will a 33 grill fit a 34 hood if your not running side panels.Are they the same around rad cap area and front of hood.thanks Bucky
Looks like you got your answer but there is a 1 1/8" difference at the top, and obviously the curve on the sides of the grill is different. Personally I like the 33 grill better.
The hood is different as well,.. a 34 Hood will not fit a 33 Grill,.. and a 33 Hood will not fit a 34 Grill, There are also some differences in the body,.. 1. Inside door handle location. 2. Notch on cowl for hood 3. 34 had smokers gl*** in the doors, and a sail panel in the back of the window opening. A few other things,.. but this is all I can remember.
