HEMI Tech- INDEX
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 5, 2006.
  1. George
    George
    A good welder could weld up the upper part of the crossover, or use a block off plate. The Edmunds(that I'm aware of) is made for the small port 331s. See how they match up. There are a number of problems trying to use 392 heads on a 354 block.
  2. 73RR
    73RR
    One piece intakes will not fit if you have tall deck (392) heads on a short deck (331-354) block.
    The Edmunds were made for both the small port (51-53) and big port (54) heads. Which do you have? IIRC, all Edmunds have a t-stat so you need to check port size to determine which head matches the intake. You could run the small port intake on large port heads, been done many times, just not the most efficient.
    You can still use the truck heads, there are two relatively easy solutions, but you will still have water in the manifold:
    ...Weld a tab onto the intake to cover the port.
    ...Once the heads have been cleaned, fill the top portion of the port (in the head) with Devcon or something similar.
    This discussion needs to be moved to a project thread.
  3. streetcoupe
    streetcoupe
    Thanks for the feedback,. jeff
  4. sb hemi
    sb hemi
    from tn
    we build a lot of cars with early hemis . we also build heads that turn an 340-360 small block chrys into a fire breathing hemi . they look just like a 392 hemi with alum heads . we built these beacuse early hemis are geting hard to find and core 392 are getting very expensive . we also mkae ealry hemi parts . and have a few motors ready to go .
  5. scootermcrad
    scootermcrad
    Good to know! Could you please post your info at the end of the following thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=118425&highlight=hemi+tech
    Then I can archive you in the contacts area. Feel free to browse through the other categories mentioned at the beginning of this thread and add your knowledge on each or any of the subjects.
  6. George
    George
    Do an Intro!
  7. bigdog56e
    bigdog56e
    Very informative, I have a '56 330 and powerflite I want to do something with if my health holds up. Thank you.
    Eddie
  8. Tom S. in Tn.
    Tom S. in Tn.
    I don't know where else to ask this, but has anyone gotten any information about the new Lavoie and Adams block, reportedly to be debuted at this years March Meet?
    Inquiring minds; Tom S. in Tn.
  9. scootermcrad
    scootermcrad
    Bump your thread again. I'm sure there are plenty of people interested... Myself included.
    http://www.jalopyjournal.com/forum/showthread.php?t=574697&highlight=392
    Some discussion here, as well...
    http://www.jalopyjournal.com/forum/showthread.php?t=523801&highlight=392
  10. Tom S. in Tn.
    Tom S. in Tn.
    Go ahead Scooter. I bumped both my thread and the one originally started by Kerry from Ka. the last time.
    I'm guessin' the economy got this one on the starting line.
    Thanx, and if you find anything let me know.
    Tom S. in Tn.
  11. scootermcrad
    scootermcrad
    Okay guys! I added a new category for dimensions related to early Hemis. Check it out and add what you can:
    http://www.jalopyjournal.com/forum/showthread.php?p=6731267#post6731267
    If you guys have any other questions about your Hemi or a Hemi in general, please find the correct thread above and ask in that thread. If you don't see a place to ask your question then start a new thread and we'll get it linked in for you.
    Thanks again everyone for all your help! You guys rule! Let's keep the info flowing!
  12. scootermcrad
    scootermcrad
    Hey guys. Just wanted to let you know that in 2012 I'm going to work on getting all the straggling Hemi related threads pulled into the Tech Index. Starting with some topics related to cooling systems.
    I created a new "Cooling Systems" category and merged some of the info into a topic that makes more sense. It was a topic that was really lacking.
    I'll be taking a look at each category this year to make sure there is room for expansion on the topics. If not, I will make some changes to the threads so they make sense.
    Thanks to everyone for their help! Sorry I've been slacking a little on the HEMI Tech section. Keep the threads coming and I'll eventually get them all pulled in and organized!
    Happy New Year!
  13. Rehpotsirhcj
    Rehpotsirhcj
    We should be thanking you for all the time you've put into this.
    so...thanks :D
  14. scootermcrad
    scootermcrad
    Thanks man! In all seriousness, this would not exist without the wonderful input of all the Hemi gurus here on the HAMB. I'm just trying to make it easier for everyone to view it and learn it. Including myself! :):cool: So much great knowledge here!
  15. Flat Ernie
    Flat Ernie
    Tech Editor
    I included a link to this thread in the Tech Archives - it'll stay "alive" that way and you can continue adding to this thread, but always find it via the Tech Archives.
    Great job and I'm sorry it's taken me so long to do this...
    Here's the link to the Tech Archive...
    http://www.jalopyjournal.com/forum/showthread.php?t=659166
  16. moparshawn
    moparshawn
    from usa
    wow i love all the info here. A+++
  17. Kerry
    Kerry
  18. scootermcrad
    scootermcrad
  19. 340HilbornDuster
    340HilbornDuster
    Subscribed!...Good Stuff!
    There's two types of guys....
    The ones that Want Early Hemis and the ones that Own Early Hemis!
    I'm the latter.....
    Aloha Tommy
  20. hotrodderhaag
    hotrodderhaag
    man this thread sure saves a giant headache! nice job.
  21. otti
    otti
    hello
    can i put this 392 intake on my 1956 354 engine?
  22. 41hemi
    41hemi
    Yes that intake will fit the 331,354,and 392!:p
  23. otti
    otti
    its the angle head to intake 354-392 the same? the 392 heads are higher than the 354/331?
  24. 41hemi
    41hemi
    When Chrysler made the 392 which is a taller block than the 331,354, they simply made the difference up in the 392 heads. All the intakes from 55 on up will interchange. If you use 331,354 heads on a 392 block, you simply use spacers between the heads and the intake.
  25. scootermcrad
    scootermcrad
    Gentlemen... The above links are divided up into various topics where these questions can be researched, subscribed and added too. This is just an index thread. Please do not post your questions in this thread unless it is a question pertaining to the Index and or other topic requests. Trying very hard to keep this thread focused and clean.
    Thanks for all your help and responses. Again... Please visit the links pertaining to the topics you have questions about (heads, intakes, interchangeability, etc.) You may also PM me if you are not sure where to post or have content you would like me to add.
    THANK YOU!
    hipster likes this.
  26. Sorry mate , thought I was putting in the right place. Can't be bothered writing it all again.
  27. tallhtrddr
    tallhtrddr
  28. scootermcrad
    scootermcrad
    Hey guys. tallhtrddr bumped this up because he noticed the links weren't working. Is anyone else having issues?
    The first link on the page was related to the social groups. It is not working, but it's a duplicate of the existing Hemi Tech Index posted right below it. I will look at that and see if it's still valid.
    Please let me know if there are issues. THANKS!
  29. Kruegster
    Kruegster
    OK. It's been a year from last post. I will jump start it again. Awesome thread, by-the-way.
    I bought a 331 hemi out of a 53 Chrysler New Yorker. The block is cracked from freezing.
    What poly blocks will the heads work on? I want it for a fenderless Model A. I am a simple guy, just want simple answers. OR, maybe one of you nice fellas' has a 331 block that is good that you'd sell me? :)
  30. 73RR
    73RR
