TECH QUESTION chev s-10 rear end choice
Discussion in 'The Hokey Ass Message Board' started by impala59, Jan 7, 2011.
  1. impala59
    impala59
    from vallejo,ca
    Im going to u pull it tommorrow to get a 4x4 s-10 rear end, i have a 50 chevy car with stock 327 motor, 5 speed trans (from chev monza) rear end is a 55 chevy, car is lowered and im running reverse wheels and tires are rubbing a little inside the wheel well,so thats why i want to go to a narrower rear end, what year s-10 4x4 rear end should i be looking for? Does it really matter if its from a 2.8-4.3 motor?automatic or stick truck? The one i was looking at today is an early 80"s blazer. Thanks jeff
  2. 50Delux
    50Delux
    from Michigan
    Mine was out of an late 80's blazer with an auto trans. I dont belive it matters between 4cyl. and 6cyl. maybe the ratio but thats all.
  3. Mr. Speed
    Mr. Speed
    from USA
    I am with 50Delux. The main (practically only) difference in them is the ratio. The 4x4 rearend may be a little lower geared for the application.
  4. gsport
    gsport
    check in the glove box for the rear end codes.. here's a list of them.
    GU1 : AXLE REAR, 2.41 RATIO
    GU2 : AXLE REAR, 2.73 RATIO
    GU4 : AXLE REAR, 3.08 RATIO
    GU5 : AXLE REAR, 3.23 RATIO
    GU6 : AXLE REAR, 3.42 RATIO
    GV1 : AXLE REAR, 2.73 RATIO
    GV2 : AXLE REAR, 5.83 RATIO
    GV3 : AXLE REAR, 3.08 RATIO
    GV4 : AXLE REAR, 3.36 RATIO
    GV5 : AXLE REAR, 3.55 RATIO
    GV7 : AXLE REAR, 4.11 RATIO
    GV8 : AXLE REAR, 2.72 RATIO
    GW2 : AXLE REAR, 2.56 RATIO
    GW3 : AXLE REAR, 2.56 RATIO
    GW4 : AXLE REAR, 3.31 RATIO
    GW5 : AXLE REAR, 2.73 RATIO
    GW6 : AXLE REAR, 3.27 RATIO
    GW8 : AXLE REAR, 4.10 RATIO
    GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
    G80 : AXLE POSITRACTION, LIMITED SLIP
    <!--POLLS--><!--FILES-->
  5. impala59
    impala59
    from vallejo,ca
    thank you very much for the information.
  6. I believe the 4X4 rears were a bit wider than the 2WD ones. Just measure overall width to make sure it's what you need to get the clearance required.
  7. turdmagnet
    turdmagnet
    4x4 measure just under 60 inches hub to hub - 2WD measure 56 inches. When searching for mine, all I could find was 3:42's - never did find anything else. It, matched up with a T5, and my 52 poncho has turned into a great hiway cruiser !!!
  8. Model A Vette
    Model A Vette
    Here are a few more:
    GT4 = 3.73
    GT5 = 4.10
    HC4 = 4.56
  9. dirt t
    dirt t
    What years had disc brakes?
  10. Model A Vette
    Model A Vette
    I did an online search and it looks like rear disc brakes started in 1998.
  11. dirt t
    dirt t
    Thank You
    dirt t
