Hidden Tunes Via An Ipod
Discussion in 'The Hokey Ass Message Board' started by Ryan, Jan 10, 2011.
  1. MattStrube
    MattStrube
    I hate wiring; but that looks like a great solution.
  2. squirrel
    I'm going to figure out how to fit this amplifier board into some of my old rides one of these days....it's designed to use as a bike boom box, but it has pretty much all that is needed to be an automotive "ipod" amp. Just needs a volume control.
    http://www.cathodecorner.com/bikeboombox/
    my brother makes it, I have one of the boards.
  3. jchav62
    jchav62
  4. Ryan
    Ryan
    ADMINISTRATOR
    Correct. This isn't a problem, however, as standard RCA cables are male on both ends.
  5. novadude
    novadude
    Great article! Thanks!
  6. NumbNutz
    NumbNutz
    Ryan,
    Thanks to your very cool tech article, I found what I needed on the PAC website for my application and wanted to share this with the guys if they have a similar situation.
    I have an older Secret Audio system, it has no aux RCA inputs for an IPOD adapter. I found that PAC makes a adapter called the PAC IS31.
    It connects into the FM radio antenna connection and has the RCA connections. Since this adapter connects into the antenna jack it is a cleaner signal than using a wireless adapter. This would also work on any older radio that does not have a RCA input connection.
    Here is the website link: http://www.pac-audio.com/productDetails.aspx?ProductId=820&CategoryID=45.
    Also found that PAC carries the IS77 which has the IS75-IPOD adapter and the IS31 combined in one package
    The link for that is: http://www.pac-audio.com/productDetails.aspx?ProductId=387&CategoryID=36
  7. hotrd32
    hotrd32
    from WA
    Put and ipod system in my car a year ago, plug under my seat. Works great and don't have to have any modern devices visible in the cabin....Love it.
  8. dolsen37
    dolsen37
    from Nebraska
    Just a quick question, can you hook up multiple speakers (2 in package tray, 2 in kick panels) to this system or would you need a bigger amp etc? Not an electronics guy, any help would be appreciated.
    Thanks
  9. Ryan
    Ryan
    ADMINISTRATOR
    Absolutely... this amp would do great with 2 speakers... and probably sound a lot better than my system does.
  10. hudsoncustom
    hudsoncustom
    Hotrodladycruiser did a post a while back where she installed 2 speakers behind the single factory speaker grille under the dash of her Olds. If I remember correctly, the speakers were installed on some sort of a "V" shaped panel that was directed up towards the speaker grille.
    Denise - if you still have that pic, perhaps you could post it here?
    Just a thought.
  11. 21tat
    21tat
  12. NumbNutz
    NumbNutz
    Ryan,
    I think what dolsen 37 was referring to is hooking up 4 speakers. 2 in the front, 2 in the back. I was looking at the connection panel on the Pioneer GM 3400 and wondering the same thing, but found the stuff I needed on the PAC website to make my application work.
  13. SLAMIT
    SLAMIT
    You know. If I didnt know any better you would never know that the volume knob wasnt stock. Very nice job!!!! Stereo head units are a thing of the past. soon they will be like 8 tracks.
  14. Ryan
    Ryan
    ADMINISTRATOR
    If you want to run 4 speakers, you would need to get a 4-channel amp...
  15. hotrd32
    hotrd32
    from WA
    Yeah, I installed a 1200 watt amp and a sub woofer...
  16. geemann51
    geemann51
    I am so going to do this when I get my car back but might try to go 4 channel route with a little sub. Would love to hear that Custom Autosound DVC 5″x7″ sometime...
  17. rramjet
    rramjet
    I had to take a setup like that out of the wifes 39 Std non traditional coupe when I installed the AC last year. It had a couple of small Pioneer speakers on it and sounded good. Not at home so can't post a picture of it. I'm sure it was made by the car builder.
  18. cool37
    cool37
    from SoCal
  19. shainerman
    shainerman
    Ryan, thats a great install. I did installs for years and as fun as it was at sometimes, I HATED it. This is hands down one of the best Ive seen with your factory knob on the level control. Kudos to you.
  20. FlamedChevy
    FlamedChevy
    Great article Ryan.... Have similar setup in my wife's 37 Chevy....
  21. Ryan, I am ***uming you are running a generator. Is this true?
    I would like to install a setup like this, but it would be powered off my 32 Amp Delco-Remy Generator. Currently my only power draw is ignition and lights at night.
  22. Ryan
    Ryan
    ADMINISTRATOR
    No, shamefully there is an alternator on the '39. However, I think if you are careful with your amp selection and got something that wasn't too hungry you would be fine with a generator.
    In any case, here is some video evidence from my drive back from a lunch a few minutes ago:
  23. Deadbird
    Deadbird
    Now that's livin' the life, right there. Cool!
  24. 1LIFE2LIVE
    1LIFE2LIVE
    sounds good for one speaker and seems like its loud enough to not be drounded out by the engine or road noise. nice simple install I will be referencing this in the future
  25. 1Bad67
    1Bad67
    I just installed an Ipod Nano over the weekend in the Corvair. The new Nano has an FM receiver, so I can get the traffic report now too.
  26. BCR
    BCR
    I did this in the roadster before I left for L.A. back in June. It is a little louder with no windows and a cloth top so I used a pretty expensive, really small, amp(1000 watts for a motorcycle) and ran two 4 1/2 inch two way speakers behind the grill on the 40 dash. I also built a super small box that goes on top of the steering coloumn with a single rockford 6 1/2 inch sub. Ran ipod or pandora off droid all the way to L.A. When the phone rings and you answer it with the unit still plugged in it is on speaker, which is nice because you can hear it really good! The best part is it is all under the dash and it sounds great.
    I like the knob on the radio delete plate. Cool install
  27. Gabriel Howard
    Gabriel Howard
    from OKC
    good info, thanks
  28. rustydeuce
    rustydeuce
    Excellent article Ryan!
    I always get queer looks from the traditional guys when I try to upsell them a few extra circuits when they're buying a Rebel Wiring kit from me. telling them "you might just wanna install an ipod one day". :)
    IPods are now officially Hamb Hot Rod friendly. :)
    Lovin' the new JJ iPhone app by the way. Well done on that too.
  29. eddie1
    eddie1
    Thanks Ryan. This will be saved for future reference!
