Velocity stacks
Discussion in 'The Hokey Ass Message Board' started by thegrappler, Sep 28, 2010.
  1. thegrappler
    thegrappler
    Anybody seen or make velocity stacks that have individual tubes for each barrel that can be installed on a 4 barrel carb?
    I think it'ed look cool with a tunnel ram, 2x4 with 8 stacks sticking up, kinda give it a fuely look
  2. hotroddon
    hotroddon
    Someone makes that setup and I think you can get it from Summit and it looks totally G Hey, Nothing like a Fuel Injection
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    not feelin it..sounds hoakey
  4. Rich Rogers
    Rich Rogers
    too phony and way too expensive for what they are imo
  5. squirrel
    tunnel ram with two 4s and two big velocity stacks looks good, in a late 70s/early 80s way
  6. thegrappler
    thegrappler
    I just found that one at summit, way to spendy, If any thing then Id make my own about 8 in tall. not sure about the seventy/eighties thing
  7. rallisracing
    rallisracing
    They used to make individual velocity stack tubes for Holley's 4500 Dominator..Had them on my Dragster years ago....
  8. RichFox
    RichFox
    I made a three Holley 500cfm individual runner manifold once for my 320 cid GMC with a Howard 12 port head. Each venturi fed one cylinder without and balance tubes. On the dyno you could see the cloud of revision hanging above the carbs from when the valve closed and the air column bounced back. I made stacks from exhaust tubing that fit down into the top of the venturi and reached the cloud. Picked up a noticeable increase. They didn't clear the hood. Later I had one of thoe 1150 Dominators that came with short stacks. Ran good. Never tried it without the stacks.
  9. thegrappler
    thegrappler
    I not gunna be running a dominator let alone 2 for my puny sbc but was thinking if I made a round base that fit around a holly 450 and attach some tubes to that, maybe out of chrome drain pipe and bell the mouth, would need to figure out the air filters though.
  10. No, they would still look gay and fake.
  11. gasser55
    gasser55
    Heres the ones I made for my awb 55
    [​IMG] [​IMG]
  12. yeah im gunna agree with the others. i too thought about doing this. i like the look of 3 dueces on a sbc with stacks but i dont have the cash to get that setup, so i was kickin around the idea you have a while ago. adn realy theres just no way for it to look good.
    just a normal large stack for the 4 brl would look better than a bunch of little ones attached to the same thing. just run a normal air filter. sure it doesnt look super old but it looks better than something trying to be somthing its not.
  13. voxnut
    voxnut
    from sacramento
    Fake stuff blows. If you have a carb/carbs, just display them loud and proud.
  14. BISHOP
    BISHOP
    Those look like the tuba section at a football game.
  15. the-lowrider
    the-lowrider
    I think that kinda air filter also would be an option, but i don`t know if that one is kustom built or aftermarket ?
  16. Please don't take this the wrong way but if you are bulding a hotrod than everything on it should have a function. Like Rich Fox said there are cir***stances where a velocity stack serves a function.
    You could also make them function on your setup but with a tunnel ram and that huge plenum normally ***ociated with a tunnel ram, I'm going to suggest that if you look real close the fog mentioned by Rich is going to be down toward the top of you venturi and not hanging above your carb. In essence a velocity stack alters your venturi length.
  17. CR1193
    CR1193
    from Tennessee
    There is an A-model coupe in the new street rodder mag with 2 large ones inline on each carb, looks pretty cool. I will see if i can find a picture.
    There is a company called TWM induction that makes some also, but would have to be modified for a 4-barrel setup.
  18. CR1193
    CR1193
    from Tennessee
    Here is some I make for'em, the merged set looks pretty cool, real close to what was on the "A" I was talkin about earlier.
    Shoot me a PM if you want any info on this type......
      52.5 KB
  19. Deuces
    Deuces
    Now you sparked my intrest!! What are those ones on the racks???? :)
  20. thegrappler
    thegrappler
    Its cool, I shifted gears with this Idea and went to a 671 Blower, still going to have 2 4s but probably the single large stack on each carb.
  21. falcongeorge
    falcongeorge
    from BC
    niiiice...
  22. CobraTracks
    CobraTracks
    I had a tunnel ram with two carbs and NOS with a scoop and I think they looked pretty serious. At one point I welded two velocity stacks together and they looked like they belonged.
  23. jamn47
    jamn47
    I like the regular K&N's for performance, I just wasn't very happy with the finish though. They started to tarnish on the stack real quick. I may change to a Blower scoop we'll see.
  24. thegrappler
    thegrappler
    Yup real niiice ;)
  25. jamn47
    jamn47
    If you happen to go with the K&N's
  26. jamn47
    jamn47
    Just be careful of the clearance, they are pretty large in dia, they don't fit some Tunnel rams.
  27. 1971BB427
    1971BB427
    from Oregon
    Here's some Hilborn stacks on my neighbor's 48 Austin:
    It's hard to tell with the hood closed, but they're fake. Underneath is a regular 4 bbl. carb and a 14" chrome air cleaner!
  28. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I was gonna,and am saying possibly use hilborn stacks.BUT,since you went with the blower route.......You still could,but would have to fab. Possibly would look like what's out there in the aftermarket=summit,but it would be unique and cool if you pulled it off. Just a thought.......
  29. CR1193
    CR1193
    from Tennessee
    Thats some throttle bodies for some late model ****, big bore fuel injection systems for kids with deep pockets!!!!
    But we make some for V-8's as well, similar to a weber setup. With the velocity stacks it's kinda hilborn looking but much more driveable. Somebody at SEMA called it "NEWSTALGIC" hehehe, I thought it was pretty funny. I guess it's like they say "not many new ideas, just variations".......
  30. thegrappler
    thegrappler
    Probably wont fit mine, no Tunnel ram, 671 Blower but I made my own carb top plate and am running 1850s inline, they are 8.75 apart so if the K&Ns are 9 inches its a no go
