Door glass-1 piece conversion in '53 Chevy truck
Discussion in 'The Hokey Ass Message Board' started by orula, Oct 17, 2010.
  1. orula
    orula
    Hello guys, please I need some advice. I'm going to replace on my '53 Chevy truck my old door gl*** with vent gl*** and install 1 piece door gl*** without vent such as models '47 to '50. Where do I set the gl*** channel on the front door? Is a very difficult job? I already ordered all the parts necessary for the conversion of the old windows and I opted for the new gl*** with chrome frame,window regulator,guide channel,
    anti-rattle kit ecc.Many thanks to all for your help. Orula (Frank64)
  2. adriancyt
    adriancyt
    I am trying to do the same thing, any news or pic??
  3. Mr48chev
    Years ago most guys just swapped the doors and were done with it. To do it right you will have to find the window moldings from a 47/50 as the 51 and later ones had a spot cut out for the vent window to fit into. Otherwise you will have a gap there.
    67Mal likes this.
  4. orula
    orula
    Many thanks guys
  5. 50scotbolt
    50scotbolt
    Also try and get the regulators too.
    Best option though is to try and find a good set of pre-51 doors. JMO
  6. orula
    orula
    You're right 50scotbolt but I live in Italy and here there are no parts available for American cars :). Today I received the new seals (from Cl***icParts) and I'm trying crare new guides. Reviewed to understand just how do you upload a few photos. Many thanks
  7. dropped53
    dropped53
    from Hanford CA
  8. orula
    orula
  9. I can't offer any tips because I don't have an AD truck, but I love vent vindows. When I had my late model Dodge Diesel, I hated not having vent vindows.
  10. Rick S
    Rick S
    I did this to my '52. Basically, you need to cut the wing window support out and add a new gl*** channel to the hinge side of the door. I used another set of '52 gl*** channels and just flipped them around (left door channel installed on right door and right door channel installed on left door) along with a couple brackets I made. The earlier style window regulators are different as are the inside door pieces...so it's easier just to add power units. I cut an access panel in the door to make it easier to install everything and make adjustments as needed. I installed the gl*** channels, new felt guides and power window motors along with new tinted gl***. The access panel bolts back on and will be covered with a door panel. I also filled in the small notch in the inside garnish molding that was there for the wing window. Since you are going with the gl*** with the chrome frame, make sure you get the larger window felt (47-50) for thicker gl***. The first three pictures show the LH door, last two show the RH door.
    Good luck.
  11. orula
    orula
    Many many thanks Rick_S, you gave me a great help with these pictures and this important explanation. Now I'm arranging everything I need, just finish the work I post photos. Thanks again.
  12. adriancyt
    adriancyt
    I am going to post some pic from my conversion. I decide to use the gl*** without the frame, for two reason. One, I like the look better and second, is cheaper.
    1. you need 4 lower rear door edge gl*** guide ($12 each, 51-55)
    2. 2 door gl*** ($36 each, 47-50)
    3. 1 door window wipes ($28 pair, 47-50), comes the inner and outer wipe.
    4. 2 window felt. You need approx 90" for each door. They don't sell it as a kit, so I got the door window felt and gl*** run kit ($82 51-55). Also you are going to need an extra 2 window division bar insert ($23 each 51-55). I found later a place that sell the window felt, I will post the place later. So you don't' have to buy the felt kit, because you need to do some fabrication.
    All the price is from car and trucks in orange california.
    5. 2 brackets for the front edge gl*** guide, you need to fabricate that.
    This is the door window felt and gl*** run kit ($82 51-55). I just bought this kit to have an idea what I am dealing with. Later I found out a place that sells the felt individually, I think is better because you don't have to fabricate the felt run. You will see it later. Here is their web www.restorationspecialties.com, go to catalog page 9 ($32 part# 10-G 96")
    You need 4 lower rear door edge gl*** guide, 2 right door and 2 left door.
    Cut the vent support
    Install the rear side first, the finger points a reference so when you install the front side is at the same height.
