i have a 1951 cranbrook 4 door im converting to a two door and wanted to know if anyone had a rough idea on how long and actual 2 dr door is any input will help thanks alot!!
it's just under 45" at the top (just below window) and just under 46" at the bottom. i have a 2dr 51 in my garage, so let me know if you need anymore measurements.
I wouldn't start cutting till you have the doors. I turned a two wagon into a two door hard top wagon and was surprized that the hardtop doors bolted in and fit perfect on the wagon. I have a 48 ford business coupe that I moved the B-pillar back 8 1/2 inches for the sedan door and it was quite simple
