My 63 falcon build
Discussion in 'The Hokey Ass Message Board' started by 63FalconFutura, Mar 22, 2010.
  1. 63FalconFutura
    63FalconFutura
    from Socal
    Pulled the pan off today.... everything looks good
  2. The Law
    The Law
    from N. AZ
    I stand corrected. I honestly did not expect those numbers. TQ is a tad light but that is a very good set of numbers. Great job man.
  3. Total Performance
    Total Performance
    from Nor Cal
    Congrats on the build so far. I guess theres a few ways to lookat it. You can go through all of your builds doing exactly what every one else says all the time and really never learn anything. Or you can cultivate a concept and see it through to the end and learn as you complete your build from you victories and your failures. That being said its always good to listen to what everyone, (that actually knows) has to add to your builds, digest it and plug in what works in your eyes. Its still YUOR project in the end and if all your left with is a basket of parts from a failure than hell, what a great lesson.
    When I was 16 I was still cleaning oil out of the bottom of drag boats and doing gruntwork learning the trade. Its great your so vested and hands on with such a clear vision of what you want out of your build. One hell of a wow factor when you see the car and a bunch of fun.
    I would do what the guys suggested for your own benifit of knowledge and experiance and try to drop a smaller group of carbs on there to "just see" what the numbers will be. Another one of those learning oppertuni***ies you shouldnt p*** up.
    I own a 63 Falcon sprint with a roller 5.0L, large port, high flow Avenger heads, Forged rotating ***em, 9:1 comp, single 735cfm Holley carb, electric fuel pump, RPM Air gap manifold, MSD 6AL and Blaster 2 coil, Thunderbolt Ram air, Roller rockers, Dougs Headers and an electric water pump. The powerplant makes a solid 435 H.P. on a CH***IS dyno. The car is used as a touring car / open track car. The point being is these Ford small blocks run really strong and even stronger when the combo is correct, or should I say optimal.
    On the carb flip side, our shop car is a 64 Fairlane 500 G***er, econoline straight axle, 455 C.I. FE stroked/forged kit from Survival Motorsports. That huge firebreather has a M/T cross ram manifold on it (very large plenum manifold). I run two 600 CFM Holleys on this car. For me too it was a matter of trial and error.
    I guess getting them to run the best is what its all about. she's your bird, its your call to make it happed the best you see fit. Great build. im really stolked for you.
  4. 63FalconFutura
    63FalconFutura
    from Socal
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Z3yM7noaSe8?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Z3yM7noaSe8?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  5. Falcon Gasser
    Falcon Gasser
    Great job, nice for the cubes, heck thats good for alot of small blocks.
    Jon
  6. 63FalconFutura
    63FalconFutura
    from Socal
    Thanks
  7. newsomtravis
    newsomtravis
    from pville, ca
    ouch........more than i suspected.........but 50 shy........
  8. 69fury
    69fury
    from Topeka
    congrats on getting it together. What's the game plan now regarding further test/tune or putting it in the car with stall, gear, tire size adjusted for your curve?
    -rick
  9. 63FalconFutura
    63FalconFutura
    from Socal
    3k convert 4.11 gears not sure on rear tires yet going to get fenders rolled...then measure
  10. Total Performance
    Total Performance
    from Nor Cal
    Great job! That'll be a little tire fryer! Get that thing ****oned up and out on the road! Can't wait to see it drivin'
  11. newfalconowner
    newfalconowner
    from NS Canada
    that will move the car pretty good, great job
  12. 63FalconFutura
    63FalconFutura
    from Socal
    Bye bye stock suspension
  13. 63FalconFutura
    63FalconFutura
    from Socal
    bye bye shock towers and braces
  14. nocoastsaint
    nocoastsaint
    Give us some update photos.
  15. 63FalconFutura
    63FalconFutura
    from Socal
    i will...check out the new engine masters the 260 has a very detailed and in depth article on the build in it!
  16. 63FalconFutura
    63FalconFutura
    from Socal
    i only got a few pictures .... everything is back from the lazer cutter and the axle should be on here fairly quick IMG00039-20110419-0912.jpg
  17. 63FalconFutura
    63FalconFutura
    from Socal
    well i had knee surgery not to long ago progress has slowed to a crawl now that i cant work and have physical therapy all the time :(
  18. 63FalconFutura
    63FalconFutura
    from Socal
    The long awaited update
  19. 63FalconFutura
    63FalconFutura
    from Socal
  20. 63FalconFutura
    63FalconFutura
    from Socal
    i got a hood and some fenders to cut up ...... hood to make room for the tunnel ram and front fenders that i can cut the lip out of and weld it on for rear fenderwell openings that way i can fit a little bit bigger tire and keep it looking factory
  21. Im liking it, love the work on the front end it looks great.
  22. bathcollector
    bathcollector
    I have a 260 that ran a Weiand tunnell ram, 2 390 cfm Holleys, National Crankshaft Co. ( i think) R8 grind cam, 2 angle valve job ( my builders 3rd stone was broken) headers and a Mallory unilite. It went like stink and i never had any problems with it, it made vac*** for the brakes that everyone told me it wouldn't, didn't bog like everyone said it would so sometimes **** just works against what people think ??? I still have my 260, the ram has gone and in it,s place is a Ford dual quad with the same 390,s so it will fit under the hood of my 66 falcon hardtop.
  23. 63FalconFutura
    63FalconFutura
    from Socal
    Nice, i wish we had more late model falcons here in the states
  24. 63FalconFutura
    63FalconFutura
    from Socal
  25. SLCK64
    SLCK64
    Got a part number for the pistons you used?
  26. 63FalconFutura
    63FalconFutura
    from Socal
    I have to dig around and look
  27. SLCK64
    SLCK64
    Cant be stock if you are running 265"
  28. woodywagon1965r
    woodywagon1965r
    Nice little run on engine dyno hope it works as well on ch***is dyno fig on a loss of somewhere around the 50 to 75 hp at rear wheels should still get you a respectable number at the track
    everyone goes about things there own way ..me i went small blower on my sbf 397 rear wheel hp 11.7 at 118 mph with lots of tuning still ongoing lol cant wait till you post your track time should be quite the ride straight axle g***er best of luck and wishes
  29. Safari-Tracker
    Safari-Tracker
    Does that 4/71 fit under the hood?
  30. 63FalconFutura
    63FalconFutura
    from Socal
