'32 Chevy- The OTHER white meat!
Discussion in 'The Hokey Ass Message Board' started by C5rider, Oct 23, 2009.
  1. Joe Tx
    Joe Tx
    Love the way your car looks and is coming along. Can you explain what you did to lower the rear 3"? Did you use the stock springs/suspension in the rear when you hung the Explorer rear end? I'm getting ready to try to lower mine. I'm using the stock suspension with a '66 chevelle 12 bolt, any suggestions would really be appreciated. I may have to breakdown and buy a kit from Chassis engineering, just didn't want to spend anymore than I had to, but..... Thanks, Joe.
  2. Wally
    Wally
    from Iowa
    I love looking at all of the bowtie's.
    I've got a 31 3w in progress. Will be a 348 tri power in it at some point, It's not done yet but here's a few pics
  3. That sits nice!
  4. C5rider
    C5rider
    from FLA
    Thanks guys! She's now my desktop image and that's helping to keep me actively working on it.
    Joe,
    I used the factory springs. I bought a pair of Speedway saddles and centered everything up. Initially, I thought I might have to go 4 inches but I wasn't sure. I bought a set of 3-inch lowering blocks for 30 bux and installed them. They came with U-bolts and everything. Once I got them in there, it was obvious that another inch of drop wasn't necessary.
    Some folks don't like to run blocks but I figured that they were cheaper than having the spring work done and finding out that it wasn't right. My brother used to run 3-inch blocks in his Plymouth and he had a solid 450-500hp small block in that. With this ol van motor, I might just keep 'em in there.
  5. SanDiegoJoe
    SanDiegoJoe
    Wow, really nice fuel setup!
  6. Real nice looking 32...I've always been partial to that year.Looks like you've got the stance figured out pretty good.
  7. Wally
    Wally
    from Iowa
    Thanks Joe! I wanted an aluminum tri-power intake for my 348 and nobody makes one so I had a buddy of mine powder coat it for me after I grinded all of the sand casting off it. It looks aluminum now!:D My friend also powder coated the carbs. I bought the fuel line and air cleaners from Hotrodcarbs.com The aluminum carb bases and linkage came from vintage speed. ( just a e-bay thing:eek: ) I took it apart after these pics awhile back and polished the fuel line and carb spacers. I'll have to get some more pictures of it sometime and get them on here. I'm happy with how it turned out.:cool:
  8. tyrefryer
    tyrefryer
    do you have the doors off of your sedan? if so would you be interestd in selling to me. email at rogerpusch@tahoo.com thanks tyrefryer
  9. chopper526
    chopper526
    from Phila., PA
    This looks great C5Rider! I'm working on a '32 5 window. Redoing a early '70's street rod. Right now working on the frame, hoping to start on the body as soon as the weather brakes. Biggest problem so far is how to handle the subframe. Some of the guys here have been great. The more pictures the better!
  10. neat thread.
    I just met an elderly fellow with a 31 4dr and 2 dr sedan and a 31 roadster...
    all of which might be coming up for sale shortly...
    hmmmm.....
  11. C5rider
    C5rider
    from FLA
    Thanks Chopper! I have the one photo as my desktop and I'm really diggin it. Can't wait to get it running!
    Altered,
    It is amazing that they are still out there but, they are! You can bet that someone will be taking care of those cars in the future. Hopefully they go to an enthusiast who will treat em right, not just whore em out for a few more bucks, making it harder for the next enthusiast to afford. Keep those 32's coming! Pix are ALWAYS welcome! :D
  12. chopper526
    chopper526
    from Phila., PA
    Joe, what I did was buy new rear shackles that were an inch shorter than the original from Eaton. They come with rubber bushings and no center bolt, they are a modern replacement. I figured that would drop me an inch. Then I disassembled my original springs and tried heating and rearching them, I heard some guys have done that. But, it turned out I had two different springs on the rear. So, I figured the local spring shop was the best alternative. For $300.00 they made me a pair with an arch that was 2" lower than stock. Theoretically, that should drop my rear about 3" and that's what I was looking for. I am picking up the springs today and will hopefully install them this weekend. Let me know if you want the Eaton part number for the shackles and I will dig it up, I think they cost about $50.00. Jim
  13. Joe Tx
    Joe Tx
    I got rid of the spring set up that came with my car and and changed out the rear ones with some others I picked up off a sedan. It seem like they have too much arch. See post # 91 above. Here's some pictures of the stuff that came with my car. Their idea of lowering it gave me nightmares.
    Rear were heated and bent about the same amount in front and rear.
    Front were cut off and welded to the frame and axle???
  14. DougHH
    DougHH
    F*CK i love 32 Chevs.
