Can glass bead damage good valve seats ?
Discussion in 'The Hokey Ass Message Board' started by nali, Jan 2, 2011.
  1. nali
    nali
    I begin rebuilding a 263 Buick engine , Str8 .
    For now I removed the head , checked the valves / seats , clean with coumpound , all is nice . The engine was rebuild before in 1995 , so I mostly check everything , just to be sure of what I have .
    The head is really dirty , a lot of carbon inside , and the shape of the T siamese intake makes it hard to reach .
    I can gl*** bead it at home , I have compressor , pressure pot , gl*** bead , cabinet , etc ..
    Is there a risk to ruin the valve seats ?
    Thanks a lot .
  2. No, bead away, if the seats are in good shape, just lap them in afterwards with grinding compound. if they needed work anyways.... go get a full valvejob.
  3. aaggie
    aaggie
    The machine shop will hot tank the heads anyway so save your work for something else.
  4. nali
    nali
    Too late :p
    This engine won t go to the machine shop for now .
    It s been rebuild in 1995 and quite not droven .
    So I don t take a big chance running it "as his "
    Just dismanstel everything , check . Etc .
    For the machine shop , I ll need a spare head 248 or 263 to port it , the first one will be quite stock .
    Did it . The gl*** bead had already used , so was really gentle . More dust than sand , and I use a mosquito screen before the blast pot :p I have to check the seats with coumpound and Prussian blue , but if seems ok .
    It s clean :p
    The goal is a 263 in the 1938 on my avatar .
    I began last week .. :p
  5. i worked in a machine shop redoing heads.. we gl*** beaded the heads... they all ran great..
  6. Dan Boehm
    Dan Boehm
    Now spend a lot of time cleaning the beads out of every nook and cranny. There is an oil p***age in that head that feeds the rockers. Beads will kill rockers and valve guides & stems in no time.
    Dan
  7. nali
    nali
    I ve used duct tape to block the oil and water p***ages , and wood for the valve guides, not so crazy :p
