Another Weesner Inspired Hot Rod (Lit Up)
Discussion in 'The Hokey Ass Message Board' started by 193257, Jan 10, 2011.
  1. 193257
    193257
    Okay boys and girls.
    Don't know if you remember or not but Jimmy Hervatin created a Hot Rod from a painting that Keith Weesner Painted called Emerald Tide. If you haven't seen that build here is a link to it. http://www.jalopyjournal.com/forum/showthread.php?t=378992 You will be amazed. Well Jimmy toured several shows in it in 2010 along with his son and wife that I will just call WC (Wild Child). Just kiddin Deb. So he has decided to build another Hot Rod created by the Weez. It's a 51 F1 Ford Pickup called LIT UP. Keith is an accomplished artist and here's a link to his web site. http://www.keithweesner.com/ Check it out. Keith has a lot of talent.
    Here's what jimmy is going to create. LIT UP
    When Jimmy gets a notion to do something he pulls out all the stops and doesn't hold back on anything. This guy's got so much talent it's not funny. Jimmy does some searching and comes. up with a 51 Ford donor truck. Most guys look for the best one they can find but Jimmy can fix anything and I mean anything. Here's the truck.
    Next he pulls it apart and sandblast the cab.
    Then he decide's to chop the top and section the cab. The chop will be 5 1/2" in the back and 6" in the front. The section will be 1 1/2" in different area's of the mid section as you can tell by the pics. First he decides to section the cab.
    Then put's it back together.
    Then he chop's it and starts cutting.
    Since the truck has a severe chop the back window would be a mail slot so he only chop's the rear window area 3".
    Since the rear window is pretty wide it would look out of proportion so he narrows the window to 28" and then lowers the window to give it the right look. Before he finishes the rear window area he makes a wood buck and a new top on his owner built Yoder hammer.
    Here he does some finishing work on his planishing hammer.
    Then he welds it in
    Here's the finished top
    As a friend of mine (Lynn Pew) always says. Stay tooned for the updates.
  2. JJK
    JJK
    Amazing work...a true artist
    LeoH likes this.
  3. fuzzy bunny
    fuzzy bunny
    uuummm...Damn! Subscribed! this is going to be great.
  4. OhioRiv
    OhioRiv
    This guy's got so much talent it's ridiculous. This is gonna be good.
  5. lorodz
    lorodz
    wow another one ..cant wait for this build ..
  6. Oh DAMN. It looks like he has it ALL under control
    LeoH likes this.
  7. TexasSpeed
    TexasSpeed
    from Texas
    Yes!! I'm ******** excited that Jimmy's building another Weesner-designed car. I absolutely loved the Emerald Tide.. Very beautifully done. Jimmy's build-up of that truck is what got me hooked on Weesner, so many kudos goes to this guy.
    I'm looking toward seeing the build up pictures of this one! Subscribed!
  8. Master of None
    Master of None
    No F"in way, that guy is incredible! and a hell of a nice guy to talk to. Had the privilege at the Heartland nationals in Des Monies Ia. Cant wait to see this one done. Subscribed!
  9. fab32
    fab32
    Another amazing project from the most amazing shop I can recall and run by a man so talented it makes me wonder if he's made a contract with the devil to turn out the quality he does.
    Frank
    chryslerfan55 and kidcampbell71 like this.
  10. henry29
    henry29
    Is that the all aluminum A pickup in the background?
  11. Gator
    Gator
    from Statham Ga
    Crazy - and that is one clean shop!
  12. Sprout
    Sprout
    amazing work
  13. JeffreyJames
    JeffreyJames
    from SUGAR CITY
  14. 562roadster
    562roadster
    Wow! subscribing to this thread.....
  15. landseaandair
    landseaandair
    from phoenix
    Beautiful work, if I only had half his skills.
  16. 193257
    193257
    Once Jimmy gets it to this point he puts the cab back on the frame and lowers the frame with a 3" dropped Axle and flip's the rear end. Then he mock's up the motor and fender to see how it is going to sit. He decides it doesn't sit low enough and does some investigating on how to lower it more.
    No problem for a man with this kind of talent. He says I think I can build a lowered frame easier that I can lower the stock one. So he decides to do just that. Now this is where it seperates the men from the boys. First he draws it up on his computer.
    Then he proceedes to cut it out with his laser.
    After he cuts it out he runs it through his sander and here is the finished product.
    He cuts an inner and outer frame rail and bends a 90 degree bend on them and then welds it in the middle to make a boxed frame rail.
    Then he puts it on his jig table and welds it together. This thing is a piece of art.
    WaLa!!! One complete 51 ford truck frame that is lowered a total of 10"
    The rectangle holes in the top and bottom frame rails will be curved and put in later. He had to do that so he could bend the frame rails in the brake.
    For those of you that haven't seen Emerald Tide, He is planning on be at the Lonestar Roundup this year and I'm trying to talk him into bringing
    Lit UP at what ever stage it's at. I think i have convinced him. It will be the first time that Weez has seen the new project. It will be your chance to buy a print of Emerald Tide and Lit Up and have them signed by the Weez and Jimmy the metal man. Stay tooned there will be more to come.
  17. 193257
    193257
    Yes that's it.
  18. Harms Way
    Harms Way
    This is gonna' be good ! :D
  19. GARY?
    GARY?
    I was gonna' say that!!:D
  20. THR1LL3R
    THR1LL3R
    from St. Louis
  21. droplord49
    droplord49
    from Bryan, Tx
    I saw Emerald Tide in person at the Street Rod Nationals and it was just amazing. I can't wait to see how this one turns out.
  22. hasty
    hasty
    That has cheered up my evening! Thank you very much for posting this and the previous thread. Can't wait for updates.
  23. 53olds
    53olds
    Holy Hell that is cool!
  24. Deadbird
    Deadbird
    Oh boy, here we go!
  25. cracker head
    cracker head
    Holy ****! Dude has serious skills.
  26. stude_trucks
    stude_trucks
    Damn, I'm seriously embarr***ed for myself.
  27. Stutz
    Stutz
    Wha.... what just happened. I blacked out from the awesomeness.
  28. BLUECOLLARKUSTOMS
    BLUECOLLARKUSTOMS
    SERIOUS skills here. This is gonna be another fine looking build, I've looked at Weesners art before and thought somebodies got to build that truck, its good to see that its being done by Jimmy. SUBSCRIBED Scott
