1956 Pontiac Chieftain power steering??
Discussion in 'The Hokey Ass Message Board' started by fitzee, Jan 6, 2011.
  1. fitzee
    fitzee
    Have a friend that has a 56 Pontiac Chieftain that he is restoring.seems someone tried to remove the column and broke the steering shaft and column. The car has power steering and is a automatic. He is in need of a new box and column. Is there any other years that might fit?? Chevy?? Olds?? and Who is out there where I can source these parts??Thanks
  2. Ill write myselfe a note & try to CK my old Hollanders tomorrow
  3. bryan6902
    bryan6902
    55-57 Pontiac... Is this a Canadian Pontiac or a US Pontiac?
  4. fitzee
    fitzee
    He tells me it is a US Pontiac. That was something else he want to know,what the difference is between Canadian and US
  5. fitzee
    fitzee
    The car has been off the road a long time.found this pic from the early 80 of the car.if this is any help.
  6. Edelbroke
    Edelbroke
    I could be wrong, but 55-56 Chevy may also fit
  7. Any casting #S on gear ?
  8. fitzee
    fitzee
    I was thinking the same thing but this has a power steering box I think the chevys had a power ***t rack??
  9. 55chieftain
    55chieftain
    There is a Rodders Digest tech article on installing a 605 Gm box on a 55-57 over at pontiacsafari.com. Pontiac garage to upgrades will find the article. For some reason acrobat reader wont list the address to send a direct on my computer for the article?
  10. fitzee
    fitzee
    The only one i see you can make out on column is the pics. If there is a part number some where else where should I look??
  11. fitzee
    fitzee
    We are sizing up that idea. but where this is a restoration we are trying to keep is stock. But please still post link if you find it.I want to see that myself.
  12. 55chieftain
    55chieftain
  13. 55chieftain
    55chieftain
    I do know of a Hamber that has the stock setup or used too, I'll get in touch and p*** the info along if your interested. He's hardly ever on here.
  14. Mr48chev
    I did that 605 swap on a 57 Star Chief I had years ago. On that car the steering column had to be slid down to the box a bit making the wheel just a bit closer to the dash.
    On the 55 he is going to have to modify the the column and shft or swap columns.
    If he wants to keep the stock wheel and column, the simple way out may be to swap the steering shaft and lower bushing out of a later model column into the 55 column.
    And now we know your friend really is that guy who can tear up steel balls with a rubber hammer in the middle of a sand pile.
  15. bryan6902
    bryan6902
    Canadian Pontiacs, of this era, share ch***is and driveline parts with Chevrolets. US cars are all Pontiac, totally different, no ch***is parts interchange. There are other differences as well but this is the biggest. Power steering stuff seems to be tough to find for these cars. I needed the factory P/S pump bracket for my 57 and searched forever to find one.
    Try French Lake Auto Parts, Alliance Vendor, they may have the column and gear you need. Last time I was there this fall they had 6-8 55-56 Pontiacs.
    There is another guy in Texas who I bought parts from, his name and phone number are in the 2nd to last page of my build thread. Would post his info but I got to go to work.... PM me if you can't find his info.
  16. fitzee
    fitzee
    That would be great.thanks
  17. fitzee
    fitzee
    Thanks for all the info I`ll dig out that number and p*** these contacts on to him.
  18. My Hollanders said a 55 would fit * have to drill the frame
  19. fitzee
    fitzee
  20. 55chieftain
    55chieftain
    I'm not much of a computer guy, do you have the latest version of adobe reader-version 9? It works fine for me. I'll attatch the file and see if that helps.
  21. fitzee
    fitzee
    No all i have is 7 and that file did the same thing. Don`t worry about it I got into the site but not sure what page your sending me.What is it listed as under the site??
  22. 55chieftain
    55chieftain
  23. fitzee
    fitzee
    Gots ya. thanks.
  24. Roy39
    Roy39
    Fitz that car is 1956 American Pontiac ----- same as the one I had.
    If i,m not mistaken olds & buick of the same years 55-56-57 will interchange with Pontiac. The American Pontiac has a chaissis ( frame ) same as Olds & Buick X frame. But I was wrong once before.
  25. dshigeka
    dshigeka
    I sell rebuilt 605 steering gears for 56-58 Pontiacs and Oldsmobiles. The bolt pattern is the same. Let me know if you want one.
  26. DaxxRuckus
    DaxxRuckus
    What do they cost? I'm about to pull my stock steering box to have it rebuilt.