    My love for 32 Chevs is only kicked down by my love of 34 Chevs will full fenders.
    I would kill for one or the other. *sigh*
  15. nailhead terry
    nailhead terry
    How about a 33. When you do a chevy you have to be creative because unlike our ford brothern we dont have 99% rebop. Thank God thats what I love about the chevy and all those ford parts I used the only one that came out of henerys press was my swapmeet rear cross member. Hey if this was a ford I would of paid more for the grille shell than I did for the car . Keep on bringing them Bowties back I love being part of the splinter group :D well my net is slow check out my Big 3 build here I will post some pics when the damb net is not froze
  16. C5rider
    C5rider
    from FLA
    Whoa Joe! That's some scary stuff right there!
    I remember looking under a Model A one time. It had a Corvette rear suspension under it and for the life of me, I couldn't figure out whether it was bolted up, or down. I mean, I KNOW Corvette IRS and this thing, it was like it was bolted EVERY direction. I think they put the rear spring in just so it would look like it fit.
    That stuff you're showin there would be really spooky, and hard ridin I'm sure!
  17. nailhead terry
    nailhead terry
    Heres one pic of my chevy
  18. nailhead terry
    nailhead terry
    Ohh heck one more
  19. C5rider
    C5rider
    from FLA
    Man Terry! That's a great looking Chevy! I'm diggin the Hemi. I've got a 330 Desoto in my T. There are very few times when a man can ask another man this question, "What size is yours?"
    Get your minds out of the gutterrrrr!!!!!!
    :D:D:D:D:D:D
  20. chopper526
    chopper526
    from Phila., PA
    Joe, that is....SCARY! Leave it that way, it sure will be an attention getter. :)
  21. I like what your doing with the Chevy. You have a good stance. I have 14's on the front., with a lower profile. Tuff to get Chebbies in the weeds.I have cut 1-i/2 coil off the MII .. Rides about 1" lowre than it should.
    My 1st SR and lovin' it.
    Keep up the good work.
    Looks a little like my 31 I have gotten on the road in09. I am stitching uop the seats now.
  22. chopper526
    chopper526
    from Phila., PA
    I'm trying to get mine a little lower. I put new springs in the front with fewer leaves and had them arched about an inch less than the original. The rear springs I just picked up today, they are arched 2" less than the originals and took out 2 leaves, and I used shackles that are 1" smaller than original. I mocked them and the rear in tonight and it still looks too high. The top of the frame at the front spring perch is 18 1/2" and the top of the frame at the rear spring perch is about 21". I am running 14" tires in front and 15" in the rear. Any thoughts?
  23. C5rider
    C5rider
    from FLA
    Great looking ride CapeCodBob! I had some guys looking at mine last week and they said it needed a set of wires on it. I dunno, I kind of like the way it is for now. Maybe if/when I ever make it pretty.
    I like how your engine sits in there. Here's a quick question for y'all. My brake booster/master should be moved back a few more inches to be right and to give me some more room for the trans (700R4). The problem is that it would hit the trans crossmember. I'm thinking of just drilling out the rivets and moving it back a few inches. Has anyone else done this for more clearance and if so, how did it work? Is it strong enough to hold the tranny?
  24. Joe Tx
    Joe Tx
    "Joe, that is....SCARY! Leave it that way, it sure will be an attention getter." :)
    Jim, I don't need attention, Just want to drive it!:D
  25. Ghost28
    Ghost28
    Here's a quick question for y'all. My brake booster/master should be moved back a few more inches to be right and to give me some more room for the trans (700R4). The problem is that it would hit the trans crossmember. I'm thinking of just drilling out the rivets and moving it back a few inches. Has anyone else done this for more clearance and if so, how did it work? Is it strong enough to hold the tranny?[/QUOTE]
    Just support your frame real well before you move the crossmember, after you reinstall it you should be good to go. the brake pedal placement is important for your comfort. Is your frame boxed?
  26. I am old school and like the caps and rings.
    I used a aftermkt. tube tranny xmember.It is in the way of installing a power booster. Also I want to change the MC bracket. As it needs bracing. K'ing the frame might have been better but would have taken a lot more work and planing. But might have given me a stronger mount.
  27. Think about reversing the eyes on the springs or lowering blocks.
    I used a CE universal rear on mine . The springs are flat with full load. .
  28. nailhead terry
    nailhead terry
    Wow !! now for the answer it not the size of the hemi its the size of the owners foot . No its a 330 desoto also and have a set of drag star intakes for 6 -2,s and 6- 94 holleys I love these chevys
  29. Here's my 32 Chev.
  30. nailhead terry
    nailhead terry
