Mounting switches for Air Rid
Discussion in 'The Hokey Ass Message Board' started by 51fordor, Jan 12, 2011.
  1. 51fordor
    51fordor
    Just wanted to ask guys to post pics of where they put the switches for the air ride on their car. So if you have em post em. I am working on my setup and don't want the typical switch box in the car. Thanks in advance guys!
  2. toreadorxlt
    toreadorxlt
    from Nashua, NH
    totally OT ride, but I had them in the dash of my truck... 5 switches, one for each corner and one for the EDC...
    Right to the right of the steering wheel.
  3. stevechaos13
    stevechaos13
    I'm trying to figure out the same thing. I've got that damn acrylic switch box and I hate it. I'm thinking about building a center console for my Galaxie and doing some sort of hidden mount. I like having switches, but hate having visible SWITCHES...if that makes sense.
  4. 51fordor
    51fordor
    That is what I don't want. I do not want to look in and see that horrible acrylic box!
  5. I saw some once that were in a pomade tin that sat on the front seat
  6. michaelmoore
    michaelmoore
    ive got mine on a p s 2 controller that hides under the seat when not using .
  7. michaelmoore
    michaelmoore
    i will post pictures when i get home.box mounts under seat with wire to controller about 6 ft long able to be out and then put back without seeing. got it on ebay 60.00
  8. stevechaos13
    stevechaos13
    Never been a fan of those video game controllers myself. Not trying to be all "traditional", it just looks cheesy to me.
    Have you thought about hiding them in your glove box? I've seen some hidden inside a glove box along with the radio, and it makes for a really clean install. Unless you plan on playing with em on the road, there's really no reason for them to be within reach.
  9. michaelmoore
    michaelmoore
    well show us your wonderful idea ;)
  10. michaelmoore
    michaelmoore
    i use mine on my 69 caddy convertible .and yes i use mine going down the road. mine has fbss
  11. TMunster
    TMunster
    from Las Vegas
    could mount under dash or even mold into dash
  12. THR1LL3R
    THR1LL3R
    from St. Louis
  13. knucklepower
    knucklepower
    from .
    good tread, iam also looking for ideas,and please pictures from the trunk / your setup
  14. 51fordor
    51fordor
    That is my exact dash. 1951 shoebox. I like those switches. Where did you pick them up from?
  15. forsakenfew
    forsakenfew
    from seattle
    I strongly disagree with "unless you plan on playing with em on the road, there's really no reason for them to be within reach"
    Mine are mounted in my dash, next to my door within easy reach of my hand at all times. I can't tell you how many times I've had to raise the car up while driving because of some unseen object or pothole. You also need to be ready for a failure of a a bag. (rare, but it does happen.) If you lose a bag at speed, it may help to adjust the pressure in the other bags and avoid more problems.
    I'll see if I can get a pic of my switches for ya.
    (I will agree with you on the subject of the boxes, video game controllers, etc. Just doesn't look clean to me, and too much like a "hopper" car. )
  16. Domino
    Domino
    There is a post on here somewhere showing how one guy used the push ****ons from his factory radio as the switches.
  17. Never2low
    Never2low
    It's not traditional, but look through the junkyard for a small, overhead console. Find one with two map lights, and a fold-down door for sungl***es, mount the switches inside. It serves two purposes, stays out of the way, and dosen't stick out like a sore thumb. Paint & strip to taste.
  18. propwash
    propwash
    from Las Vegas
    because this is a traditional site, I suggest you put those air ride switches in the same place all the guys in the 50s and early 60s put them.....if you need to ask 'where is that' - I can't help you
    dj
  19. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    When I bagged my '50 Ford, I put the switches on a plate under the dash. They were out of view, you just reached under and flicked the one you wanted.
  20. THR1LL3R
    THR1LL3R
    from St. Louis
    They're manual switches, no solenoids needed.
  21. Anderson
    Anderson
    In my console.
  22. Reds 29
    Reds 29
    The truck is o/t 67 chevy pick-up my son and I built. We built the center console and got rid of the acrylic box by mounting switches in the console. Pressure gauges mounted above stereo.
    Red
  23. MP4/8
    MP4/8
    They are paddle switches. Air Lift, firestone, and ride tech all sell them. Just check with one of their dealers.
  24. choptvan
    choptvan
    you can see em if you look REAL hard.
    Before I got it all finished up.
  25. flt-blk
    flt-blk
    from IL
    Mine are in the ashtray on my 59 Chevy, since I don't smoke it seems to work fine. I kept the cigarette lighter too so I can plug in my cell phone.
  26. chevrolayd
    chevrolayd
    i used the switches from my ugly acrilic box and put them in a guitar petal. the 4 on bottom are corners and the two outer knobs are front and back
      46.7 KB
      49.4 KB
  27. chop32
    chop32
    An older set-up, but in my '49 I mounted the panel under the dash inside the flip-down tissue dispenser.
  28. 51fordor
    51fordor
    I am going to come up with somthing to mount them in that looks cool, but can be stuffed under the seat when not in use. I will put my guages in the glove box. I really appreciate the pics guys!
  29. WhiteDevilsCC
    WhiteDevilsCC
    from Spring Tx.
    Here's my switch box I made it's small and you can throw it under the seat if you don't want anyone to see it. [​IMG]
  30. gnichols
    gnichols
    from Tampa, FL
    X2. I've only got a few hundred miles on mine so far, and being able to make fast adjustments and monitor or adjust the pressures at a glance far exceeds the need to hide them. One day I plan to have a cover that flips up when I drive and down to hide the gizmo when parked. You could do the same on an under dash panel, have it flip back and up to hide it when the trad police guys are peeking inside. Gary
