New 50 shoebox wiring harness
Discussion in 'The Hokey Ass Message Board' started by PipeWelder81, Jan 5, 2011.
  1. PipeWelder81
    PipeWelder81
    Hey guys, just bought a 50 shoebox with a flatty and 3 on the tree! im picking it up this weekend and i want to rewire the whole car. Anybody have any good suggestions for a new harness? Anybody have any tips for me, im not a wiring guru but have done tons of custom stereo installs etc. Im a little hesitant to do it, but its gotta be done! thanks
  2. smarg
    smarg
  3. PipeWelder81
    PipeWelder81
    Hey thanks for the info. Would anyone recommend a stock type harness, or go with a Painless, American Autowire, ROn Francis universal harness??
  4. Buddy Palumbo
    Buddy Palumbo
    I've installed harnesses from American Autowire , Painless , Ron Francis and I'm now installing a harness from Centech in a '50 Shoebox - in my opinion , they all go in very well . Just take your time , be patient & you'll be fine . Do I have a favorite ?? No , to be honest , not really . Just get one that's color coded and (each wire is) marked & you'll do just fine .
  5. I used a Painless on my '50, I got no complaints about it. I also replaced all the bulbs and sockets to be on the safe side.
  6. Harris
    Harris
    Rebel Harness
  7. X2. Never wired a car before. Great harness and even better tech ***istance (can't put a price tag on that) Only one I wound use in the future. Tdd
  8. shainerman
    shainerman
    Rebel Wire. AMERICA AMERICA AMERICA Hamber, GREAT service, and an actual knowledge of cars.
  9. PipeWelder81
    PipeWelder81
    Hey thanks for the info guys, im gonna order up the Rebel harness i think, i have seen some great reviews on here about it. we will see what happens! haha
  10. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Rebel seems like good stuff and he's a member, I use EZ which is basically a Painless clone, which is basically a GM block clone.
  11. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Where'd you get the shoebox from?
  12. RMR&C
    RMR&C
    from NW Montana
    Are you staying 6 volt or switching to 12 volt. If 12v you can use about any harness....but for 6v the original type is best. 6v requires heavier gauge wire.
    I just put a new original type harness in my F-1, it was sooo easy. Got it from Macs...
  13. PipeWelder81
    PipeWelder81
    well its still 6 volt, and i would like to change it over to 12v while im at it. Im just thinking because its gonna be my daily driver and if i want to do any upgrades it will already have the right electrical system. thats my 2 cents! HAHA
  14. PipeWelder81
    PipeWelder81
    picked the car up out in central PA
  15. Krash
    Krash
    from Cleveland
    Check out Mac's for a high quality original cloth wrapped harness. It will be heavier gauge wiring for 6 volt. You have the option of converting to 12 volt.
    I went with one from Mac's for my '51 Merc. They outsource from another company. The quality was top notch. It was an exact reproduction of the original. They probably aren't the cheapest, but well worth it in my opinion. Check them out.
  16. Retro Jim
    Retro Jim
    Just email Glenn33 and he will help you get the right harness that you will need . If you have any problems he will help you thought the process . All his harnesses are AMERICAN MADE too ! The prices are the best around . No other wiring harness company will give you the service that Glenn and his staff will from Rebal Wiring ! Glenn will also tell you everything you will need to change over to a 12v system . I also have a 49 & 50 Fords tudors and a 55 Ford . When I rewire them , they will ALL be Rebal wiring harness . American made from a HAMBer . You can't go wrong with that !
    Retro Jim
  17. PipeWelder81
    PipeWelder81
    thanks for all of the input! i really appreciate it. i have a question though, i looked at Macs wiring kit which looks really nice because it has all the connectors and what not to match the factory parts. Kind of looks like a "plug and play" type kit. Now if i got a Rebel 9+3 kit, how do i connect everything properly, like the dash wiring, guage cluster, light bulb sockets etc.? i dont need the OEM look of the MACS kit, so im just looking for what will be the easiest and still let me upgrade later on with things like a nice stereo system with an amp or two. thanks again for all the help everybody
  18. Buddy Palumbo
    Buddy Palumbo
    If you're looking to use original-style connectors to connect to your lights & sockets here & there , just look into buying a bunch of solder-on connectors used on old British cars and bikes . The connectors are called "LUCAR bullets and sleeves" , and they hook right up to factory-style Ford stuff . You solder the "bullet" onto the end of your wire , then use the sleeves (available in single , double , triple and even quad) to connect 'em all together .
    (Trying to clarify for ya) The bullets that you solder on , look right like the Ford (silver-colored) connectors on your factory harness . The sleeves , are just that - hollow sleeves that connect 2 (or more) wires together , just as factory . I've used plenty of them on misc. non-british cars , and have installed literally hundreds on British stuff at our (british car resto) shop . You can get them through Moss Motors , Victoria British or the guy at British Wiring (in Bally , PA) has them at a reasonable price too - they're in his online catalog at :
    http://www.britishwiring.com/CAT12_15.PDF
    Look under "bullets and snap connectors"to see them
  19. PipeWelder81
    PipeWelder81
    thanks for the help! im gonna check out that site for the connectors. Hopefully this goes well!
  20. 51ChevPU
    51ChevPU
    from Arizona
    I used Rebel. I was a first timer and it was straightforward. Best part about it was the tech support. If I didn't catch them the first time, I would get a return call and the took no less than a dozen calls from me.
  21. Big Blue Car
    Big Blue Car
    from Orlando FL
    I used an EZ harness for my 50, which was eazy to install and has done well for the last 3-4 years. If i were to do it again I do think I would use a Rebel harness (support the HAMB Family)...
  22. fathertime33
    fathertime33
    i used a painless kit on mine and i made a smart move by getting the multi-colored kit.. cant tell you how hard it would have been if just looking at the fine print on each wire
  23. Buddy Palumbo
    Buddy Palumbo
    I can ... It ****s *** :eek: !
