Can you name this VINTAGE wheel?
Discussion in 'The Hokey Ass Message Board' started by NVR2ND, Jan 13, 2011.
  1. NVR2ND
    NVR2ND
    As usuall I need help:confused:
      188.5 KB
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    mickey thomsons
  3. GaryB
    GaryB
    from Reno,nv
    ansen sprint ?
  4. hotrod40coupe
    hotrod40coupe
    Could be the old U.S. Wheel...
  5. NVR2ND
    NVR2ND
    If it helps any, its 15 x Id guess 16? The Hoosiers say they are 18.5 wide, and they stick out a little further than the rim...
  6. BADBIRDCAGE
    BADBIRDCAGE
    from Virginia
  7. bobwop
    bobwop
    from Arley, AL
    who are you calling a SLOT?
  8. B.A.KING
    B.A.KING
    i wish i was a SLOT......Errr............ well.i................... that could be any number of wheel manufacturers.it MIGHT be stamped inside. but if i had to guess you could pick from one of the above names and get it rite
  9. pan-dragger
    pan-dragger
  10. 51 BIRD
    51 BIRD
    Are there any numbers or whatever cast/stamped on the backside?
  11. Edelbroke
    Edelbroke
    American Racing - Indy (slots) Not all that vintage
  12. hotroddon
    hotroddon
    Indy Slots were made by US Wheel if I am not mistaken - at least they were when I sold them at the tire store in the 70's
    US Indy Mags were a trade name, and if I'm also not mistaken, recently the original owners son just reacquired control of the name and is making them again.
  13. stevechaos13
    stevechaos13
    All the US Indy's I have are cast with US INDY and the size on the back of the rim.
    Is this a wheel you have or just a pic you found?
  14. the four step downs at the edge are a good indicator that it is probably wider then a 10" width....personally i like it when they don't have a step down at the back by the centers...i have RI (rocket industries) on the topolino...they also have the a smooth transistion from the hub area to the outter...makes em look wider,,,,
    my new mags for the front don't have any brand on them..and they also lack an inner step down....
    so i guess i'm no help with IDing yours.....
  15. NVR2ND
    NVR2ND
    I have not seen anything on the back of them, and Steve... I have them, well 2 of them. I will try to look at them in the light tommorow....Thx
