How did old schoolers lower Model A rear?
Discussion in 'The Hokey Ass Message Board' started by RPU Rick, Jan 2, 2011.
  1. RPU Rick
    RPU Rick
    As ***le implies, how did the guys "back in the day" lower their Model A Hot Rod rears? I have a 4" drop front axle. Car will stay spring over in stock frame. I am arm chair building a 40's style Model A Hot Rod.
    Thanks HAMBer's
  2. Rpmrex
    Rpmrex
    from Indiana
    From what I have gathered, a T spring does the trick and you can take out some leaves if you need it lower.
  3. lorodz
    lorodz
    They did a small z in the rear of the frame look it up ..
  4. RPU Rick
    RPU Rick
    OK, Good info. About how low would a T spring with reverse eyes get it?
    Thanks Guy's
  5. cruzr
    cruzr
    z the rear, thats what mine has
  6. Thriftmaster
    Thriftmaster
    from Canada
    I have not done this myself but the early guys did infact use a model T spring to lower there cars. There was not mush in the way of welders around back in the early days. Rule of thumb is you drop one inch with a reversed rolled eye on a spring and for every leaf you remove you drop approximately one and a half to two inches in ride height. If I am wrong I am sure someone here will chime in and correct me.
  7. RPU Rick
    RPU Rick
    Sounds like I need a new T spring with reversed eyes...bolt in and done!!!!! Yeah, I know better!
    Thanks
  8. Hitchhiker
    Hitchhiker
    it's not just a bolt in. the t sping is narrower than a model a spring. You will need spacers at the perches and wedges at the spring mount.
  9. swsimon
    swsimon
    Can't the same thing be accomplished with a Model A spring? Reverse the spring eyes and remove some of the sping leafs? It seems to me that this would work using the original Model A spring. Please correct me if i am wrong. Thanks Scott
  10. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Also longer shackles
  11. brokenspoke
    brokenspoke
    Wedges?????
  12. handyandy289
    handyandy289
    from Georgia
    Longer shackles won't work on a spring over mount on a Model A.
  13. thunderbirdesq
    thunderbirdesq
    I've got a T spring in my deuce framed AV8. It is lower (almost too low with a spring behind axle) and the ride is great. You can get away without spacers at the perches, but it looks better with them or to trim the perches to suit the width of the T spring/shackles. The rear is fixed by the torque tube and will not move on the perches. You will need a shim to match the tighter curve of the T spring to the broader curve of the A crossmember. If you simply bolt a T spring into the A crossmember it will crack. I used a T rear crossmember as well to get around it.
    That said, I've seen more than a few old jalopies lowered by heating and bending the ends of the spring down too. Probably not the best method, but seems to be effective...
  14. racemad55
    racemad55
    Exactly,spring eyes will rub on the rearend housing!
  15. F-6Garagerat
    F-6Garagerat
    Cruzr, doesn't your car have a "spring behind banjo" under it too?
  16. Hitchhiker
    Hitchhiker
    A shim would be a better word I guess. Basically something to make up the difference of the tighter curve like Thunderbirdesq pointed out.
  17. brokenspoke
    brokenspoke
    I think I understand....how are they made, how are they attached...I appreciate it
  18. thunderbirdesq
    thunderbirdesq
    It would go between the spring and crossmember and are held in place by the ubolts and located by the centerbolt and the centerhole in the crossmember. I think the best solution is to swap the rear crossmember for a 26-27 model T unit. I just picked one up at a swap for $10. Probably equally as much work as fabbing an "adaptor shim".
  19. Just rework the stock A spring. Remove leaves 2 and 4, reverse the eyes, and de-arch the main leaves as per the Bishop/Tardel book. This combination should net you about 4" and give you a better ride. A springmaker will do this work for comparatively little.
  20. chrisntx
    chrisntx
    from Texas .
    My A coupe has the ends of the spring bent down.
    Rides good
  21. I am a big fan of the T spring. We made tiny little spacers out of solid stock to take up the shackle/spring eye difference. I was NOT interested in Zing the frame.
  22. brokenspoke
    brokenspoke
    If I was starting with a bare frame I would....I wish someone would do a tech on this
  23. i want to see the spacer
    anyone have a pic
    tk
  24. RPU Rick
    RPU Rick
    Wow, thank you HAMBers. I have the Tardel book...duh!
    Rick.
  25. brokenspoke
    brokenspoke
    x-2
  26. Russ B
    Russ B
    Mine went down with a torch heating up the ends of the spring. Not the best idea, but it was easy to find another rear spring back in the early sixties after one end broke. I think I still have the old broken spring laying around, looks like it was from a T. the ride was awful, almost no movement.
  27. You can see the little spacer on the spring eye side of the shackle, there is one on each side to make up the 1/4" diffrence, basically just a tiny washer but machined specific for the application out of solid stock. I still need to make up the wedges to support the crossmember above the spring, seems like a good project to start tonite.
  28. dirty old man
    dirty old man
    In '55 I was in Odessa, TX and bought a '30 "A" roadster. The rear had been lowered by the 'quick and dirty" method , heat the spring red about 6" or so from the eye and allow to sag till the resulting "V" almost touched the axle housing. The old car had a real good running banger that I've always believed had some internal mods as it was way faster than other A's I've owned or ridden in. I drove that thing all around the Odessa area, had a rumble seat and we'd pile it full and ride around raisin' Hell.
    When I left Odessa and returned to GA in late Nov. '55, I drove that car all the way back, 1500 miles with no top, and no heater either! ****, when you're 18 years old, you're 10 feet tall and bulletproof!
    But I drove that car for a couple years around home and it never had any problem that was caused by the spring torch job.
    But it is a method almost universally condemned by the "experts".
    Dave
  29. i understand that
    i used sae washers and drilled the hole bigger to fit over the shackle
    its the wedge i want to see
    tk
  30. modelAsteve
    modelAsteve
    On the "Stupid Car" we just heated the ends of the main and 1st leaf about 2" in from the end. I wired a 2x4 on its side and let the weight of the car and a little heat do the rest. 1 1/2'' clearance works fine. I got 20,000 miles on it- some not to gentle. The 2 springs together seems to work kinda like a swaybar. The car is much beter in turns than some of my others.
