I have a polished intake for my flattie. The PO clear coated the intake after polishing. The clear has yellow in areas. What is the best way to remove the clear without etching the polished aluminum?
I have used automotive paint stripper on alloy wheels and it didnt seem to etch or mark them, just rinse well and buff. You should try it on the under side maybe.
Had some wheels done shot blasted with crushed walnut shells...took a bit of effort to polish out again but worked out nicely
I've used Easy-Off to remove anodizing years ago. I wasn't sure if it would dull or etch the polished metal. Thanks - I'll give it a try
Easy-Off may be a bit harsh...I'd try some Citri-Strip paint stripper in an incon****uous area first. You can get it at Home Depot or most other home improvement stores. Its pretty mild, but works well.
my experience w/ bike parts is that ez off and oven cleaners will mess up the finish on the aluminum. I will never put that stuff on anything aluminum that I care about again. if it were me, i'd media blast with gl*** bead or the old fashioned way with good old fashioned paint stripper and some elbow grease.
Try an oven............................Outdoors, of course!!!!.......................375-475 degrees, should kill that clear coat, unless they used some high temp stuff............
