T Coupe guys help
Discussion in 'The Hokey Ass Message Board' started by poofus1929, Jan 2, 2011.
  1. poofus1929
    poofus1929
    from So Cal
    I am looking for a rear end for my project. Those of you who have built T coupes what rear end did you use and what vehicle did you get it out of? Year and model? Any help would be appreciated.
  2. poofus1929
    poofus1929
    from So Cal
    For the Sunday morning crowd.
  3. 117harv
    117harv
    Banjo rear or later style? Ford Mustangs and Maverick 8" rears are narrow and have small ford lug pattern. Ford station wagon 9" rears from the late 50's to mid 60's are also narrow with small lug pattern. If a banjo, the 35-37 are the narrowest with good parts availability. Some people are running late 8.8 ford rears, they can be had realitivly cheap and come in different widths. It all depends on your budget and horsepower.
  4. rottenrods
    rottenrods
    Depends on your bolt pattern. I'm using a 70 jeep cj5 axle 5 on 5 1/2 on my 25 t coupe
  5. Edelbroke
    Edelbroke
    55-57 Chevy seems to fit pretty well
  6. Badass
    Badass
  7. alwaystiredlong
    alwaystiredlong
    9" first gen BRONCO, 58" backing plate to backing plate. See ya. Scott
  8. SinisterCustom
    SinisterCustom
    Ya runnin' fenders???? An 8" outta a Mustang or Fairlane is @ 58" flange to flange....eary Bronco is as well, but has large Ford pattern.
    I'm using an 8.8 out of an '89 Explorer....they are cheap, strong and have a few nice ratios, some with limited slip. They're @ 60", perfect if fenderless and channelled...
  9. shane85
    shane85
    55-57 chevy in my 27
  10. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Dana 44 out of 1973 Scout. Factory 3.73 gears, 5 on 5 1/2" pattern and same width as my ford front axle.
    Louie
  11. alwayzarat
    alwayzarat
    9" out of a 72 ford pickup. Buggy spring in rear. 5 on 5.5 bolt pattern
  12. HarveyWallbanger
    HarveyWallbanger
    Stock '46 Ford banjo with an A spring on an A frame.
  13. 56 olds fits perfect
  14. Mr cheater
    Mr cheater
    some thing in the neighborhood of 57'' worked for me. I think it was out of a 55 Chevy
  15. 58belair
    58belair
    55 chevy in my 26 T
  16. So-cal Tex
    So-cal Tex
    I have '55-'56 rear ends in my '32 and '36 Roadster. Chevy pattern and you can run '47-'49 International "16 steel wheels that accept a '40 Ford style hub cap ( chevy pattern).
    They are pretty narrow and fit model A's and T's well, I think "57 wide.
  17. crotex
    crotex
    from cuero, tx
    I got a 97 pontiac firebird posi trac rear end in mine.
  18. poofus1929
    poofus1929
    from So Cal
    Thanks for the responses fellas. I am getting a good idea what my options are now.
  19. DuckusCrapus
    DuckusCrapus
    I ran a '70 Ford Bronco 9" in mine.