    Take it out and
    cut the little tongues
    Mark and drill holes, 2.5 from the edge
    This is the part you make the front guide brackets, to support it
    Put it on place
    Install the gl*** and the felt channel and try to push the edge gl*** guide to the gl***, so is tight. Them mark the holes
    I hope you see the marks, then drill it
    This is from the other side, but you get the idea. Try to make the hole more in the middle. This was the first, and was actually a little up
    Now everything is in position. Before you put the felt, you have to compensate the size of the gl***. Because I am using the gl*** only, no metal frame around, the sides are going to be a bit small. To compensate this you need to use washers or spacers. I used 2 in the front and 1 in the back edge channel
  13. adriancyt
    adriancyt
    You don't need to fabricate this if you get the felt channel run from www.restorationspecialties.com or other place that sell it. You need 90" approx. This part is the felt kit.
    This is the bottom part from the previous pic. This is the window division bar insert, it come with the kit. But you need and extra pair, because you can use it for one only.
    I used this stud welder that I had it for long time, pretty good
    Final setting
    The corners
    will raise the channel to make it fit better
    I ordered some window regulators to finish the project, when I get it will post more pic. Have fun Orula
  14. adriancyt
    adriancyt
  15. orula
    orula
    Hi Adriancyt,with these photos made me a beautiful Christmas present :).
    Many many many thanks. Thanks to your post now I can continue my project, you have been a great help to me, I was in serious trouble :). You did a great job, congratulations and thanks again. When I finished my gl*** conversion also will post my photos. See you soon and Merry Christmas to all.:)
  16. propwash
    propwash
    from Las Vegas
    Is this place great or what?....I'm amazed every time I log on....
    dj
  17. adriancyt
    adriancyt
    Merry Christmas to all.......
  18. lango
    lango
    from Georgia
  19. Johnny1290
    Johnny1290
    Holy moley awesome pics!
    Believe it or not, this is a big help for me too....but I'm converting my '51 Ford from 1 pc to vents!
    When does the first issue of the HAMB magazine come out, because this place can be a lot better than the car mags I get now.
    What a pleasant surprise, thanks man!
  20. orula
    orula
    Merry Christmas and Happy new year to you all
  21. orula
    orula
    For those interested in seeing pictures of the work to the frame of my '53 Chevy Truck can look for this topic: How to lower my 53 Chevy truck? in Hokey *** Message Board. I would be happy if I could help some of you. If you have any questions go ahead, I will answer with pleasure.
  22. 50scotbolt
    50scotbolt
    I see your point Orula,I've got the same problem here, but it looks like 'the guys' have saved the day!
    Hope you had a great Christmas!
  23. adriancyt
    adriancyt
    I member ask me to fabricate the brakets for him, so I wil post pic of the fabrication in detail for everybody, coming soon.
  24. orula
    orula
    Hello guys,here I am.Today I want to post some pictures of my work to go to the 1 piece door gl***. I hope to be helpful with my work,I have worked hard over the holidays.
    I prepared all the things I need to buy the door gl*** conversion kit from Cl***iParts (MO) and the door gl*** channels are long and 90 ". I chose to install the gl*** with chrome frame because I like to see the chrome part so I could not use the door gl*** channels guide as did our friend Adriancyt but I had to forge for myself.
    From a retailer I bought a bar of iron U-1 "x1" about 20 feet long and I cut the right size for the Door gl*** channels guide.
  25. orula
    orula
    I continue with the processing of the rear channels guides
    I built these guides by copying the original model
    I created a slot for the screw
    Through this hole the screw will be thick and will not give any trouble to the door gl*** channels
  26. orula
    orula
    Now step to the realization of the front bracket starting with a piece of iron box and cut in half
    After cutting to size bracket I welded a bracket on it another 90 degrees and then create holes for fixing
    This is the result photographed from two angles
    Then the door step to drilling
    I hope you can understand the position I found to the front guide
  27. orula
    orula
    Even for fixing the guide at the top I created a loop for the screw
    This is the finished product
    Tomorrow will post more photos on installing the window regulator but to see the work completely finished it will take another few months, the truck will be painted, and only then I can put it back together. Please, if you need any clarification please feel free to ask questions, will be a pleasure to answer you. Thanks to all
  28. orula
    orula
    To install the gl*** one must cut the support of the vent gl***
    Now the p***age is free
    This is the procedure I used for the installation of window regulator
    I hope the work I've done you like it, I tried to do my best :). If you have questions or suggestions please do not hesitate to contact me. Many thanks. Frank orula
  29. 454navyss
    454navyss
    cool "how to" thread.
  30. adriancyt
    adriancyt
    Excellent work, congratulation.
