Do brand new gas tanks need to be sealed?
Discussion in 'The Hokey Ass Message Board' started by OldSchool64, Jan 2, 2011.
  1. OldSchool64
    OldSchool64
    I recently purchased a brand new gas tank for my thunderbird and have prepped and painted the outside. Before I install it do I need to seal the inside with something like POR-15 or should it be good as is?
    Thanks!
  2. landseaandair
    landseaandair
    from phoenix
    No no no! Edit, to be clear, don't seal it.
  3. OldSchool64
    OldSchool64
    I thought the sealant was only for restoring an old tank, just wanted to check. Thanks!
  4. landseaandair
    landseaandair
    from phoenix
    Yep, it's a last resort kind of deal and quite often doesn't work out well.
  5. CutawayAl
    CutawayAl
    from MI
    For many years OEM type tanks were protected by a solder-like layer called Terne coating. Due to environmental concerns tanks are now plated with zinc or other metals. If you wanted to seal the tank, proper adhesion of the sealer would require acid etching or completely removal of the existing plating. Sealers sometimes fail, so it wouldn't make sense to compromise the factory coating to apply a sealer. Methanol attacks the platings used on gas tanks. So no matter what coating/plating the tank has, be sure to avoid fuels and fuel additives(like cleaners and dry gas) containing methanol. A little Isopropyl alcohol won't hurt anything, so be sure any alcohol containing products are isopropyl or ethanol and not Methanol.
  6. GassersGarage
    GassersGarage
    My buddy sealed his brand new tank in a '32 3 window. One day, the car wouldn't run. The sealer was flaking off and clogging the everything.
  7. hotrod1940
    hotrod1940
    Painting the outside is a no-no from what I was taught, but I forget why.
