Monroe Shock Dimensions re-arranged
Discussion in 'The Hokey Ass Message Board' started by 4t64rd, Dec 17, 2007.
  1. I took the text from the Monroe shock dimensions PDF, and rearranged it to make it easier to find the shocks by size. They are now sorted by style of end (upper first), then by size of end, then by lower end style and size. I needed this to find my shocks
    You can cross reference #'s with other brands.
    I hope this helps somebody.
    Thommyknocker likes this.
  2. Moonglow2
    Moonglow2
    Hey 4t! Thanks for your efforts, Dude!
    Damn! It's about three weeks too late to do me any good. At least the parts guy I deal with was nice enough to hand me an old Monroe catalog to study at my leisure before I found the one with the right dimensions for my application.
    Once I boned up on type of end part codes I had to go thru my catalog underlining those that met that criteria. Only then could I find the dimensions I needed.
    Hey fellow HAMBers do yourself a favor and d/l this zip for future reference.
  3. gashog
    gashog
    Great tech, thanks!
  4. AHotRod
    AHotRod
    Excellant job and information, this will make my job here at the shop much easier.
    Thanks Mikey !
  5. revkev6
    revkev6
    from ma
    good job, I just end up getting stock 48 ford deluxe shocks for my cars from napa. works well for me.
  6. redlinetoys
    redlinetoys
    from Midwest
    This chart is a God send compared to the mess that Monroe has on their website. THANKS SO MUCH!!!!!!!!!!!!!!
  7. fab32
    fab32
    Definitely going to use this information. thanks,
    Frank
  8. praisethelowered
    praisethelowered
  9. Jalopy Joker
    Jalopy Joker
    THANKS-Wow-have spent many an hour trying to figure out what shock might fit what-on the front of my '47 Ford Coupe with a stock axle with reversed eye dearched spring with three leaves removed I found that rear shocks from an early 60's Corvette were perfect. I know I will be shot for this, but Tokico brand shocks out performed any Monroe, KYB, etc that I tried.
  10. spoons
    spoons
    from ohio
    THANK YOU!!!
    I spent 2 hours the other night locating a set....
  11. zman
    zman
    from Garner, NC
  12. johnsons63
    johnsons63
    from Hawaii
    Thank for this man.
    Guys i'll just ask cause i'm planning to buy a monroe shocks but i've read some negative comments about monroe shocks. what can you suggest? should i buy a monroe shocks or other brand like gabriel, bilsteins and rancho...
    which is better?:confused::confused::confused::confused:
    _________________________________________________
    If everything comes your way, you are in the wrong lane.:D
  13. BobbyD
    BobbyD
    from Belmont NC
    Great tech and will be a ton of help. Monroe's version of this was a nightmare to try and figure something out. Thanks man!
  14. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
  15. JohnFromVentura
    JohnFromVentura
    This sure helped me find a shock for my 63 Pontiac Tempest. The Monroe catalog (website) implies that Tempests weren't made until 64! :)
  16. JohnFromVentura
    JohnFromVentura
    Okay ... I've outsmarted myself again! I used this handy chart to pick and order Monroe 37019's. The diameter of these shocks are to large (2"+) and they have to fit through an 1 3/4" hole in the lower control arm.
    Is there a listing anywhere of Monroe P/N vs Outside Diameter???
    Thanks for any Help, John
  17. biggeorge
    biggeorge
    great chart thanks
  18. 48prerunner
    48prerunner
    from ny
    holy cow this must have taken hours thanks saves us hours works great.
  19. 55 dude
    55 dude
    if yougo to the monroe site and call for tech help they will get you what you need. just have your specs ready.
  20. fastcar1953
    fastcar1953
    old thread but wow will use this alot. thanks
  21. Mr48chev
    Thanks for doing that. You will save a lot of folks a lot of headaches with it.
    I've dug the link to their chart out more times than I can count in the past few years for people and this really helps.
  22. salf100
    salf100
    Ok so this is perfect thanks man! But, how do you properly measure for shocks after youve lowered a vehicle.
  23. this thread should win every tech week without ever having to even enter them.
  24. Dirty2
    Dirty2
  25. WCRiot
    WCRiot
    I googled searched and found this thead. Excellent help!
  26. Thank you for your effort on this. It will come in handy!
  27. lgh1157
    lgh1157
    Just found this.
    Awesome , Thank you !
    L
  28. bonesy
    bonesy
    This helped soooo much!
    I know it's an older post, but it sure is a goodie.
  29. Rice n Beans Garage
    Rice n Beans Garage
    Thanks getting ready to fit rear shocks
  30. Gasser 57
    Gasser 57
    from New Jersey
    That's a very nice resource to have. Thanks for taking the time to post it up.
