you "samples" enough to do the job!
  7. Lukydevl
    Lukydevl
    from Arizona
    Kick *** transformation!!!
  8. POLYFRIED 35
    POLYFRIED 35
  9. linkstar69
    linkstar69
    Great results man. A little help if you can I'm building a lakes modified from a dodge cowl and I was wondering what length your doors are.
  10. Looks great so far.
    Question about the shroud, could you remove the bars to the cowl, then unscrew the shroud and slide it back over the fan...then remove the radiator and cover?
    Keep at it. I like where it's headed.
  11. Rustridden31
    Rustridden31
    from Denver, CO
    Yeah, I like the new term "re-Rod" too. It must feel really cleansing to transform that thing. Much much better!
  12. Mart
    Mart
    You have done a great job of de-ratting the car - nice work.
    Can you take a couple of constructive comments?
    1, is it too late to get it up a bit higher? I'm thinking it might be, but in my opinion, the deep z'ing of the frame and the deep body channel still shout rat to me.
    2, ***uming the above is impossible, would it be possible to fill in the body a bit just in front of the rear wheel - as seen in this pic..
    That would add depth to the body and maybe alleviate the overly low / too thin look.
    Don't get me wrong, it looks great, especially compared to how it was, I just wanted to say what was in my mind as I looked at the pictures.
    Mart.
  13. rottenleonard
    rottenleonard
    Very small triumph, I had found a chrysler horn on e-pay, and found it was near the right diameter, the picture looked good so I sprung for it
    The photo looked a lot beter than it was, most of the color was just barely hanging on and would fall off if touched, so I media blasted the color off and brushed back in silver,black and body color. I had to cut off a couple of tabs and it just snapped into place!! looks right at home in the 56 chevy pickup wheel I think.
  14. rottenleonard
    rottenleonard
    Just under 38"
  15. rottenleonard
    rottenleonard
    Thanks for the link! these ones look interesting
  16. hasty
    hasty
    Looks like a fun car. Like the dash.
  17. rustydusty
    rustydusty
    The re-rod is coming out great! I agree with you that the first r@# rods I saw were basically low-budget unfinished hot rods. I looked at the first ones and thought they looked like a very affordable way to build. Over the years they quickly morphed into bizarre, unsafe looking shock-cars!:eek: I applaud you on your workmanship de-ratting the Chrysler.;) Also, would you mind posting some pics of the '39-'40 Chevy pick-up in your avatar? I have a buddy building a fenderless '40 Chevy p/u and I'd like him to see these pics for inspiration. Thanks...
  18. rottenleonard
    rottenleonard
    I've sold that truck and I sure miss it
    look here
    http://s559.photobucket.com/albums/ss34/rottenleonard/46 chevy/
  19. Rudy'sRod
    Rudy'sRod
    from Denver, Co
    Just read the entire thread as well. AWESOME work man. What a great transformation.
  20. Mr48chev
  21. koolkemp
    koolkemp
    Wow great job, I cant believe I never saw this thread before ! Fantastic transformation !
  22. rottenleonard
    rottenleonard
    small update, I got the steering arms cut off and replaced with the magnum arms, they seem pretty beafy, I don't think they will flex.
    Also the steering was a little fast so I built a new upper steering arm that was 1.5" longer, This made it go from a little ofer a turn lock to lock to almost 3 turns lock to lock and eliviated the tire rubbing on the drag link.
    I threw the car on the alignment rack but now the tie rod is too long, I could just cut it off and re tap, but it is one of the speedway specials that I've heard nothing but good things about on here:D, So I called up the folks at Welder Series and ordered one of their 7/8" seamless tubing units, cheap at 50 bucks if it stiffens it up.
  23. You're getting there.
  24. themachine
    themachine
    wow this has came a long way you did a great job
  25. BadLuck
    BadLuck
    this is so awesome to see! good for you.. what a giant step in the right direction! Looks great!
  26. rottenleonard
    rottenleonard
    I cut and pasted my quote from another thread just for the update on my chrysler.
    "Not to beat a dead horse, But I needed a shorter tie rod after changing my steering arms, I had a speedway one on before and after reading this thread I figured I would order a welder series rod rather than shorten and rethread the speedway rod.
    Despite the welder series rod being 1.5" shorter it weighed about a pound and a half more than the speedway rod, and the i.d. was substantialy smaller. The speedway one looked to be DOM tubing as was the welder series rod.
    Now the question is will this be enough of an advantage to offset the extra 1.5 lbs of un sprung weight? But I guess when you run straight axles you have to have the additude of "whats unsprung weight?"
    At any rate the folks at Welder Series are top notch and provided great service and a quality product. They sent a couple of free catalogs that look to have some cool stuff in them."
  27. rottenleonard
    rottenleonard
    Time to blow the dust off this old thread. I've been faithfully ignoring the car for a while working on other projects, but have managed some work on the interior.
    A few weekends ago the guys from the knuckle sk****rs were giving me grief about my "ol skool rodz" spade shaped brake line brackets:D
    I had built a portion of the aluminum seat and was triing to figure out a centerpiece, after a little mild ribbing I figured some retaliation was in order. This started my first real metalshaping episode(at least first somewhat succesfull peice") I think it adds something, :rolleyes:
    The seats are made from .060" aluminum, at this point they are just screwed together I still need to pull them apart dress the edges and fancy them up with some bead rolling. I'm hoping to make them look similar to radiator shroud. I'm prepping my wife for a few hours of bucking Rivets;)
    I also fitted some door panels I had made a few years ago out of aluminum.
    After triing to fugure out inside and outside door handles I settled on a low tech knob directly attatched to the bear claw release lever, It works well from inside or outside. The knob I hate to admit is straight off home depot's shelf.
  28. farmer12
    farmer12
    Looking great, good to see some progress! Awesome!
  29. chaddilac
    chaddilac
    Wow... looking good!!!
  30. Gabriel Howard
    Gabriel Howard
    from OKC
    like it, looks great
